New Member papagersi Posted October 19, 2011 New Member Report Share Posted October 19, 2011 Hi!! I watched the auto-retopology video on You tube.. at the starting ,, the artist drew masking painting right? I cannot find the feature,,, How can I masking before stroking.. I wanna know that .. plz~~~help me~ Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted October 19, 2011 Moderator Report Share Posted October 19, 2011 Hi papagersi, You can paint masking (which is actually areas which will have more dense quads) right after you click OK in the first prompt window where you set amount of polys that will be on resulting mesh. Try it out! Good Luck! Quote Link to comment Share on other sites More sharing options...
New Member papagersi Posted October 19, 2011 Author New Member Report Share Posted October 19, 2011 Thanks for replying ,, but I meant about the masking .... where is it~~~ Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted October 19, 2011 Moderator Report Share Posted October 19, 2011 If you mean masking in AUTOPO process then it turns automatically after the first prompt window. If you mean masking as standalone feature, then it can be found in voxel surface tools, and is called Freeze Quote Link to comment Share on other sites More sharing options...
Contributor TimmyZDesign Posted October 21, 2011 Contributor Report Share Posted October 21, 2011 Hi papagersi, As far as I know, you cannot actually mask anything when you use the Auto-retopology function. The auto-retopology function will cover the entire voxel volume with polygons, and you cannot mask certain areas which you do not want covered. In the video on Youtube, there is no masking going on. The user is choosing areas of the voxel volume which are to have a more dense polygon mesh applied. It would be wonderful if you actually could mask parts of the voxel volume when using the auto-retopology function! That is something which should be suggested to the 3D-Coat developers in the "Feature Request" forum. -Tim Z. Quote Link to comment Share on other sites More sharing options...
