2.07 BET4
It is mainly performance update
1) Loading speed of 3DB file increased much.
2) Multiple processors support.
3) 4GB memory aceess on 64-BIT Windows and 3GB access on Win32 worth /3 in boot.ini
4) Hints style changed essentially
5) Many few issues fixed.
Testing on multicore computers is very important. I able to test only on 2-core AMD 64.
The link is below:
http://www.3d-brush.com/files/3d-brush-2-07-beta4-en.exe
I don't know if it's just the multicore optimizations, but the smooth brush is so much more responsive now. It's really nice to work with.
Just after trying 3d coat it for a few moments, it loads files faster, and runs so much more smoothly that it is like I'm using 3d coat on an upgraded machine.
PS I have dual-core @2.81 ghz, with 4gb of ram
Wow, great update. Loads really fast. I am using single CPU\core machine at home, but tommorow i'll test new 3db on intel quad core\6gb\64bit machine.
Movement of the camera with MMB+Alt appears to be disabled, however LMB+RMB+ALT works instead as per the help.
*EDIT* I restarted my computer and did the same things, and it works fine now.
wow that's good to hear, thanks Andrew!! great update. I have old dual socket P4 Xeon :D
downloading now!
EDIT: Nice! it loads twice as fast, great job Andrew!! :D You also fixed the zooming, it was abit off in beta 3! very nice.
testing it on an 8 cores...
msot operations uses 2 cores... but sometimes I can see the 8 cores running.. !
all good to me..
and the increased memory (4gb) is priceless ! :)
H.
edit... pretty unstable??? sent 3 bug reports... :huh: :huh:
all good to me..
H.
Thanks, testing on 8 cores is especially important. Now descovering your reports.
Runing Beta 4 on Intel 64bit quad core with 6gb. Starts very fast, also its looks like brushing is more smooth. 3db use 2 cores all the time.
Can you please check LWO import? I can't get anything in right now (it loads and does stuff, but no model appears). 3db files load fine though.
mike
quad opteron(2x270), 4gb ram, 6800 gt
Seems to depend on the chosen texture size. Whenever I select 4096 width or/and height), import fails.
Everytime.
mike
I set occlusion calc to 6 lights and smoothing to 22 and got a'Instability warning"
mike
occlusion will crash everytime when I increase the smootheness (last time a value of 9 was enough to crash 3dc)
mike
Occlusion pass works only on one cpu.
During painting (brush is awesome now :)) I can see 3dc taking only below 50 percent cpu time. Overall the system comes over 50%, but the actual process never exceeded 50% on my machine. What would be the most stressful task in 3dc to test processing power?
mike
