    • SreckoM
      I managed to built flatpak for 3Dcoat myself and now it should work on every distro that has flatpak installed. It was made from prebuilt 2015.15 version. Did not do thorough testing but it works, both Wayland and X11.  I can share this if devs are ok with this, or can send it to Sergii.
    • TRepeat
      With stroke options like Stamp and Stamp Drag modes, you have no option to change the opacity or intensity of your brush with the Freeze tool. It also seems like Freeze exclusively uses the Alpha channels of brushes.
      Source... This project is part of my ongoing exploration into accelerating early 3D asset development by creating tools and workflows that bridge the gap between raw topology and stylized, production-ready textures. With Wireframe to Texture 360°, I wanted to push the idea even further: instead of relying on concept art inputs, the system learns directly from the 3D model’s structure and projects stylized texture logic consistently across a full 360° turnaround. ted
      Hello, try this: The Stroke panel, specifies the way that your stroke behaves over the surface from mouse click to mouse release.
    • TRepeat
      Using the Freeze surface brush in either Voxel or Surface sculpting, is it possible to control the strength of the freeze with brush opacity, or is there any kind of depth option for freeze?  I often use the freeze brush to paint selections onto a mesh before using the Pose tool to extrude or pull details into the surface. Using Freeze allows me to use the brushes/brush alphas to get interesting effects.
    • HerbalTea
      I just tested all my programs with my 3d mouse including 3dcoat and it all works suddenly?  Last night though, 3dcoat kept losing my 3d mouse and just zooming out and being non responsive, I restarted lots of times my pc and 3dcoat and cleared temp dir...  this just black box magic sometimes it works and sometimes it doesn't? :/   Thanks though, I downloaded 3d connexion driver v10-9-3_b671.exe,  but now that it works with the latest driver v10.9.8.715 (right now anyways) I will hold off on trying to downgrade.
    • HerbalTea
      So, downgrading the 3d mouse driver makes your 3d mouse work with 3dcoat? I don't really want to downgrade my drivers I do more than just use 3d coat and then it might screw up another program. Do you use Blender/UE5/Rhino/Cascadeur/Poser/SubstancePainter with the downgraded 3d connexion driver and they all work along with 3dcoat?
    • MikeyJay
      I'm completely new to 3DCoat, and I just started messing around with the sculpting brushes. After some experimenting, I tried right-clicking on a brush and selecting "Restore Default" to switch it back to default settings, but it didn't work until I restarted the program. Is there a way around this? It's not the end of the world, but it would be nice to avoid if possible. Thanks!
    • AbnRanger
      I cannot use recent builds of 3DConnexion software and 3DCoat, either. It behaves very strangely, practically buggy and that has never been the case, until this year. It turns out that 3Dconnexion made some major changes to it's API/Drivers and it requires Pilgway developers to have to spend valuable time trying to fix what is broken on their side. I have to use an older driver (10.9.3.671) until Andrew (Co-Owner & Chief Developer) is able to investigate it. He is only working on 3DCoat development part time, now, due to the Russian invasion of Ukraine. Other developers are still working full time developing the tools they are tasked with, but Andrew is the only one who can truly bugfix and deal with core applications issues like this. I reported this problem before, but I guess it was not high enough of a priority compared to some other issues and the Blender Applink.
    • HerbalTea
      sometimes it works usually it eventually doesn't... In a blank project it works but after adding some poly model it just doesn't work. It's always been buggy in 3d coat but now it is unusable. I'm on the latest 2025.15 3d coat,  I have the 3d connexion big one, the space mouse enterprise?  Can I add videos to here? Yet my 3d mouse works perfectly in: Rhino8, Blender 4.5, Substance Painter 11? (steam.. latest version)(although it sometimes has problems too, but not as bad as 3d coat), Cascadeur (latest), Unreal 5, ... and a couple more.. I love my 3d mouse and it works great with most of all my others programs except Marmoset Toolbag 5... and it takes me out of my flow when then I open 3d coat and I spend a half hour trying ...and failing to get it to work. :/   Is this a known issue is 3d coat programmer trying to fix this?   Ok, well after fiddling it seems that 3d coat has an issue with my tablet... I use a display tablet and a 3d mouse at the same time, and I have a trackball, shuttle pro v2 and 2 streamdecks (XL and mk2), probably not a normal setup...but other 3d programs can handle it. 3d coat seems to get confused when I use my pen (display tablet ) and 3d mouse together?
    • animk
      I downloaded the latest Linux version 2025.15, the performance is a lot better than the previous 2025.01.  I can go back to linux version now.
    • Britain
      Nope. Dont use the app that much, import - export works for me. Andrew should sell it on Superhive or Gumroad for anyone that may requires it for other 3dcoat versions.
