Showing results for tags 'macbook pro 2017'.
    • Basics & Interface
    • Questions & Answers
  1. I have a new MacBook Pro 2017 (meets system specifications and running Sierra OS), but 3D Coat version 4.7.23 keeps crashing at startup. I installed version 4.5.xxx but these either crashed, froze, or gave me red-screens. What do I do? I already purchased a license. Thanks for any help! Andrew copy/pasted my error crash log here on Sierra OS, 3D Coat version 4.7.23 -- Loading Xml file "Xmls/Settings.xml"... Can't load file "Xmls/Settings.xml" ------------------------------------------------------------ OpenGL | Version: 4.1 ATI-1.51.8 OpenGL | Vendor: ATI Technologies Inc. OpenGL | Renderer: AMD Radeon R9 M295X OpenGL Engine OpenGL | Supported features: OpenGL | Multitexture (fragment shader units: 16) OpenGL | Anisotropic filtering (level: 16) OpenGL | Texture Compression DXT OpenGL | Vertex Array Object OpenGL | Vertex Buffer Object OpenGL | Vertex Attributes (count: 16) OpenGL | Vertex Uniform Vectors (count: 1024) OpenGL | OpenGL Shading Language OpenGL | Frame Buffer Object (max size: 16384 X 16384) OpenGL | MRT (targets: OpenGL | Extensions (46) : GL_ARB_blend_func_extended GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader5 GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_occlusion_query2 GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_subroutine GL_ARB_shading_language_include GL_ARB_tessellation_shader GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_texture_storage GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_vertex_attrib_64bit GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_texture_compression_s3tc GL_EXT_texture_filter_anisotropic GL_EXT_texture_mirror_clamp GL_EXT_texture_sRGB_decode GL_APPLE_client_storage GL_APPLE_container_object_shareable GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_texture_range GL_ATI_texture_mirror_once GL_NV_texture_barrier ------------------------------------------------------------ Registering vertex formats... 3Dconnexion framework found cMeshIO::AddCodec(): Added "Obj" mesh codec. cMeshIO::AddCodec(): Added "Lwo" mesh codec. cMeshIO::AddCodec(): Added "Fbx" mesh codec. cMeshIO::AddCodec(): Added "Stl" mesh codec. cMeshIO::AddCodec(): Added "Ply" mesh codec. cMeshIO::AddCodec(): Added "dae" mesh codec. cMeshIO::AddCodec(): Added "wrl" mesh codec. cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Sphere.obj". cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Ring.obj". cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Cube.obj". cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Sector.obj". cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Cone.obj". cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Cylinder.obj". cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets/icosa240.obj". Added "TIF" image codec. Added "TIFF" image codec. Added "EXR" image codec. Added "HDR" image codec. - Loading font "Calibri 11"... Can't load file "Fonts/Calibri 11.cFont" - Loading font "Calibri 16"... Can't load file "Fonts/Calibri 16.cFont" - Loading font "Calibri B24"... Can't load file "Fonts/Calibri B24.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma B8"... Can't load file "Fonts/Tahoma B8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" Can't load image file "Textures/WindowsStandard/ToolBar.bmp" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" Version : 3D-COAT 4.7.23(GL64) Can't load file "Shaders/hud2t.glsl" Can't load file "Shaders/Low/hud2t.glsl" Can't load file "Shaders/VeryLow/hud2t.glsl" Can't load file "Shaders/hud_smooth.glsl" Can't load file "Shaders/Low/hud_smooth.glsl" Can't load file "Shaders/VeryLow/hud_smooth.glsl" Can't load file "Shaders/hud.glsl" Can't load file "Shaders/Low/hud.glsl" Can't load file "Shaders/VeryLow/hud.glsl" Can't load file "Shaders/LinesPointsUI.glsl" Can't load file "Shaders/Low/LinesPointsUI.glsl" Can't load file "Shaders/VeryLow/LinesPointsUI.glsl" Can't load file "Shaders/Colored.glsl" Can't load file "Shaders/Low/Colored.glsl" Can't load file "Shaders/VeryLow/Colored.glsl" Can't load file "Shaders/RenderSystem.glsl" Can't load file "Shaders/Low/RenderSystem.glsl" Can't load file "Shaders/VeryLow/RenderSystem.glsl" Can't load file "Shaders/RenderSystem.glsl" Can't load file "Shaders/Low/RenderSystem.glsl" Can't load file "Shaders/VeryLow/RenderSystem.glsl" Can't load file "Shaders/text2.glsl" Can't load file "Shaders/Low/text2.glsl" Can't load file "Shaders/VeryLow/text2.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_render_color.glsl" Can't load file "Shaders/Low/obj_render_color.glsl" Can't load file "Shaders/VeryLow/obj_render_color.glsl" Can't load file "Shaders/obj_render_normals.glsl" Can't load file "Shaders/Low/obj_render_normals.glsl" Can't load file "Shaders/VeryLow/obj_render_normals.glsl" Can't load file "Shaders/obj_render_mrt.glsl" Can't load file "Shaders/Low/obj_render_mrt.glsl" Can't load file "Shaders/VeryLow/obj_render_mrt.glsl" Can't load file "Shaders/tex_preview.glsl" Can't load file "Shaders/Low/tex_preview.glsl" Can't load file "Shaders/VeryLow/tex_preview.glsl" Can't load file "Shaders/tex_preview_nrm.glsl" Can't load file "Shaders/Low/tex_preview_nrm.glsl" Can't load file "Shaders/VeryLow/tex_preview_nrm.glsl" Can't load file "Shaders/tex_preview_alpha.glsl" Can't load file "Shaders/Low/tex_preview_alpha.glsl" Can't load file "Shaders/VeryLow/tex_preview_alpha.glsl" Can't load file "Shaders/tex_preview_all.glsl" Can't load file "Shaders/Low/tex_preview_all.glsl" Can't load file "Shaders/VeryLow/tex_preview_all.glsl" Can't load file "Shaders/obj_preview_pen2.glsl" Can't load file "Shaders/Low/obj_preview_pen2.glsl" Can't load file "Shaders/VeryLow/obj_preview_pen2.glsl" Can't load file "Shaders/inrect.glsl" Can't load file "Shaders/Low/inrect.glsl" Can't load file "Shaders/VeryLow/inrect.glsl" Can't load file "Shaders/obj_preview_pen2.glsl" Can't load file "Shaders/Low/obj_preview_pen2.glsl" Can't load file "Shaders/VeryLow/obj_preview_pen2.glsl" Can't load file "Shaders/preview_rect.glsl" Can't load file "Shaders/Low/preview_rect.glsl" Can't load file "Shaders/VeryLow/preview_rect.glsl" Can't load file "Shaders/draw_pic_over_curve.glsl" Can't load file "Shaders/Low/draw_pic_over_curve.glsl" Can't load file "Shaders/VeryLow/draw_pic_over_curve.glsl" Can't load file "Shaders/draw_pic_over_curve.glsl" Can't load file "Shaders/Low/draw_pic_over_curve.glsl" Can't load file "Shaders/VeryLow/draw_pic_over_curve.glsl" Can't load file "Shaders/preview_fill.glsl" Can't load file "Shaders/Low/preview_fill.glsl" Can't load file "Shaders/VeryLow/preview_fill.glsl" Can't load file "Shaders/uv.glsl" Can't load file "Shaders/Low/uv.glsl" Can't load file "Shaders/VeryLow/uv.glsl" Can't load file "Shaders/wires.glsl" Can't load file "Shaders/Low/wires.glsl" Can't load file "Shaders/VeryLow/wires.glsl" Can't load file "Shaders/wires.glsl" Can't load file "Shaders/Low/wires.glsl" Can't load file "Shaders/VeryLow/wires.glsl" Can't load file "Shaders/sphere.glsl" Can't load file "Shaders/Low/sphere.glsl" Can't load file "Shaders/VeryLow/sphere.glsl" Can't load file "Shaders/obj_preview_pen.glsl" Can't load file "Shaders/Low/obj_preview_pen.glsl" Can't load file "Shaders/VeryLow/obj_preview_pen.glsl" Can't load file "Shaders/CurrentMcubes/mcubes.glsl" Can't load file "Shaders/Low/CurrentMcubes/mcubes.glsl" Can't load file "Shaders/VeryLow/CurrentMcubes/mcubes.glsl" Can't load file "Shaders/sphere.glsl" Can't load file "Shaders/Low/sphere.glsl" Can't load file "Shaders/VeryLow/sphere.glsl" Can't load file "Shaders/mpreview.glsl" Can't load file "Shaders/Low/mpreview.glsl" Can't load file "Shaders/VeryLow/mpreview.glsl" Can't load file "Shaders/mpreview1.glsl" Can't load file "Shaders/Low/mpreview1.glsl" Can't load file "Shaders/VeryLow/mpreview1.glsl" Can't load file "Shaders/Font.glsl" Can't load file "Shaders/Low/Font.glsl" Can't load file "Shaders/VeryLow/Font.glsl" Can't load file "Shaders/mcubes_rt.glsl" Can't load file "Shaders/Low/mcubes_rt.glsl" Can't load file "Shaders/VeryLow/mcubes_rt.glsl" Can't load file "Shaders/mcubes_nrm.glsl" Can't load file "Shaders/Low/mcubes_nrm.glsl" Can't load file "Shaders/VeryLow/mcubes_nrm.glsl" AppLink search path registered: /Users/Andrew1/AppLinks/3D-Coat/Exchange/ AppLink search path registered: /Users/Andrew1/3D-CoatV4/Exchange/ AppLink search path registered: /Users/Andrew1/3D-CoatV3/Exchange/ AppLink search path registered: /Users/Andrew1/3D-CoatV47/Exchange/ Can't load file "Shaders/LinesPointsUI.glsl" Can't load file "Shaders/Low/LinesPointsUI.glsl" Can't load file "Shaders/VeryLow/LinesPointsUI.glsl" Can't load file "Shaders/Colored.glsl" Can't load file "Shaders/Low/Colored.glsl" Can't load file "Shaders/VeryLow/Colored.glsl" Can't load file "Shaders/RenderSystem.glsl" Can't load file "Shaders/Low/RenderSystem.glsl" Can't load file "Shaders/VeryLow/RenderSystem.glsl" Can't load file "Shaders/RenderSystem.glsl" Can't load file "Shaders/Low/RenderSystem.glsl" Can't load file "Shaders/VeryLow/RenderSystem.glsl" Can't load image file "Levels/Uv/Uv_d" Crash occured. Trying to save object...
