Free stuff & extensions
Andrew Shpagin
At risk of sounding stupid, what exactly is a matcap? I just read it's ZBrush's "material capture". But that doesn't really help in relation to 3DC. Is it just an image file? Like an HDRI spherical map? Is it something I could make myself without the use of ZB? If so, can it be tested in #DC, like just drop the file into a specific f9older?
artman, youre welcome :)
phil, yes absolutely, its in principle a chromeballshader (matcap goes a step further in capturing light information from images, however the shader itself is more or less the same). All you need to do is draw a sphere in photoshop and make sure it lines up exactly with the borders. Then you can save it as customsampler1.dds (id use the carshader as it has no cavity) in any of the custom shaders to replace the "material". Hope that helps
Thank you!
I attached zip archive to be unpacked in Shaders\Custom folder to get new shaders.
Custom.zip
With Andrew's implementation of the 'Logo' tool with volumetric sculpting, I thought it might be handy
to have a very basic proportional silhouette-type stamp with which to start roughing in characters.
Anyhow, it's proportions are around 7.5 heads tall and you just bulk it out 3-dimensionally as needed
(default is not bad, but you may want to increase in z-depth a little bit before hitting 'enter').
Dunno how useful this is, so mileage may vary.
Enjoy.
*edit* Added a female silhouette as well (slightly different hands--palms forward)
a few alphas (pens?)
I made them a long time ago and I'm not very good at those things
(file formats,resolutions ect...)
feel free to goof with them,modify them,use them in commercial or non-commercial projects
...no use to credit me.
TO USE ON 1 MILLION POLYS AT LEAST otherwise they look all the same
Happy Voxing!! :):brush:
I also have been making some pens for everybody.Will upload soon.
Thanks artman!
Hi all,
Decided to put my voxel ear in here from last night. If all goes well it will be distributed with next 3dcoat release as well so people have a voxel sculpt to play with.
ear.zip
The only thing i ask of you is that you do not use it as it is and present it as your own work in that way.
If you modify it and incorporate it into your sculpt or make a nice piece of abstract art with it its fine though, even for for commercial projects and you dont need to mention the ear was based on mine.
I hope its of use to some of you. :)
GrtZ JW
Just figured out how to make custom shaders ,so I'll post somethings for everyone to play around with. I'll post more as I make them.
Of course these will look different depending on the textures of your model.
Some of these utilize the additional shader setting options.
If you want me to modify these let me know.When I figure out how to set the bump parameters I will modify.
Put in here:C:\Program Files\3D-Coat-3-00-ALPHA59\Shaders\Custom Or where ever you installed Coat.
P.S. Quick note about bricks shader, this will not map correctly because of lack of U.V's Just use on thin walls then.
Ricks_shaders.rar
  • 3 months later...
Hi
I can't download those 4 shader sets.
is it me,or have they been removed?
There were some UI setups to by Akira wich I can't download as well.
I just tested for my color preset file and it worked here, but the shader sets above were removed.
I'm using firefox 3, maybe it's proxy problem?
  • 2 weeks later...
Hi there, I've made also some PicMats. It's metal, red plastic, green clay, blue clay and skin. The materials are created and rendered with fryrender. To make it a little bit special I surrounded the rendered scene with the 3D-Coat background gradient. You can see in the Screenshots, it looks like the Background is reflected - cause it is ;)
Preview:
Download:
klick
Edit: Files were corrupted during upload, should work now!
  • 4 weeks later...
A fun, free exercise for V3 users to start with a clean humanoid basemesh.
Install MakeHuman Alpha from here: http://code.google.com/p/makehuman/downloads/list
Run MakeHuman and get the figure the way you want it.
Export menu is currently not implemented but if you hit 'e' and go to the directory that MakeHuman in installed, you will see a file called export.obj.
Merge export.obj into your voxel room using the Merge command, scale the mesh up about to 3.5 using the little white box on the proxy object.
Click on the Increase tool to commit the object to the voxel room and sculpt away.
Note: This only worked for me with 3DC 3.0.7.
Patrick
  • 4 weeks later...
  • Carlosan changed the title to Free stuff & extensions
