Member dulo Posted January 19, 2011 Member Report Share Posted January 19, 2011 I it possible to run Autoretopo on a pure Voxelmodel ? I wrote an importer which reads dicom mrt/ct scans and i would like to create meshes for the scanned organs. I only see the possibility to run autoretopo on meshes which creates voxels models from meshes, but i dont need this step because i already have voxel models. thanks for help and tips dulo Quote Link to comment Share on other sites More sharing options...
Member ace63 Posted January 19, 2011 Member Report Share Posted January 19, 2011 Of course, I think that is what is was primarily made for In your voxtree rightclick the object you want to auto retopo and you'll find several options for auto retopologizing your voxel objects. Quote Link to comment Share on other sites More sharing options...
Psmith Posted January 19, 2011 Report Share Posted January 19, 2011 I'm not sure what your scan data looks like - but, at present, there is a limit to the number of scan data points that are supported for import into the Voxel Room. The best way to experiment is to use the opening import wizard - choosing the voxel area of the dialog and then clicking on the "folder" icon. Your data will either import or not. If it does, experiment with using AUTOPO with its default settings. If that is not acceptable, trying small variations in the data fields in the AUTOPO wizard. Greg Smith Quote Link to comment Share on other sites More sharing options...
Member jnothing Posted July 16, 2013 Member Report Share Posted July 16, 2013 I have a somewhat complex space ship I made using tinker objects in voxel mode. I'm desperate to figure out how to best get it retopo/uv/normal mapped/painted. I don't want to take the next step until I know exactly what to do. I can't seem to invoke the auto-retopo for the whole thing, just each layer. That makes good sense, but is the workflow really to pick it apart and retopo each little piece? I'm quite confused and could really use some help. Quote Link to comment Share on other sites More sharing options...
Contributor Malo Posted July 17, 2013 Contributor Report Share Posted July 17, 2013 Show some pics, please. Quote Link to comment Share on other sites More sharing options...
