Andrew Shpagin Posted April 1, 2008 Share Posted April 1, 2008 2.08 is released. The list of changes: 1) I have tried to make possibility to export layers as morphs. If you are exportiing LWO file morphs will be inserted into the file, if you are exporting OBJ, morphs will be stored as additional objects. To export object with morphs please press "Add morph" in export dialog. Then you should select the layer that will be used as a morph. 2) Incremental saving 3) Navigation style is slightly changed. The pivot point is a last picked point. Also you can pan using MMB without ALT. 4) Now you can import UV-set. It is important because somtimes you need to adjust UV-set slightly after you have drawn something over the object. 5) Bug with distortion of open edges of the mesh is fixed. 6) Pens, strips, masks, materials names are visible in hints. 7) Fully customable hotkeys on almost every action. Press "End" over the action item and define hotkey. Interface improvements. A list of pop-up windows is extended 9) New tool - put picture along spline 10) Sculpt mode improvements - now pen pressure can change degre of action, not only radius. Action buttons rearranged. 11) LWO import improved. Now you can import LWO files with multiple uv-sets, but no more then one per face. 12) The problem or "spikes" during import is solved. 13) You can change freeze preview type 14) Pens panel does not lags when first clicked. 15) Objects/interface thumbnails can be removed permanently 16) Eraser of the pen works correctly now. 17) the list of input formats for pens/strips extended (+psd, mclp), it allows to transfer library of pens in more easy way. 18) New mode of pen pressure reaction - decrease radius&transparency simultaneously 19) The program has trial period 15 days and 2 type of licenses - professional (120$) and educational(89$). The link is below (it will be valid for 48 hours) www.3d-coat.com/files/3d-Coat-2082-en.exe *edit: the link is updated - baking tool improved, one stability issue in UV-tool fixed. Quote Link to comment Share on other sites More sharing options...
Advanced Member SonK Posted April 2, 2008 Advanced Member Share Posted April 2, 2008 Andrew, i like the different type of freeze preview!Looking forward to the next beta. Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted April 2, 2008 Contributor Share Posted April 2, 2008 Andrew I can not get the 2.08 update to be accepted----still is 3 Beta? Brian Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 2, 2008 Author Share Posted April 2, 2008 AndrewI can not get the 2.08 update to be accepted----still is 3 Beta? Brian Why? Is there problems with downloads? 2.08 is not beta, it is release. Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted April 2, 2008 Contributor Share Posted April 2, 2008 Andrew, Other releases, and Betas, have loaded into the computer without a problem. This one does nothing to change the Beta3 to 2.08. Are you saying I have to buy 3D Coat---again? Brian Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 2, 2008 Author Share Posted April 2, 2008 Andrew,Other releases, and Betas, have loaded into the computer without a problem. This one does nothing to change the Beta3 to 2.08. Are you saying I have to buy 3D Coat---again? Brian Of cause you should not buy it again Maybe you have installed it to other folder (not overwrite) and use old link on the desktop? Quote Link to comment Share on other sites More sharing options...
Advanced Member SonK Posted April 2, 2008 Advanced Member Share Posted April 2, 2008 Of cause you should not buy it again Maybe you have installed it to other folder (not overwrite) and use old link on the desktop? lol probably, it has happen to me before. He can also remove the beta, and do a fresh install. Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted April 2, 2008 Contributor Share Posted April 2, 2008 Andrew. Unlike previously it "pretends" to overwrite but does not seem to. I will try the idea of removing the old and installing as completely new--BUT I will scream if I have to go through a re-registeration exercise--again--again! Brian Quote Link to comment Share on other sites More sharing options...
Member Reactor Posted April 2, 2008 Member Share Posted April 2, 2008 Sorry, the only screaming that's allowed around here are the screams of joy over added features Quote Link to comment Share on other sites More sharing options...
Advanced Member yukon_28 Posted April 2, 2008 Advanced Member Share Posted April 2, 2008 bwtr I installed new version over previos beta without any problem, its just overwrited old files as always, also it keeps registration, so there is no need to do it again. Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted April 2, 2008 Contributor Share Posted April 2, 2008 bwtrI installed new version over previos beta without any problem, its just overwrited old files as always, also it keeps registration, so there is no need to do it again. This is what I am still getting. (Never had on any installation of anything before?) Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 2, 2008 Author Share Posted April 2, 2008 This is what I am still getting. (Never had on any installation of anything before?) This error can occur if: 1) 3D-Coat is run and you are trying to install it. 2) You have no administrative rights on computer 3) 3DC has suspended and you can't see it in tray, but it is run. (need reboot, or CTRL+ALT+DEL -> kill process) 4) You (or some program) have set read only attribute on 3d-coat.exe 5) virus has locked access to file Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted April 2, 2008 Contributor Share Posted April 2, 2008 This error can occur if:1) 3D-Coat is run and you are trying to install it. 2) You have no administrative rights on computer 3) 3DC has suspended and you can't see it in tray, but it is run. (need reboot, or CTRL+ALT+DEL -> kill process) 4) You (or some program) have set read only attribute on 3d-coat.exe 5) virus has locked access to file Thanks Andrew. I will get my son to look at it tonight when he gets home from work. I know it's not the first one, and know of no chages that should have occured for the others. Hope it's not a virus as have about as good a security set up as available. Brian Quote Link to comment Share on other sites More sharing options...
Advanced Member JimB Posted April 3, 2008 Advanced Member Share Posted April 3, 2008 Hello Since there are now two versions of 3D Coat ,Educational and Professional can I assume that version 2.08 is the professional version,there is nothing about what version it is in the "About" box. Quote Link to comment Share on other sites More sharing options...
Member 2Mylent Posted April 3, 2008 Member Share Posted April 3, 2008 Thanks Andrew for this new release 2.08 Quote Link to comment Share on other sites More sharing options...
Advanced Member juanmanuel Posted April 4, 2008 Advanced Member Share Posted April 4, 2008 HelloSince there are now two versions of 3D Coat ,Educational and Professional can I assume that version 2.08 is the professional version,there is nothing about what version it is in the "About" box. I think the difference is in licensing, not in features. So I guess for the Educational version, you must send copies of your academic status... Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 4, 2008 Author Share Posted April 4, 2008 The difference between Educational and Full version: 1) no commercial usage 2) textures size to export is limited to 2048x2048 3) layers amout is limited to 7 It is listed on the Buy page. Quote Link to comment Share on other sites More sharing options...
Advanced Member JimB Posted April 4, 2008 Advanced Member Share Posted April 4, 2008 Ok I bought a license for 3D Brush a few weeks ago so do I have the Professional license? It is usual to find what version of software in the Help "about" box within the program. Quote Link to comment Share on other sites More sharing options...
Advanced Member yukon_28 Posted April 4, 2008 Advanced Member Share Posted April 4, 2008 Ok I bought a license for 3D Brush a few weeks ago so do I have the Professional license?It is usual to find what version of software in the Help "about" box within the program. Yes, you have a full Pro license, as anyone bought 3DC befoure Edu\Pro types of licensing where introduced. But, with that said i'd sugest Andrew to add more version\licensing\etc. info to "about" box, in general users expect to find some specific information in "about" dialog. Quote Link to comment Share on other sites More sharing options...
Advanced Member JimB Posted April 5, 2008 Advanced Member Share Posted April 5, 2008 Thanks yukon_28 Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted April 6, 2008 Contributor Share Posted April 6, 2008 Refering back to my earlier problem about installing 2.08. I had no problem with the 2.082 version! (And I note that the 2.082 file size was smaller? than the 2.08 version!!!!) Quote Link to comment Share on other sites More sharing options...
