    • Mihu83
      Hey, can we finally have fixes for couple of issues: 1. Curves tool - it doesn't stay in selected mode(Q, W, R, E). In previous versions of 3DC I have kept this tool in Move mode(W), but now it switches to default every time. 2. Cut off tool - switching from this tool to any other tool is keeping stroke mode from cut off tool. 3. Switching between subtools changes the tools/brushes between those subtools - really annoying behaviour. If I select specific tool, use it on one subtool, then I usually want to use it on another object, so 3DC switching tool on its own isn't very good behaviour. 4. Duplicating objects - when I try to duplicate object multiple times with hotkey(CTRL+J), I need to hit that hotkey twice, because first time doesn't do a thing(after first duplicate) and the gizmo jumps to the center of the original object every time.
    • Britain
      Yeah. You need to know one or another well. One can make good money if your a good engineer and know CAD. Know a someone who works out of this Motor home while cruising about. I spent much of my first 20 years working off shore and it helped to know drawings, machining and CAD. Dont know many people that do well in the polygon modeling. Used to be a customer here Bay Riatt 3d artist seems like he cut out a good living doing this.
    • wendallhitherd
      love that bit of CAD lore I see something like cadquader having a lot of utility outside of engineering: at least for me, all current triangulation methods for CAD result in sliver triangles and n-gon boundaries between patches, having a mesher that tries to resolve these boundary seams saves me a TON of work. Recently I tried to make an X-ray machine in plasticity for a game mesh, and while it was fun and easy to make the high poly, making the game res mesh was an absolute nightmare: you have to painstakingly go over every single chamfer, bevel, and surface patch intersection and repair ngons / zipper seams / floating vertices etc so that you can do things like apply bevels. It's prohibitively expensive time wise to use CAD for game res meshes unless you are a weapons artist and can spend several days repairing the lowpoly output, or doing a retopo - I reckon for every 1 day you spend making the highpoly in CAD you spend 2 day repairing the lowpoly mesh for production. IT's pretty awful without a tool like cadquader  something like CADQuader makes using tools like plasticity viable within time constraints. Or if they eventually roll it into Coat, even better for faster, less painful work!
    • Britain
      In the 90's the Japanese were using Catia a lot. Mostly or the old crt tv and computer monitor cases. Its was the best for surface modeling. The US was using Solidworks. Solidworks at the time wasnt very good for surfacing. But the  .step files could be read  between the software we could send files back and forth. Took a bit of work still if you only had SW for the CAM side interrupting the Catia files.  Moving forward both softwares lacked good texturing. In the early 2000's, for me I started exporting to .obj so I could have a more realistic model for the CAPEX approval. So lol Ive been dealing with cleaning up manually those .obj files. But today most of the commercial CAD has good texturing built in. For the hobbiest the CADQuader will be a good deal. I dont see it moving into the commercial market at this point. That market is hard to break into.
    • Britain
      I think also a sizing issue perhaps and some non attached geometry. Problem with  plasticity is other cad programs have issues reading the step files. Lot of people are using it on hobbiest side for blender.
      Also offer sale through our Discord channels
    • wendallhitherd
      Thank you! Misread the number of zeroes on the fsize 😅, Definitely a bad stp / plasticity source file issue. Sorry if it seems unrelated, but I am not really advanced enough with CAD to know how to debug well, any idea why there are thousands of surfaces here? Was there some crazy degenerate / near zero area sheets created by a bad chamfer or some other operation? I understand how to avoid creating bad geometry with polygons but still not sure about bad practices with cad
    • macmonkey
      Re No selectable menu items. When the app loads, it loads in full screen mode and the menu items aren't selectable but when i drag the screen out of fullscreen mode the menus work. I recorded a video but the the strange thing is the menus are showing in the video playback - I swear to to you though that on my screen when the app is in full screen mode the menus aren't showing. i hope that helps?!   CAD Quader.mp4
    • Gorbatovsky
      CADQuader 2026.17 is available Download: cadquader.com This update adds symmetry to Low Poly and fixes the meshing issues reported with the Plasticity STEP example. Symmetry: X, Y or Z, through the body center or a specified coordinate. CADQuader checks the geometry before meshing and reports an error if the selected symmetry plane does not fit the part. Faster fallback meshing, including fixes for the 12 missing faces. All 4,450 CAD faces in the test model now build without invalid cells. TrimmingFace (legacy): fixed folded cells on conical transitions and gaps at circular joints. The scope housing now builds all 323 faces while preserving the regular quad rows on the main panels. Object tree: Shift range selection, visibility control for selected objects, and Shift-click on the eye to isolate one object. Project settings: Low Poly mode, density and Collar settings are now saved and restored. Please install 2026.17 and rebuild existing meshes to apply the fixes. The installer is digitally signed by PILGWAY LLC. Thank you for the models and detailed reports!
    • Torotoro
      I'm selling my 3DCoat permanent license for $200 USD. Download access up to version 2023.25 Permanent license License transfer to the buyer Payment via PayPal Please contact me if you're interested.
    • Gorbatovsky
    • wendallhitherd
      ayy really cool! Sorry about the slowness. I have no idea why that file is 80mb, probably something super weird going on. I'll try fixin on my end
    • erisan
      I don't know if this applies to linux but on macOS 3DC 2026 version, there is a doc_folder.txt that sets the folder where the exchange happens to on 3DC side at least, I think...
    • Britain
      Wow Imported 6 takes for ever to quad nearly 500 sec. I did a quick copy and havent  finished it yet. Mine was nearly 1 sec to quad. Ill put in the rest of the details later ( Chamfers and other insets.) I dont think it will add to much more time.
    • wendallhitherd
      2025-08-11_scope_2.stp here is an stp file. I have no idea why it is almost 90mb, the plasticity file is kb bi2025-08-11_scope_2.plasticity this scope was done as part of a tutorial I followed but feel free to use it for whatever testing purposes
    • wendallhitherd
      I can provide some of my personal STL files from plasticity messing around later some of them, especially those with fillets, triangulate horribly in plasticity so it will be cool to know I can feel confident I am not ruining my life working in CAD if I have to get a quadmesh out of it Plasticity also has the problem working with voxels has where it is extremely fun to work in but ruins your life later on when you have to make a subdivision mesh from it so really happy to see people tackling the problem
    • Gorbatovsky
      Thanks for testing it again — glad to hear it’s much better!
    • Gorbatovsky
      CADQuader 2026.16 is now available, with fixes based on your feedback and test models: Mesh Quadro is now enabled by default in Low Poly. The selected mode is remembered for each object when saving and reopening a project. Much faster object rotation, including quick 90° turns. Rotating an object no longer rebuilds its entire mesh. Fixed corrupted symbols in rotation dialogs, menus and other interface labels, including degree signs, minus signs and arrows. Restored missing vertical toolbar commands in command search and hotkey settings, including Copy, Mirror, Move Point to Point and Point-to-Point Dimension. Simplified the Import dialog to three file types: CADQuader Project (.quader, .dom3d), STEP and IGES. Fixed four corner gaps in the mesh of the reported AAA model with stepped spherical cuts. Fixed the DivideFace issue on a hemisphere. The resulting mesh remains closed and fully quad-based, including when switching meshing modes. All 27 targeted regression checks passed. Download the signed installer from cadquader.com, or update directly through Help → Update. Please rebuild existing meshes after updating to apply the meshing fixes. Thanks to everyone who reported these issues and shared example files!
    • Britain
      Much better. If possible 1 Quads holding to an equal square on curved surfaces 2 Less quads that are trapezoid looking. 3 No tri's 4 If part is symmetrical have the ability to quad one side of the axis and then mirror that to the other side. This works well using Quad remesher (paid) and  Qremeshify (free Blender). Keep up the good work!
    • webmaster
      Sculpting a Bed in 3DCoat #3DCoat #3DModeling #3DSculpting #GameArtView the full article
