Member wolfiboy Posted February 18, 2011 Member Report Share Posted February 18, 2011 I reloaded a file of a detailed character I sculpted in voxel-room yesterday, but when I want to paint holes appear (see attached file). So I can't go on with sculpting!!! I installed the newest graphic-card drivers for my nvidia quadro FX580 (267.05) and installed the latest version of 3D-Coat (3.5.13A). I run it as CUDA-Version with OpenGL on a Windows 7 64 bit. Okay, the file is not so small (98 MB) but it worked fine to sculpt the object yesterday. Today is the first time I tried to load it from disk. Could somebody help me? Quote Link to comment Share on other sites More sharing options...
Member wolfiboy Posted February 18, 2011 Author Member Report Share Posted February 18, 2011 Well, I think I fixed it on my own: I started 3D-Coat, worked on an other model, saved it and opend the 'problem-file' without closing the application. And it worked! Now I split the area I want to detail into another layer, downgraded the other parts and could work again. For me it seems to be a graphic-card-driver-problem, because my screen flickers when I activate the brush and the holes appear. When I try to downgrade the model in this status 3D-Coat finally crashes. In my opinion it has to do with high-res-objects (15 000 000 triangles). And I had the impression that the application worked slower with this reloaded object then yesterday with the fresh, non-reloaded object. Never mind! But maybe somebody else had the same problem and this post could help. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted February 19, 2011 Report Share Posted February 19, 2011 This is a CUDA problem that occasionally pops up. Whenever it does I usually either restart 3DC, which usually fixes it, or under the voxel menu you can find a check box to disable CUDA. As a last resort rebooting your computer should also solve it. Quote Link to comment Share on other sites More sharing options...
Member wolfiboy Posted February 21, 2011 Author Member Report Share Posted February 21, 2011 Yes, you're right. With 'Use CUDA' unchecked it works. Thank you very much. Quote Link to comment Share on other sites More sharing options...
