Psmith 87 Report post Posted August 22, 2011 Here it is. (Just like we advertise, in Arizona) - Another, "From Scratch" video. This one, "The Proverbial Pirate", assumes that you have gone through the first set of "From Scratch" videos. But, you probably can follow along, even if you haven't. This first installment covers only voxel sculpting - up to the point where it is wiser to move to the Paint Room to add the finishing, realistic touches - (which I am hesitant to provide, since I really don't like "CG Realism") - I'm really a cartoonist, at heart. The Proverbial Pirate Part 1 - Voxel Sculpting And now, the all new, Part 2, covering efficient use of AUTOPO and UV mapping & unwrapping: The Proverbial Pirate Part 2 - AUTOPO & UV's I hope you get something from it, Greg Smith 1 Share this post Link to post Share on other sites
Tony Nemo 393 Report post Posted August 22, 2011 Well done, Greg! Do you intend to retopo or autopo this head prior to Paint? I ask because a mouth cavity and especially the asymmetrical tweaks create some interesting problems. Share this post Link to post Share on other sites
Psmith 87 Report post Posted August 22, 2011 Tony: You had to bring that up, didn't you. Greg Share this post Link to post Share on other sites
Psmith 87 Report post Posted August 22, 2011 Tony: I'm not too worried about the mouth cavity, since I don't anticipate any kind of "Fantastic Voyage"* past the uvula and onward toward the larynx, but AUTOPO will be an interesting experiment, (I always use it). Probably, the result will need lots of adjustment and trial and error placement of guides to get an acceptable edge flow. One thing I would like to put to the test is how much n-gons and triangles really matter - even when a head like this is morphed and animated - while being seen in close-up. Let's put this urban legend to rest, once and for all. This is a big job - not one I should finish any time soon. Also, it's not my area of expertise. *"Fantastic Voyage" was a movie both Tony and I are sure to remember, (being slightly aged). It represented the pinnacle of special effects during the 1960's - lots of extreme close-ups (microscopic). Greg Share this post Link to post Share on other sites
Tony Nemo 393 Report post Posted August 22, 2011 Although not currently your "area of expertise", this project will no doubt get you a lot closer. Autopo with generous guidance may yield results perfectly useful, with edge flow and etc, for animation. Share this post Link to post Share on other sites
AbnRanger 1,479 Report post Posted August 22, 2011 Although not currently your "area of expertise", this project will no doubt get you a lot closer. Autopo with generous guidance may yield results perfectly useful, with edge flow and etc, for animation. This is why I have asked repeatedly for a DOT RING feature, similar to what is available in 3ds Max. This let's you do Polygon reduction super fast...just 2-3 clicks. This way, you can cleanup Auto Retopo results rather quickly. You can see it in action at about the 1:30 mark in the following video. Auto Retopo takes quite a bit of geometry to get a decent result, but it often leaves you with too much to use for a mesh that will be animated. So, you have decide upfront if you'll waste more time with Auto Retopo + Cleanup time or Retopo manually. A DOT RING feature can make cleanup almost a non-issue. Share this post Link to post Share on other sites
T.H. ROCK 13 Report post Posted August 24, 2011 This is why I have asked repeatedly for a DOT RING feature, similar to what is available in 3ds Max. This let's you do Polygon reduction super fast...just 2-3 clicks. This way, you can cleanup Auto Retopo results rather quickly. You can see it in action at about the 1:30 mark in the following video. Auto Retopo takes quite a bit of geometry to get a decent result, but it often leaves you with too much to use for a mesh that will be animated. So, you have decide upfront if you'll waste more time with Auto Retopo + Cleanup time or Retopo manually. A DOT RING feature can make cleanup almost a non-issue. Wow! I want that Dot Ring tool! heh Share this post Link to post Share on other sites
dfp123 0 Report post Posted October 5, 2011 Hi Greg, Thank you for the pirate tutorials. They are as stellar as the Rat from Scratch series. Are you planning to extend the series into painting and detail work? Thanks for the hard work. It is very beneficial to the community. Share this post Link to post Share on other sites
Gene 0 Report post Posted November 16, 2011 Those were very good tutorials, just wanted to say thanks! Looking forward to the next one in the series. Gene Share this post Link to post Share on other sites
