Applink Developer haikalle Posted May 4, 2011 Applink Developer Report Share Posted May 4, 2011 Hi! One of the missing features would be rotate snapping. For example if I have a cube and I want to cut it half with 45 degree. Right now there is not easy way of doing it. If you could add that feature for "Paint for surrounding an irregular area" in e-panel, that would be great. with option where we can set snap angle amount. With this added I could easily cut precise cuts into my voxels. This would be realy helpful for hard surface modelling. Thanks a lot. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Polygoon Posted May 5, 2011 Advanced Member Report Share Posted May 5, 2011 +1 Yes I agree this would be a helpful feature. Quote Link to comment Share on other sites More sharing options...
Member mulciber Posted May 6, 2011 Member Report Share Posted May 6, 2011 Can't you use the cube primitive to boolean a 45 degree surface out of your voxel shape? You can rotate snap the boolean primitives to 45 degrees when holding shift while rotating it. It only snaps to 45 degree angles though as far as I know, so manually defining the rotation increments would be quite useful indeed. Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted May 6, 2011 Author Applink Developer Report Share Posted May 6, 2011 Hi! Yep that one way to do it. But even then you have to rescale the cube to cover your voxel mesh. Takes a little bit too much time when you compare it to lasso select. Quote Link to comment Share on other sites More sharing options...
Advanced Member The Candy-floss Kid Posted June 3, 2011 Advanced Member Report Share Posted June 3, 2011 +1 Quote Link to comment Share on other sites More sharing options...
