Member ArBuZ Posted November 3, 2011 Member Report Share Posted November 3, 2011 Hi! While using this command in Voxels menu I couldn't find how to specify direction of copying. For example, if I have symmetry by the X axis turned on. And I press "Symm copy". How to specify if it should copy the volume from left to right or from right to left? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted November 3, 2011 Moderator Report Share Posted November 3, 2011 Привет, Арбуз Работает это след. образом. Допустим ты что-то скульптанул на левой или правой части и теперь хочешь симметрично это скопировать. Включаешь симметрию (до этого она была выключена, разумеется) и жмешь Symm copy. Она скопирует ту часть, которая была модифицирована последней. Пробуй! Удачи! Quote Link to comment Share on other sites More sharing options...
Member ArBuZ Posted November 3, 2011 Author Member Report Share Posted November 3, 2011 Так, с ходу и не поймешь Спасибо! Разобрался! Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted November 3, 2011 Moderator Report Share Posted November 3, 2011 Так, с ходу и не поймешь Спасибо! Разобрался! Quote Link to comment Share on other sites More sharing options...
Advanced Member johnnycore Posted November 22, 2011 Advanced Member Report Share Posted November 22, 2011 I'm not sure if this is the right topic to share this, but I tought this workflow fits here.. Sometimes when I sculpt, I forget to turn symmetry on and I only have one half sculpted.. What I usually do is split the half I forgot to sculpt using the split tool and delete it. Then using the instancer tool I mirror the axis I just deleted with "put instance in subtree" turned on so I can merge down the subtree in the voxtree. Hope this tip can help anyone. Quote Link to comment Share on other sites More sharing options...
