Member maya69 Posted May 8, 2009 Member Report Share Posted May 8, 2009 hello, i use 3d coat alpha 82 without cuda when i import dp paint model (4 object with uv ) and i use 4096 size for texture 3d coat use 5 go of my ram memory if i import normal mode for my model 3d coat use 1 go why the difference ? Can you think issue of memory usage for dp paint ? I work for architecture and direct paint is great solution but usage memory is really big probleme May be if anyone can explain the probleme thank best regard philippe Quote Link to comment Share on other sites More sharing options...
