v2024.22 add a new option “Edit->Prefs->Tools->Don’t group vertices per objects in OBJ files (like ZB)” for better compatibility when you need to keep the vertex order in OBJ files.
Anyway, Coat preserved vertices order, but in some case it is not enough, and vertices should not be grouped. In this case you need his option.
For texture Per Pixel Painting
On DAZ you need to export G3 figures or G8 figures without eyelashes.
Preserve uDim tiles
In the Splash screen you want to choose Paint Per Pixel or Choose File > Import > Model for Per Pixel Painting.
So import the Daz figure turning on Import Tiles as UVset.
with the model objects zones
For Genesis 2 models
For Genesis2 models there’s an option in your DAZ obj export dialogue to collapse the UVs, which is an alternative to previous suggestion.
It would also give you a collapsed set of UVs to import into Genesis within DAZ Studio, provided you export the base mesh -without SubDiv-
2. and high resolution mesh.
Creating Morph Targets
As is show on this picture.
You can also use this other method. This video covers the updated process of creating Morph Targets or Blend Shapes in 3DCoat, with the purpose of exporting to a major 3D Animation application.
 Ελληνικά  English
 English Українська
 Українська Español
 Español Deutsch
 Deutsch Français
 Français 日本語
 日本語 Русский
 Русский 한국어
 한국어 Polski
 Polski 中文 (中国)
 中文 (中国) Português
 Português Italiano
 Italiano Suomi
 Suomi Svenska
 Svenska 中文 (台灣)
 中文 (台灣) Dansk
 Dansk Slovenčina
 Slovenčina Türkçe
 Türkçe Nederlands
 Nederlands Magyar
 Magyar ไทย
 ไทย हिन्दी
 हिन्दी Tiếng Việt
 Tiếng Việt Lietuviškai
 Lietuviškai Latviešu valoda
 Latviešu valoda Eesti
 Eesti Čeština
 Čeština Română
 Română Norsk Bokmål
