moska 3 Report post Posted February 16, 2011 1.tiff2.tiff3.tiff Hi i post this here because its probably just a Silo problem, but may be someone here with more experience could advise me. in picture 1 you can see a normal .obj loaded in 3dcoat for PPP but if that .obj comes from Silo 2.2 mac build, i notice the strange shading you can see in pictures 2 and 3. i hope any of you could see whats going on,cause silo could be a great tool for creation but as im using it ive noticing this strange shading in .objs, wich persists if i export it back from 3dcoat. maybe someone knows whats about, cause for me its just Share this post Link to post Share on other sites
Bob Morane 1 Report post Posted February 17, 2011 Hi. It would be easier to find what's going on if we had access to the obj. First thing that comes to my mind when i see strange shading is bad normals orientation. I wish there was a way to visualize and change them in DCoat retopo room. EDIT : BTW you should post images as .jpg, tiff images don't show in my browser so i had to download them. Share this post Link to post Share on other sites
moska 3 Report post Posted February 17, 2011 Hi Bob thanks for your help i dont know what is it ,normals seems fine to me heres the bad scene from silo please have a look im really curious casa3c.obj Share this post Link to post Share on other sites
Bob Morane 1 Report post Posted February 17, 2011 Yep. Normals are pointing inward wich means what you see from outside is the back of the faces. I'm not sure 3DCoat can paint on those back faces and some rendering applications can't use them anyway. I reversed them to test and the outside can be worked, but of course the back faces are now towards the inside and you won't be able to paint inside. If you just plan to use the inside, just don't worry of the black outside. If however you want to use both you really want to give some thickness to your walls so you have faces pointing inside in the inside, faces pointing outside on the outside and back faces in the thickness of the wall. Share this post Link to post Share on other sites
moska 3 Report post Posted February 18, 2011 thankx Bob but sorry if i didnt explain earlier that this is an interior ,the exterior wil be another mesh,so normals are fine to me .no point painting both sides anyway. its for unity3d.i even split this mesh into smaller pieces to switch on and off and be able to paint inside easier.so the black faces outside look good to me,they are reversed.the point is the shading on it (clear gradients)and the shading on the inside(instead of regular grey,gradients of dark) this is visible in the first pictures i posted,1 and 2 are diferent cause you can see that slight shading in 2. in 3 theres also that shading i mean but you can see that wall wich is black cause its reversed to the camera,but the shading is visible by the gradient on the surfaces:dark on facing thecamera,clear grey in the ones back to the camera. hope you understand. by loading the mesh in PPP you can see this easier too. anyway heres another pic thanks again i think this is hapening with silo meshes only but can have to do on how 3dcoat presents meshes too i dont know about it but theres some diferent shadings metods writen on the obj file and the softwares,things like phong ,flat constraint ,who knows? Share this post Link to post Share on other sites
michalis 129 Report post Posted February 18, 2011 Wrong normals, lot of non manifolds. Impossible to work on this. Its not a silos fault. You probably need walls with some thickness. Except this what I'm posting works for your needs. Some cleaning with blender. But it wont work either. Share this post Link to post Share on other sites
moska 3 Report post Posted February 19, 2011 thankx for your time Mik sorry for desagree.the normals are fine cause they are for the faces on the interior rooms. i have a separate mech for the house exterior,roof ,etc. theres no manifolds also,cause those faces are not conected to each other. so you have been inverting normals ,right?thats not what i need here. any one could just save any obj in silo and see these strange shading in 3dcoat,compared with obj from other aplications at least in mac,where i am. thanks for trying Share this post Link to post Share on other sites
michalis 129 Report post Posted February 19, 2011 So, if interior matters, where is the problem with shading? I missed something, but i really don't see a problem. As for the 3dc renderer, have in mind that a single sided surface wont cast shadows there. It doesn't work like this. Blender still shows non manifolds. And its right. One sided meshes have to be 'waterproof' to be 3dc friendly. Blender has double sided shading 'on' by default. Uncheck it and similar results to 3dc then. Share this post Link to post Share on other sites
moska 3 Report post Posted February 20, 2011 silo problem:it smoths normals,thats all. have to use other aplication to un smooth them. Share this post Link to post Share on other sites
