New Member monica Posted August 18, 2011 New Member Report Share Posted August 18, 2011 when i export the low poly model, from 3d coat(as an obj) and then import it in to 3dstudio max. "the normal map get placed wrong" the painted and sculped straight lines get wobbly ? how can i fix that.... ( this do not happen all the time) yes the uv map is correct both in the max model and 3dcoat model. the normal map channel is on one Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted August 18, 2011 Report Share Posted August 18, 2011 I recommend you split model on triangles. It seems that 3D-Max splits quads and n-gons in different way that 3DC and distortion occurs. I recommend you delete mesh in paint room, go to retopo, split quads/ngons and bake again. Quote Link to comment Share on other sites More sharing options...
Member Aniow Posted August 18, 2011 Member Report Share Posted August 18, 2011 The problem may be due to increased gamma correction, gamma correction settings look in 3ds Max. Quote Link to comment Share on other sites More sharing options...
