Advanced Member vivi Posted February 25, 2012 Advanced Member Report Share Posted February 25, 2012 When I use closed curve, the first point and the last point, is kinda producing strange result. I t looks like the spline is not closed correctly... http://bit.ly/xUfu9X Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted February 26, 2012 Report Share Posted February 26, 2012 I haven't really found a way to fix this problem, whenever it occurs I usually just have to fix that little spot manually with the paintbrush. Quote Link to comment Share on other sites More sharing options...
Advanced Member vivi Posted February 27, 2012 Author Advanced Member Report Share Posted February 27, 2012 I haven't really found a way to fix this problem, whenever it occurs I usually just have to fix that little spot manually with the paintbrush. what is the problem? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted February 27, 2012 Reputable Contributor Report Share Posted February 27, 2012 Have you tried to move the last point around and uncheck the closed curve, then maybe re-check it and see if it snaps back into place like it should? The tool acts a bit odd for me too. Often times, if I finish a line and try to add another point along the line, it tries to connect the point from the end. Not what I want. It works correctly sometimes (50%). I hope Andrew can take a look at the tool and work out all the quirks. Quote Link to comment Share on other sites More sharing options...
