mifth Posted April 5, 2016 Posted April 5, 2016 This post was recognized by Carlosan! mifth was awarded the badge 'Great Content' and 1 points. Hi. I did 3DCoat-Houdini Applinker asset. It's possible to export-import meshes and export textures from 3DCoat. Very useful for modeling and texturing artists. It's going to be at Orbolt soon. - Set the Exchange folder before exporting/importing. On linux it's at 'home/user/3DCoatVersion/Exchange'. On Windows it's somewhere at user documents. 3DCoat creates such a folder itself. - Tested on Linux. If you have any issues on Windows then write me here. Video test of export/import of meshes and textures: https://youtu.be/4WVgfgugZ5M Houdini thread: https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=43886&start=0&postdays=0&postorder=asc&highlight= 4 Quote
mifth Posted April 5, 2016 Author Posted April 5, 2016 This post was recognized by Carlosan! mifth was awarded the badge 'Great Content' and 1 points. And! The asset is now at Orbolt! http://www.orbolt.com/asset/mifth::mifth_3dcoat_applinker Enjoy and test it! 1 1 Quote
Advanced Member paulrus Posted June 8, 2016 Advanced Member Posted June 8, 2016 I'm testing out Houdini as a Softimage replacement & having a 3DCoat applink is really helpful to me. I don't know a lot about Houdini so forgive me if I'm missing something obvious, but.... In 3DC when I choose Open in Original App, then click Import on the applinker, I get a new FBX object with all my changes made. The problem I see is, the object is living inside the 3DC Exchange folder as a reference object. How do I bring it into my project so it's part of the project & not an external reference? Thanks, Paul Quote
mifth Posted June 9, 2016 Author Posted June 9, 2016 It's not an external reference. You can use the new subnet as a common imported fbx. All its sop nodes are locked. 1 Quote
Advanced Member paulrus Posted June 9, 2016 Advanced Member Posted June 9, 2016 Sorry, but I literally just started trying out Houdini and I haven't yet gotten an understanding of what all the VOP, SOP, COP, FLIPPITY-FLOP, DOOWOPSHEBOP stuff is all about. What I see is not a new object/geometry, I see a node that has a referenced path and filename as it's name - the filename is the path to my Exchange folder and the object is being loaded dynamically. I know this is the case because I tried creating a scene on one machine that uses this applink, then loading it on another machine - all objects that were created internally in Houdini loaded fine, but the applink object was missing because it couldn't find the Exchange folder where the modified object lived. I'll attach an image of what I'm talking about. Quote
New Member matthias.kappenberg Posted July 26, 2016 New Member Posted July 26, 2016 This post was recognized by Carlosan! matthias.kappenberg was awarded the badge 'Helpful' and 1 points. Hi Paulrus, you have many options if you like to transfer your stuff to another machine. The simplest one is: check the "lock" icon, if you have the desired model imported on your base machine. Then the FBX is locked and the actual geometry will be embedded in the Houdini file. But beware of the dog: Never save it then, with unlocking the Geometry... Mainly used if you like to transfer a simple Houdini file with some demo geometry. Another option, which is usually better, is to have your files organized in a "project", which should have subfolders for the different needed files like textures, models, .... like: YourProjectFolder <--- base folder YourProjectFolder/Models <--- your models YourProjectFolder/Textures <--- your textures .... then save your Houdini file in YourProjectFolder/TheFile.hip and the FBX in YourProjectFolder/Models/export.fbx now you can use variables like "$HIP" , see here: http://www.sidefx.com/docs/houdini13.0/expressions/_globals and set a variable path to the model like: $HIP/ Models/export.fbx or use shared path, which are accessible in the network and use them, optional with the above variable to have all your stuff in sync. Hope that was helpy. @ .. VOP, SOP, COP, FLIPPITY-FLOP, DOOWOPSHEBOP ... Have a closer look at the manual... simply think of it like: stay organized (ok, it's much more...) SOP -> SurfaceOPerator -> all Geometry related stuff COP -> CompositingOPerator -> all Image manipulation ...... DOOWOPSHEBOP -> my favorit -> the Paulrus playground, I'm curios what's growing up there? Quote
New Member matthias.kappenberg Posted July 26, 2016 New Member Posted July 26, 2016 Forgotten to say: Really big thanks for the "3DCoat-Houdini Applinker", simply cool Quote
mifth Posted July 27, 2016 Author Posted July 27, 2016 Thanks a lot. I'm gland that the asset is useful. Quote
Member Barracuda Posted April 11, 2018 Member Posted April 11, 2018 Hello, first of all thanks a lot for the applinker, the workflow described here is if you start from Houdini export load in 3dc, what if I am starting in 3dc and want to export first from there, Should I just export using the Houdini Mantra surface preset?, and would you happen to know if that would work with redshift?. and when baking I cant find any Houdini preset for normals, which one of the existing ones would work? and then should I export this to the exchange folder or can I just pick any folder and then point the Houdini app link to it? Thanks a lot for your time Ahmed Barakat Quote
Moderator AbnRanger Posted April 11, 2018 Moderator Posted April 11, 2018 13 hours ago, Barracuda said: Hello, first of all thanks a lot for the applinker, the workflow described here is if you start from Houdini export load in 3dc, what if I am starting in 3dc and want to export first from there, Should I just export using the Houdini Mantra surface preset?, and would you happen to know if that would work with redshift?. and when baking I cant find any Houdini preset for normals, which one of the existing ones would work? and then should I export this to the exchange folder or can I just pick any folder and then point the Houdini app link to it? Thanks a lot for your time Ahmed Barakat Yeah, that's how some of the Applinks work. They assume the user wants to bring an asset from their main 3D application, into 3D Coat first, rather than originating in 3D Coat. Wish that would change. Quote
Member vertigo262 Posted May 3, 2018 Member Posted May 3, 2018 Hi, I have never used the Applink before. While trying it out today on Houdini 16.5.439 I get this error Also, on the download section the Youtube link no longer exists I checked all the folder perms and even made a simple folder in a new directory. That does not seem to be the problem Quote
Member RandyBonnette Posted August 28, 2019 Member Posted August 28, 2019 On 7/27/2016 at 12:30 AM, matthias.kappenberg said: Hi Paulrus, you have many options if you like to transfer your stuff to another machine. The simplest one is: check the "lock" icon, if you have the desired model imported on your base machine. Then the FBX is locked and the actual geometry will be embedded in the Houdini file. But beware of the dog: Never save it then, with unlocking the Geometry... Mainly used if you like to transfer a simple Houdini file with some demo geometry. Another option, which is usually better, is to have your files organized in a "project", which should have subfolders for the different needed files like textures, models, .... like: YourProjectFolder <--- base folder YourProjectFolder/Models <--- your models YourProjectFolder/Textures <--- your textures .... then save your Houdini file in YourProjectFolder/TheFile.hip and the FBX in YourProjectFolder/Models/export.fbx now you can use variables like "$HIP" , see here: http://www.sidefx.com/docs/houdini13.0/expressions/_globals/essaydune and set a variable path to the model like: $HIP/ Models/export.fbx or use shared path, which are accessible in the network and use them, optional with the above variable to have all your stuff in sync. Hope that was helpy. @ .. VOP, SOP, COP, FLIPPITY-FLOP, DOOWOPSHEBOP ... Have a closer look at the manual... simply think of it like: stay organized (ok, it's much more...) SOP -> SurfaceOPerator -> all Geometry related stuff COP -> CompositingOPerator -> all Image manipulation ...... DOOWOPSHEBOP -> my favorit -> the Paulrus playground, I'm curios what's growing up there? Hi there, Is it possible to define a new location to store files? The $HIP variable in Houdini actually defaults to the C:/users/username folder whenever I start Houdini. I'm working on a project and need to configure $HIP and a project directory. I asked the same on sidefx forum, but there's no reply yet. Quote
mifth Posted August 28, 2019 Author Posted August 28, 2019 Hi. You can set a project. Then you can use $JOB variable. https://www.sidefx.com/docs/houdini/basics/project.html 1 Quote
Advanced Member jacobo Posted September 20, 2019 Advanced Member Posted September 20, 2019 (edited) Thank you so much for your efforts, yet I just don't get why on earth Pilgway does not develop it's own applinks and rely on third party efforts. Yes, generous people like yourself do a fantastic job, yet I need to ask; don't users of 3DC deserve up-to-date official applinks???? Edited September 20, 2019 by jacobo Quote
mifth Posted September 20, 2019 Author Posted September 20, 2019 Hello. Thank you. All works fine at my side. I have such setup. 2 1 Quote
