Who's Online 0 Members, 0 Anonymous, 257 Guests (See full list)
- 19 views
- 19 views
- 100 views
- 89 views
- 100 views
- 130 views
- 97 views
Posts
By Carlosan · Posted
Yes, as you said the only relation between RS and 3DC was importing a mesh into 3DC and do normal sculpting pass. RealityScan and Colmap are used as engines as 3D reconstruction based on images and video. PointCloud import only support .las file format. At current stage of development it is not as effective as solution found on other apps. To create a 3D model from a point cloud in 3DCoat, you will first need to use another application to generate the mesh from the point cloud. You can use Meshlab to convert the pointcloud .ply format to a 3d tin model. -
By Kayess · Posted
ok - so we hope for a fix in next version of 3DC, I guess? I think I saw a 2026 beta around... fingers crossed ! -
By Elemeno · Posted
realityscan hasnt worked for a while inside 3dcoat , i have to use the actual software outside of 3dcoat -
By Kayess · Posted
nope... RealityScan works on it´s own, yeah - but the tools (in 3DC) do not seem to do anything, besides giving me this msg when importing a ply. I also follwed along the video series you linked, interesting stuff. But the only relation between RS and 3DC was importting a mesh (I think it was fbx) into 3DC and just do normal sculpting pass. I thought with the photogrammetry tool we could calculate the mesh via RS API and get this directly into 3DC or something like a bridge to push the mesh over from one app to the other back´n forth. Or even drag in images into 3DC and under the hood, RS does the math or something like this... but... no -
By erisan · Posted
By Kayess · Posted
By Kayess · Posted
By Kayess · Posted
By Kayess · Posted
By Kayess · Posted
By erisan · Posted
Crash occurs just after pressing Choose Texture in Smart Material editor at 0:40 (I stopped recording prior to the crash). So another crash while randomly following a page in the docs. All these crashes on macOS makes erodes my confidence and interest in 3dcoat and I wonder if anyone uses it professionally on mac? Perhaps you should stop selling 3DC for macOS. I cannot understand how anyone can put up with such unstable software on macOS. ------------------------------------- Translated Report (Full Report Below) ------------------------------------- Process: 3DCoat [24617] Path: /Applications/3DCoat-2026.01/3DCoat.app/Contents/MacOS/3DCoat Identifier: com.Pilgway.-DCoat Version: 2026.01 (1) Code Type: ARM-64 (Native) Parent Process: launchd [1] User ID: 501 Date/Time: 2026-04-29 00:44:52.3086 +0200 OS Version: macOS 15.7.5 (24G624) Report Version: 12 Anonymous UUID: F9229ABC-4732-A1D8-BEB3-C9B32A468FA6 Sleep/Wake UUID: 97B0F65B-0D68-4C5D-A6D8-0342E11878C4 Time Awake Since Boot: 1600000 seconds Time Since Wake: 8049 seconds System Integrity Protection: enabled Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_PROTECTION_FAILURE at 0x000000016f50fff8 Exception Codes: 0x0000000000000002, 0x000000016f50fff8 Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11 Terminating Process: exc handler [24617] VM Region Info: 0x16f50fff8 is in 0x16bd0c000-0x16f510000; bytes after start: 58736632 bytes before end: 7 REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL MALLOC_TINY 16bc00000-16bd00000 [ 1024K] rw-/rwx SM=PRV GAP OF 0xc000 BYTES ---> STACK GUARD 16bd0c000-16f510000 [ 56.0M] ---/rwx SM=NUL stack guard for thread 0 Stack 16f510000-16fd0c000 [ 8176K] rw-/rwx SM=SHM thread 0 Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 libsystem_pthread.dylib 0x18c42ebc0 ___chkstk_darwin + 60 1 3DCoat 0x10106832c Widgets::DestroyDeadWidgets() + 40 2 3DCoat 0x1010682f4 GlobalProcessWidgets() + 12 3 3DCoat 0x101946dd4 comms::cMain_OnRender(comms::cRect const&) + 148 4 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 5 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 6 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 7 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 8 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 9 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 10 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 11 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 12 3DCoat 0x101058fbc BaseWidget::_draw() + 288 13 3DCoat 0x1010590bc BaseWidget::_draw() + 544 14 3DCoat 0x1010590bc BaseWidget::_draw() + 544 15 3DCoat 0x1010590bc BaseWidget::_draw() + 544 16 3DCoat 0x1010590bc BaseWidget::_draw() + 544 17 3DCoat 0x1010590bc BaseWidget::_draw() + 544 18 3DCoat 0x1010590bc BaseWidget::_draw() + 544 19 3DCoat 0x1010590bc BaseWidget::_draw() + 544 20 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 21 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 22 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 23 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 24 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 25 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 26 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 27 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 28 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 29 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 30 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 31 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 32 3DCoat 0x101058fbc BaseWidget::_draw() + 288 33 3DCoat 0x1010590bc BaseWidget::_draw() + 544 34 3DCoat 0x1010590bc BaseWidget::_draw() + 544 35 3DCoat 0x1010590bc BaseWidget::_draw() + 544 36 3DCoat 0x1010590bc BaseWidget::_draw() + 544 37 3DCoat 0x1010590bc BaseWidget::_draw() + 544 38 3DCoat 0x1010590bc BaseWidget::_draw() + 544 39 3DCoat 0x1010590bc BaseWidget::_draw() + 544 40 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 41 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 42 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 43 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 44 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 45 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 46 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 47 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 48 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 49 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 50 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 51 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 52 3DCoat 0x101058fbc BaseWidget::_draw() + 288 53 3DCoat 0x1010590bc BaseWidget::_draw() + 544 54 3DCoat 0x1010590bc BaseWidget::_draw() + 544 55 3DCoat 0x1010590bc BaseWidget::_draw() + 544 56 3DCoat 0x1010590bc BaseWidget::_draw() + 544 57 3DCoat 0x1010590bc BaseWidget::_draw() + 544 58 3DCoat 0x1010590bc BaseWidget::_draw() + 544 59 3DCoat 0x1010590bc BaseWidget::_draw() + 544 60 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 61 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 62 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 63 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 64 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 65 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 66 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 67 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 68 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 69 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 70 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 71 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 72 3DCoat 0x101058fbc BaseWidget::_draw() + 288 73 3DCoat 0x1010590bc BaseWidget::_draw() + 544 74 3DCoat 0x1010590bc BaseWidget::_draw() + 544 75 3DCoat 0x1010590bc BaseWidget::_draw() + 544 76 3DCoat 0x1010590bc BaseWidget::_draw() + 544 77 3DCoat 0x1010590bc BaseWidget::_draw() + 544 78 3DCoat 0x1010590bc BaseWidget::_draw() + 544 79 3DCoat 0x1010590bc BaseWidget::_draw() + 544 80 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 81 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 82 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 83 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 84 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 85 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 86 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 87 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 88 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 89 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 90 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 91 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 92 3DCoat 0x101058fbc BaseWidget::_draw() + 288 93 3DCoat 0x1010590bc BaseWidget::_draw() + 544 94 3DCoat 0x1010590bc BaseWidget::_draw() + 544 95 3DCoat 0x1010590bc BaseWidget::_draw() + 544 96 3DCoat 0x1010590bc BaseWidget::_draw() + 544 97 3DCoat 0x1010590bc BaseWidget::_draw() + 544 98 3DCoat 0x1010590bc BaseWidget::_draw() + 544 99 3DCoat 0x1010590bc BaseWidget::_draw() + 544 100 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 101 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 102 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 103 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 104 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 105 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 106 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 107 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 108 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 109 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 110 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 111 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 112 3DCoat 0x101058fbc BaseWidget::_draw() + 288 113 3DCoat 0x1010590bc BaseWidget::_draw() + 544 114 3DCoat 0x1010590bc BaseWidget::_draw() + 544 115 3DCoat 0x1010590bc BaseWidget::_draw() + 544 116 3DCoat 0x1010590bc BaseWidget::_draw() + 544 117 3DCoat 0x1010590bc BaseWidget::_draw() + 544 118 3DCoat 0x1010590bc BaseWidget::_draw() + 544 119 3DCoat 0x1010590bc BaseWidget::_draw() + 544 120 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 121 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 122 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 123 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 124 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 125 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 126 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 127 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 128 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 129 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 130 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 131 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 132 3DCoat 0x101058fbc BaseWidget::_draw() + 288 133 3DCoat 0x1010590bc BaseWidget::_draw() + 544 134 3DCoat 0x1010590bc BaseWidget::_draw() + 544 135 3DCoat 0x1010590bc BaseWidget::_draw() + 544 136 3DCoat 0x1010590bc BaseWidget::_draw() + 544 137 3DCoat 0x1010590bc BaseWidget::_draw() + 544 138 3DCoat 0x1010590bc BaseWidget::_draw() + 544 139 3DCoat 0x1010590bc BaseWidget::_draw() + 544 140 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 141 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 142 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 143 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 144 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 145 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 146 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 147 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 148 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 149 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 150 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 151 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 152 3DCoat 0x101058fbc BaseWidget::_draw() + 288 153 3DCoat 0x1010590bc BaseWidget::_draw() + 544 154 3DCoat 0x1010590bc BaseWidget::_draw() + 544 155 3DCoat 0x1010590bc BaseWidget::_draw() + 544 156 3DCoat 0x1010590bc BaseWidget::_draw() + 544 157 3DCoat 0x1010590bc BaseWidget::_draw() + 544 158 3DCoat 0x1010590bc BaseWidget::_draw() + 544 159 3DCoat 0x1010590bc BaseWidget::_draw() + 544 160 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 161 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 162 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 163 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 164 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 165 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 166 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 167 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 168 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 169 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 170 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 171 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 172 3DCoat 0x101058fbc BaseWidget::_draw() + 288 173 3DCoat 0x1010590bc BaseWidget::_draw() + 544 174 3DCoat 0x1010590bc BaseWidget::_draw() + 544 175 3DCoat 0x1010590bc BaseWidget::_draw() + 544 176 3DCoat 0x1010590bc BaseWidget::_draw() + 544 177 3DCoat 0x1010590bc BaseWidget::_draw() + 544 178 3DCoat 0x1010590bc BaseWidget::_draw() + 544 179 3DCoat 0x1010590bc BaseWidget::_draw() + 544 180 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 181 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 182 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 183 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 184 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 185 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 186 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 187 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 188 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 189 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 190 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 191 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 192 3DCoat 0x101058fbc BaseWidget::_draw() + 288 193 3DCoat 0x1010590bc BaseWidget::_draw() + 544 194 3DCoat 0x1010590bc BaseWidget::_draw() + 544 195 3DCoat 0x1010590bc BaseWidget::_draw() + 544 196 3DCoat 0x1010590bc BaseWidget::_draw() + 544 197 3DCoat 0x1010590bc BaseWidget::_draw() + 544 198 3DCoat 0x1010590bc BaseWidget::_draw() + 544 199 3DCoat 0x1010590bc BaseWidget::_draw() + 544 200 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 201 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 202 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 203 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 204 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 205 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 206 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 207 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 208 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 209 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 210 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 211 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 212 3DCoat 0x101058fbc BaseWidget::_draw() + 288 213 3DCoat 0x1010590bc BaseWidget::_draw() + 544 214 3DCoat 0x1010590bc BaseWidget::_draw() + 544 215 3DCoat 0x1010590bc BaseWidget::_draw() + 544 216 3DCoat 0x1010590bc BaseWidget::_draw() + 544 217 3DCoat 0x1010590bc BaseWidget::_draw() + 544 218 3DCoat 0x1010590bc BaseWidget::_draw() + 544 219 3DCoat 0x1010590bc BaseWidget::_draw() + 544 220 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 221 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 222 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 223 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 224 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 225 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 226 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 227 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 228 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 229 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 230 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 231 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 232 3DCoat 0x101058fbc BaseWidget::_draw() + 288 233 3DCoat 0x1010590bc BaseWidget::_draw() + 544 234 3DCoat 0x1010590bc BaseWidget::_draw() + 544 235 3DCoat 0x1010590bc BaseWidget::_draw() + 544 236 3DCoat 0x1010590bc BaseWidget::_draw() + 544 237 3DCoat 0x1010590bc BaseWidget::_draw() + 544 238 3DCoat 0x1010590bc BaseWidget::_draw() + 544 239 3DCoat 0x1010590bc BaseWidget::_draw() + 544 240 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 241 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 242 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 243 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 244 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 245 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 246 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 247 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 248 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 249 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 250 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 251 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 252 3DCoat 0x101058fbc BaseWidget::_draw() + 288 253 3DCoat 0x1010590bc BaseWidget::_draw() + 544 254 3DCoat 0x1010590bc BaseWidget::_draw() + 544 255 3DCoat 0x1010590bc BaseWidget::_draw() + 544 256 3DCoat 0x1010590bc BaseWidget::_draw() + 544 257 3DCoat 0x1010590bc BaseWidget::_draw() + 544 258 3DCoat 0x1010590bc BaseWidget::_draw() + 544 259 3DCoat 0x1010590bc BaseWidget::_draw() + 544 260 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 261 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 262 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 263 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 264 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 265 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 266 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 267 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 268 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 269 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 270 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 271 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 272 3DCoat 0x101058fbc BaseWidget::_draw() + 288 273 3DCoat 0x1010590bc BaseWidget::_draw() + 544 274 3DCoat 0x1010590bc BaseWidget::_draw() + 544 275 3DCoat 0x1010590bc BaseWidget::_draw() + 544 276 3DCoat 0x1010590bc BaseWidget::_draw() + 544 277 3DCoat 0x1010590bc BaseWidget::_draw() + 544 278 3DCoat 0x1010590bc BaseWidget::_draw() + 544 279 3DCoat 0x1010590bc BaseWidget::_draw() + 544 280 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 281 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 282 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 283 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 284 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 285 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 286 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 287 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 288 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 289 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 290 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 291 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 292 3DCoat 0x101058fbc BaseWidget::_draw() + 288 293 3DCoat 0x1010590bc BaseWidget::_draw() + 544 294 3DCoat 0x1010590bc BaseWidget::_draw() + 544 295 3DCoat 0x1010590bc BaseWidget::_draw() + 544 296 3DCoat 0x1010590bc BaseWidget::_draw() + 544 297 3DCoat 0x1010590bc BaseWidget::_draw() + 544 298 3DCoat 0x1010590bc BaseWidget::_draw() + 544 299 3DCoat 0x1010590bc BaseWidget::_draw() + 544 300 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 301 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 302 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 303 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 304 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 305 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 306 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 307 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 308 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 309 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 310 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 311 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 312 3DCoat 0x101058fbc BaseWidget::_draw() + 288 313 3DCoat 0x1010590bc BaseWidget::_draw() + 544 314 3DCoat 0x1010590bc BaseWidget::_draw() + 544 315 3DCoat 0x1010590bc BaseWidget::_draw() + 544 316 3DCoat 0x1010590bc BaseWidget::_draw() + 544 317 3DCoat 0x1010590bc BaseWidget::_draw() + 544 318 3DCoat 0x1010590bc BaseWidget::_draw() + 544 319 3DCoat 0x1010590bc BaseWidget::_draw() + 544 320 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 321 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 322 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 323 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 324 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 325 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 326 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 327 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 328 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 329 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 330 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 331 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 332 3DCoat 0x101058fbc BaseWidget::_draw() + 288 333 3DCoat 0x1010590bc BaseWidget::_draw() + 544 334 3DCoat 0x1010590bc BaseWidget::_draw() + 544 335 3DCoat 0x1010590bc BaseWidget::_draw() + 544 336 3DCoat 0x1010590bc BaseWidget::_draw() + 544 337 3DCoat 0x1010590bc BaseWidget::_draw() + 544 338 3DCoat 0x1010590bc BaseWidget::_draw() + 544 339 3DCoat 0x1010590bc BaseWidget::_draw() + 544 340 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 341 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 342 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 343 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 344 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 345 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 346 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 347 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 348 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 349 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 350 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 351 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 352 3DCoat 0x101058fbc BaseWidget::_draw() + 288 353 3DCoat 0x1010590bc BaseWidget::_draw() + 544 354 3DCoat 0x1010590bc BaseWidget::_draw() + 544 355 3DCoat 0x1010590bc BaseWidget::_draw() + 544 356 3DCoat 0x1010590bc BaseWidget::_draw() + 544 357 3DCoat 0x1010590bc BaseWidget::_draw() + 544 358 3DCoat 0x1010590bc BaseWidget::_draw() + 544 359 3DCoat 0x1010590bc BaseWidget::_draw() + 544 360 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 361 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 362 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 363 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 364 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 365 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 366 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 367 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 368 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 369 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 370 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 371 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 372 3DCoat 0x101058fbc BaseWidget::_draw() + 288 373 3DCoat 0x1010590bc BaseWidget::_draw() + 544 374 3DCoat 0x1010590bc BaseWidget::_draw() + 544 375 3DCoat 0x1010590bc BaseWidget::_draw() + 544 376 3DCoat 0x1010590bc BaseWidget::_draw() + 544 377 3DCoat 0x1010590bc BaseWidget::_draw() + 544 378 3DCoat 0x1010590bc BaseWidget::_draw() + 544 379 3DCoat 0x1010590bc BaseWidget::_draw() + 544 380 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 381 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 382 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 383 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 384 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 385 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 386 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 387 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 388 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 389 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 390 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 391 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 392 3DCoat 0x101058fbc BaseWidget::_draw() + 288 393 3DCoat 0x1010590bc BaseWidget::_draw() + 544 394 3DCoat 0x1010590bc BaseWidget::_draw() + 544 395 3DCoat 0x1010590bc BaseWidget::_draw() + 544 396 3DCoat 0x1010590bc BaseWidget::_draw() + 544 397 3DCoat 0x1010590bc BaseWidget::_draw() + 544 398 3DCoat 0x1010590bc BaseWidget::_draw() + 544 399 3DCoat 0x1010590bc BaseWidget::_draw() + 544 400 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 401 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 402 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 403 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 404 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 405 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 406 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 407 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 408 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 409 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 410 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 411 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 412 3DCoat 0x101058fbc BaseWidget::_draw() + 288 413 3DCoat 0x1010590bc BaseWidget::_draw() + 544 414 3DCoat 0x1010590bc BaseWidget::_draw() + 544 415 3DCoat 0x1010590bc BaseWidget::_draw() + 544 416 3DCoat 0x1010590bc BaseWidget::_draw() + 544 417 3DCoat 0x1010590bc BaseWidget::_draw() + 544 418 3DCoat 0x1010590bc BaseWidget::_draw() + 544 419 3DCoat 0x1010590bc BaseWidget::_draw() + 544 420 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 421 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 422 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 423 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 424 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 425 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 426 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 427 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 428 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 429 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 430 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 431 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 432 3DCoat 0x101058fbc BaseWidget::_draw() + 288 433 3DCoat 0x1010590bc BaseWidget::_draw() + 544 434 3DCoat 0x1010590bc BaseWidget::_draw() + 544 435 3DCoat 0x1010590bc BaseWidget::_draw() + 544 436 3DCoat 0x1010590bc BaseWidget::_draw() + 544 437 3DCoat 0x1010590bc BaseWidget::_draw() + 544 438 3DCoat 0x1010590bc BaseWidget::_draw() + 544 439 3DCoat 0x1010590bc BaseWidget::_draw() + 544 440 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 441 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 442 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 443 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 444 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 445 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 446 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 447 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 448 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 449 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 450 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 451 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 452 3DCoat 0x101058fbc BaseWidget::_draw() + 288 453 3DCoat 0x1010590bc BaseWidget::_draw() + 544 454 3DCoat 0x1010590bc BaseWidget::_draw() + 544 455 3DCoat 0x1010590bc BaseWidget::_draw() + 544 456 3DCoat 0x1010590bc BaseWidget::_draw() + 544 457 3DCoat 0x1010590bc BaseWidget::_draw() + 544 458 3DCoat 0x1010590bc BaseWidget::_draw() + 544 459 3DCoat 0x1010590bc BaseWidget::_draw() + 544 460 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 461 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 462 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 463 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 464 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 465 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 466 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 467 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 468 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 469 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 470 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 471 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 472 3DCoat 0x101058fbc BaseWidget::_draw() + 288 473 3DCoat 0x1010590bc BaseWidget::_draw() + 544 474 3DCoat 0x1010590bc BaseWidget::_draw() + 544 475 3DCoat 0x1010590bc BaseWidget::_draw() + 544 476 3DCoat 0x1010590bc BaseWidget::_draw() + 544 477 3DCoat 0x1010590bc BaseWidget::_draw() + 544 478 3DCoat 0x1010590bc BaseWidget::_draw() + 544 479 3DCoat 0x1010590bc BaseWidget::_draw() + 544 480 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 481 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 482 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 483 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 484 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 485 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 486 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 487 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 488 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 489 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 490 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 491 3DCoat 0x10105926c BaseWidget::CallPaintCallbacks() + 88 492 3DCoat 0x101058fbc BaseWidget::_draw() + 288 493 3DCoat 0x1010590bc BaseWidget::_draw() + 544 494 3DCoat 0x1010590bc BaseWidget::_draw() + 544 495 3DCoat 0x1010590bc BaseWidget::_draw() + 544 496 3DCoat 0x1010590bc BaseWidget::_draw() + 544 497 3DCoat 0x1010590bc BaseWidget::_draw() + 544 498 3DCoat 0x1010590bc BaseWidget::_draw() + 544 499 3DCoat 0x1010590bc BaseWidget::_draw() + 544 500 3DCoat 0x10105dcb4 Widgets::DrawWidgets() + 580 501 3DCoat 0x10107d560 IntfWidget2::OnRender() + 176 502 3DCoat 0x100d5cfb4 comms::cWidgets::Render(int) + 164 503 3DCoat 0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 504 3DCoat 0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 505 3DCoat 0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 506 3DCoat 0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 507 3DCoat 0x101aea5f8 TextureKeeper::Activate() + 336 508 3DCoat 0x101afa86c TextureKeeper::UpdatePreview() + 96 509 3DCoat 0x101afaf64 tkDrawPnPreview(long) + 156 510 3DCoat 0x1000f8580 _tcallback<void>::call() + 228 Thread 1: 0 libsystem_pthread.dylib 0x18c42eb6c start_wqthread + 0 Thread 2: 0 libsystem_pthread.dylib 0x18c42eb6c start_wqthread + 0 Thread 3: 0 libsystem_kernel.dylib 0x18c3f51c8 __semwait_signal + 8 1 libsystem_c.dylib 0x18c2d16f4 nanosleep + 220 2 libc++.1.dylib 0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3 3DCoat 0x1013c64a0 comms::SavingThread() + 56 4 3DCoat 0x1013ae6a8 void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, void (*)()>>(void*) + 52 5 libsystem_pthread.dylib 0x18c433bc8 _pthread_start + 136 6 libsystem_pthread.dylib 0x18c42eb80 thread_start + 8 Thread 4: 0 libsystem_kernel.dylib 0x18c3fa46c __accept + 8 1 3DCoat 0x1013dc324 httpListenThread(void*) + 300 2 libsystem_pthread.dylib 0x18c433bc8 _pthread_start + 136 3 libsystem_pthread.dylib 0x18c42eb80 thread_start + 8 Thread 5: 0 libsystem_kernel.dylib 0x18c3f51c8 __semwait_signal + 8 1 libsystem_c.dylib 0x18c2d16f4 nanosleep + 220 2 libc++.1.dylib 0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3 3DCoat 0x101e467b0 FileWaitThread(void*) + 112 4 libsystem_pthread.dylib 0x18c433bc8 _pthread_start + 136 5 libsystem_pthread.dylib 0x18c42eb80 thread_start + 8 Thread 6:: com.apple.NSEventThread 0 libsystem_kernel.dylib 0x18c3f1c34 mach_msg2_trap + 8 1 libsystem_kernel.dylib 0x18c404338 mach_msg2_internal + 76 2 libsystem_kernel.dylib 0x18c3fa764 mach_msg_overwrite + 484 3 libsystem_kernel.dylib 0x18c3f1fa8 mach_msg + 24 4 CoreFoundation 0x18c51ec0c __CFRunLoopServiceMachPort + 160 5 CoreFoundation 0x18c51d528 __CFRunLoopRun + 1208 6 CoreFoundation 0x18c51c9e8 CFRunLoopRunSpecific + 572 7 AppKit 0x19056178c _NSEventThread + 140 8 libsystem_pthread.dylib 0x18c433bc8 _pthread_start + 136 9 libsystem_pthread.dylib 0x18c42eb80 thread_start + 8 Thread 7: 0 libsystem_kernel.dylib 0x18c3f51c8 __semwait_signal + 8 1 libsystem_c.dylib 0x18c2d16f4 nanosleep + 220 2 libc++.1.dylib 0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3 3DCoat 0x100191f6c CheckFileThread(void*) + 184 4 libsystem_pthread.dylib 0x18c433bc8 _pthread_start + 136 5 libsystem_pthread.dylib 0x18c42eb80 thread_start + 8 Thread 8: 0 libsystem_kernel.dylib 0x18c3f51c8 __semwait_signal + 8 1 libsystem_c.dylib 0x18c2d16f4 nanosleep + 220 2 libc++.1.dylib 0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3 3DCoat 0x1017a1780 void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, CaptureTrajectory::CaptureTrajectory()::$_0>>(void*) + 228 4 libsystem_pthread.dylib 0x18c433bc8 _pthread_start + 136 5 libsystem_pthread.dylib 0x18c42eb80 thread_start + 8 Thread 9: 0 libsystem_kernel.dylib 0x18c3f51c8 __semwait_signal + 8 1 libsystem_c.dylib 0x18c2d16f4 nanosleep + 220 2 libc++.1.dylib 0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3 3DCoat 0x1013ae548 void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, fn_POST_RENDERlic()::$_1>>(void*) + 224 4 libsystem_pthread.dylib 0x18c433bc8 _pthread_start + 136 5 libsystem_pthread.dylib 0x18c42eb80 thread_start + 8 Thread 10: 0 libsystem_kernel.dylib 0x18c3f6158 __recvfrom + 8 1 3DCoat 0x1013a9a64 GetNeighbourPackets() + 224 2 3DCoat 0x1013ae6a8 void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, void (*)()>>(void*) + 52 3 libsystem_pthread.dylib 0x18c433bc8 _pthread_start + 136 4 libsystem_pthread.dylib 0x18c42eb80 thread_start + 8 Thread 11: 0 libsystem_kernel.dylib 0x18c3f51c8 __semwait_signal + 8 1 libsystem_c.dylib 0x18c2d16f4 nanosleep + 220 2 libc++.1.dylib 0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3 3DCoat 0x1013ae740 void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, fn_POST_RENDERlic()::$_2>>(void*) + 88 4 libsystem_pthread.dylib 0x18c433bc8 _pthread_start + 136 5 libsystem_pthread.dylib 0x18c42eb80 thread_start + 8 Thread 12: 0 libsystem_kernel.dylib 0x18c3f51c8 __semwait_signal + 8 1 libsystem_c.dylib 0x18c2d16f4 nanosleep + 220 2 libc++.1.dylib 0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3 3DCoat 0x1013aeb08 void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, fn_POST_RENDERlic()::$_3>>(void*) + 904 4 libsystem_pthread.dylib 0x18c433bc8 _pthread_start + 136 5 libsystem_pthread.dylib 0x18c42eb80 thread_start + 8 Thread 13: 0 libsystem_pthread.dylib 0x18c42eb6c start_wqthread + 0 Thread 0 crashed with ARM Thread State (64-bit): x0: 0x0000000000000000 x1: 0xffffec99bbc5287f x2: 0xffffec99bbc5287f x3: 0x0000000fffffc088 x4: 0x0000000000000000 x5: 0x000000016f5139a0 x6: 0x36323032206c6972 x7: 0xffffffff0011b500 x8: 0x0000000000000021 x9: 0x0000000000004300 x10: 0x000000016f50f700 x11: 0x000000016f510000 x12: 0x00000000016e3600 x13: 0x000000000003202a x14: 0x0000000000000006 x15: 0x8f5c28f5c28f5c29 x16: 0x000000018c42eb84 x17: 0x00000001fb4293e8 x18: 0x0000000000000000 x19: 0x000000016f513b18 x20: 0x000000010286e9e8 x21: 0x0000000102861000 x22: 0x000000010262e000 x23: 0x000000010262e000 x24: 0x000000010262e188 x25: 0x0000000000000000 x26: 0x000000010263c000 x27: 0x000000010263c000 x28: 0x0000000102814000 fp: 0x000000016f513a40 lr: 0x000000010106832c sp: 0x000000016f513a00 pc: 0x000000018c42ebc0 cpsr: 0x80001000 far: 0x000000016f50fff8 esr: 0x92000007 (Data Abort) byte read Translation fault Binary Images: 0x1000f4000 - 0x102417fff com.Pilgway.-DCoat (2026.01) <d392e462-7082-3703-892e-96a650c13893> /Applications/3DCoat-2026.01/3DCoat.app/Contents/MacOS/3DCoat 0x105430000 - 0x1057f3fff Python (*) <88bffd37-99d8-36ab-9b95-9f54b30bd667> /Applications/3DCoat-2026.01/3DCoat.app/Contents/MacOS/Python 0x1046b0000 - 0x104c0ffff libfbxsdk.dylib (*) <8206ed5d-f904-3e12-87a9-a14097f58481> /Applications/3DCoat-2026.01/3DCoat.app/Contents/MacOS/libfbxsdk.dylib 0x104624000 - 0x10462ffff libobjc-trampolines.dylib (*) <9a87f143-aa9d-3c46-b2e8-b3fb9215e33e> /usr/lib/libobjc-trampolines.dylib 0x110d60000 - 0x1113f7fff com.apple.AGXMetalG13X (329.2) <85754bfd-af86-38d8-997e-2a50a45ef2a0> /System/Library/Extensions/AGXMetalG13X.bundle/Contents/MacOS/AGXMetalG13X 0x105eb4000 - 0x105f1bfff com.apple.AppleMetalOpenGLRenderer (1.0) <993a7f68-a0cf-32ec-bd84-9a23cd55b5e2> /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer 0x105f50000 - 0x105f53fff _opcode.cpython-311-darwin.so (*) <5973ec29-8c62-3285-97ee-5797aef28b1c> /Users/USER/Documents/*/_opcode.cpython-311-darwin.so 0x1100a0000 - 0x1100b3fff _ctypes.cpython-311-darwin.so (*) <6c214dd2-6044-3285-949b-8d8ba72ca17b> /Users/USER/Documents/*/_ctypes.cpython-311-darwin.so 0x105fc8000 - 0x105fcffff _struct.cpython-311-darwin.so (*) <167d8231-8346-37b6-9d67-149a1fe3df21> /Users/USER/Documents/*/_struct.cpython-311-darwin.so 0x105f90000 - 0x105f9bfff math.cpython-311-darwin.so (*) <51d31d0d-1dcc-31ad-b6c1-73d57e544a3a> /Users/USER/Documents/*/math.cpython-311-darwin.so 0x18c42d000 - 0x18c439a77 libsystem_pthread.dylib (*) <c0519bf8-8fc4-3222-a4a7-d98af817277c> /usr/lib/system/libsystem_pthread.dylib 0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ??? 0x18c3f1000 - 0x18c42c5f3 libsystem_kernel.dylib (*) <bf2be9c2-05ea-372a-ad72-80441cad5380> /usr/lib/system/libsystem_kernel.dylib 0x18c2c4000 - 0x18c345247 libsystem_c.dylib (*) <89e4e823-2117-3e30-92da-4fdfec463893> /usr/lib/system/libsystem_c.dylib 0x18c346000 - 0x18c3d2ff7 libc++.1.dylib (*) <eb94c9fe-91da-3e9f-9c45-7b476feaaeae> /usr/lib/libc++.1.dylib 0x18c4a2000 - 0x18c9e0fff com.apple.CoreFoundation (6.9) <b670b809-77c2-36d2-ac51-eddc00ce8d74> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x190403000 - 0x19189375f com.apple.AppKit (6.9) <93588b4a-92ed-31d5-941c-fde64e4b5ed8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 42 thread_create: 0 thread_set_state: 792 VM Region Summary: ReadOnly portion of Libraries: Total=1.7G resident=0K(0%) swapped_out_or_unallocated=1.7G(100%) Writable regions: Total=1.2G written=8853K(1%) resident=1253K(0%) swapped_out=7600K(1%) unallocated=1.2G(99%) VIRTUAL REGION REGION TYPE SIZE COUNT (non-coalesced) =========== ======= ======= Accelerate framework 128K 1 Activity Tracing 256K 1 CG image 784K 5 ColorSync 608K 32 CoreAnimation 1296K 25 CoreGraphics 32K 2 CoreUI image data 992K 7 Dispatch continuations 80.0M 1 Foundation 16K 1 Kernel Alloc Once 32K 1 MALLOC 1.0G 116 MALLOC guard page 288K 18 MALLOC_LARGE (reserved) 45.8M 1 reserved VM address space (unallocated) OpenGL GLSL 256K 3 STACK GUARD 56.2M 14 Stack 15.0M 17 VM_ALLOCATE 53.3M 2333 __AUTH 5350K 681 __AUTH_CONST 75.6M 924 __CTF 824 1 __DATA 29.7M 914 __DATA_CONST 29.0M 941 __DATA_DIRTY 2770K 338 __FONT_DATA 2352 1 __GLSLBUILTINS 5174K 1 __INFO_FILTER 8 1 __LINKEDIT 650.5M 11 __OBJC_RO 61.4M 1 __OBJC_RW 2397K 1 __TEXT 1.0G 959 __TEXT (graphics) 44.3M 3 __TPRO_CONST 128K 2 mapped file 258.7M 49 page table in kernel 1253K 1 shared memory 976K 16 =========== ======= ======= TOTAL 3.4G 7423 TOTAL, minus reserved VM space 3.4G 7423 ----------- Full Report ----------- {"app_name":"3DCoat","timestamp":"2026-04-29 00:44:52.00 +0200","app_version":"2026.01","slice_uuid":"d392e462-7082-3703-892e-96a650c13893","build_version":"1","platform":1,"bundleID":"com.Pilgway.-DCoat","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 15.7.5 (24G624)","roots_installed":0,"name":"3DCoat","incident_id":"272C19B5-897F-4439-AAA6-B0C0B20CE9A4"} { "uptime" : 1600000, "procRole" : "Foreground", "version" : 2, "userID" : 501, "deployVersion" : 210, "modelCode" : "MacBookPro18,3", "coalitionID" : 279655, "osVersion" : { "train" : "macOS 15.7.5", "build" : "24G624", "releaseType" : "User" }, "captureTime" : "2026-04-29 00:44:52.3086 +0200", "codeSigningMonitor" : 1, "incident" : "272C19B5-897F-4439-AAA6-B0C0B20CE9A4", "pid" : 24617, "translated" : false, "cpuType" : "ARM-64", "roots_installed" : 0, "bug_type" : "309", "procLaunch" : "2026-04-29 00:41:45.0400 +0200", "procStartAbsTime" : 38753204011325, "procExitAbsTime" : 38757697678934, "procName" : "3DCoat", "procPath" : "\/Applications\/3DCoat-2026.01\/3DCoat.app\/Contents\/MacOS\/3DCoat", "bundleInfo" : {"CFBundleShortVersionString":"2026.01","CFBundleVersion":"1","CFBundleIdentifier":"com.Pilgway.-DCoat"}, "storeInfo" : {"deviceIdentifierForVendor":"B4EC1335-D606-5986-A13F-E8A0D8C6D7C0","thirdParty":true}, "parentProc" : "launchd", "parentPid" : 1, "coalitionName" : "com.Pilgway.-DCoat", "crashReporterKey" : "F9229ABC-4732-A1D8-BEB3-C9B32A468FA6", "appleIntelligenceStatus" : {"state":"unavailable","reasons":["selectedSiriLanguageIneligible","selectedLanguageIneligible"]}, "codeSigningID" : "com.Pilgway.-DCoat", "codeSigningTeamID" : "T2DD9H2G7P", "codeSigningFlags" : 570495745, "codeSigningValidationCategory" : 6, "codeSigningTrustLevel" : 4294967295, "codeSigningAuxiliaryInfo" : 0, "instructionByteStream" : {"beforePC":"S4Fd+OoDAJFfAQvrCQEAVEoBCeujAABUXwEL62MAAFTqL3+pwANf1g==","atPC":"a4Ff+OoDAJE\/BUDxwwAAVEoFQNFLAUD5KQVA0T8FQPGI\/\/9USgEJyw=="}, "bootSessionUUID" : "B25E2C84-D367-40CD-9E0B-31868C7D77AD", "wakeTime" : 8049, "sleepWakeUUID" : "97B0F65B-0D68-4C5D-A6D8-0342E11878C4", "sip" : "enabled", "vmRegionInfo" : "0x16f50fff8 is in 0x16bd0c000-0x16f510000; bytes after start: 58736632 bytes before end: 7\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n MALLOC_TINY 16bc00000-16bd00000 [ 1024K] rw-\/rwx SM=PRV \n GAP OF 0xc000 BYTES\n---> STACK GUARD 16bd0c000-16f510000 [ 56.0M] ---\/rwx SM=NUL stack guard for thread 0\n Stack 16f510000-16fd0c000 [ 8176K] rw-\/rwx SM=SHM thread 0", "exception" : {"codes":"0x0000000000000002, 0x000000016f50fff8","rawCodes":[2,6162546680],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_PROTECTION_FAILURE at 0x000000016f50fff8"}, "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":24617}, "vmregioninfo" : "0x16f50fff8 is in 0x16bd0c000-0x16f510000; bytes after start: 58736632 bytes before end: 7\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n MALLOC_TINY 16bc00000-16bd00000 [ 1024K] rw-\/rwx SM=PRV \n GAP OF 0xc000 BYTES\n---> STACK GUARD 16bd0c000-16f510000 [ 56.0M] ---\/rwx SM=NUL stack guard for thread 0\n Stack 16f510000-16fd0c000 [ 8176K] rw-\/rwx SM=SHM thread 0", "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":792,"task_for_pid":42},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0}, "faultingThread" : 0, "threads" : [{"triggered":true,"id":58927509,"threadState":{"x":[{"value":0},{"value":18446722743757252735},{"value":18446722743757252735},{"value":68719460488},{"value":0},{"value":6162561440},{"value":3905236818734115186},{"value":18446744069415744768},{"value":33},{"value":17152},{"value":6162544384},{"value":6162546688},{"value":24000000},{"value":204842},{"value":6},{"value":10330176681277348905},{"value":6648163204,"symbolLocation":0,"symbol":"___chkstk_darwin"},{"value":8510411752},{"value":0},{"value":6162561816},{"value":4337363432,"symbolLocation":0,"symbol":"IRS"},{"value":4337307648,"symbolLocation":528,"symbol":"bc"},{"value":4335001600,"symbolLocation":455,"symbol":"GetTextInFile(char const*, char const*)::s"},{"value":4335001600,"symbolLocation":455,"symbol":"GetTextInFile(char const*, char const*)::s"},{"value":4335001992,"symbolLocation":0,"symbol":"cMacMain_WindowedWindow"},{"value":0},{"value":4335058944,"symbolLocation":936,"symbol":"get_array_lecsems2(char const*, char**, char*, short)::strtmp"},{"value":4335058944,"symbolLocation":936,"symbol":"get_array_lecsems2(char const*, char**, char*, short)::strtmp"},{"value":4336992256,"symbolLocation":88,"symbol":"m_SmudgeTool"}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4312171308},"cpsr":{"value":2147487744},"fp":{"value":6162561600},"sp":{"value":6162561536},"esr":{"value":2449473543,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":6648163264,"matchesCrashFrame":1},"far":{"value":6162546680}},"queue":"com.apple.main-thread","frames":[{"imageOffset":7104,"symbol":"___chkstk_darwin","symbolLocation":60,"imageIndex":10},{"imageOffset":16204588,"symbol":"Widgets::DestroyDeadWidgets()","symbolLocation":40,"imageIndex":0},{"imageOffset":16204532,"symbol":"GlobalProcessWidgets()","symbolLocation":12,"imageIndex":0},{"imageOffset":25505236,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":148,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0}]},{"id":58927641,"frames":[{"imageOffset":7020,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":10}],"threadState":{"x":[{"value":6172618752},{"value":17155},{"value":6172082176},{"value":6172617600},{"value":5193734},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6172617488},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6648163180},"far":{"value":0}}},{"id":58927642,"frames":[{"imageOffset":7020,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":10}],"threadState":{"x":[{"value":6173192192},{"value":32003},{"value":6172655616},{"value":6173191040},{"value":5193732},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6173191024},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6648163180},"far":{"value":0}}},{"id":58927670,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":19735712,"symbol":"comms::SavingThread()","symbolLocation":56,"imageIndex":0},{"imageOffset":19637928,"symbol":"void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, void (*)()>>(void*)","symbolLocation":52,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":0},{"value":500000000},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":334},{"value":8510412152},{"value":0},{"value":6173765456},{"value":6173765456},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6173765440},"sp":{"value":6173765392},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58927673,"frames":[{"imageOffset":37996,"symbol":"__accept","symbolLocation":8,"imageIndex":12},{"imageOffset":19825444,"symbol":"httpListenThread(void*)","symbolLocation":300,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":6174912060},{"value":9876},{"value":6174912512},{"value":419432703},{"value":0},{"value":0},{"value":37926},{"value":43780},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":30},{"value":8510412248},{"value":0},{"value":9876},{"value":9},{"value":2},{"value":0},{"value":0},{"value":16},{"value":4337000448,"symbolLocation":8,"symbol":"pyBindPreprocessor::pyDefClasses"},{"value":4337010840,"symbolLocation":0,"symbol":"comms::cStr::def_str"},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4315792164},"cpsr":{"value":536875008},"fp":{"value":6174912448},"sp":{"value":6174912000},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647948396},"far":{"value":0}}},{"id":58927674,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":30746544,"symbol":"FileWaitThread(void*)","symbolLocation":112,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":1},{"value":0},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":1099511628034},{"value":256},{"value":1099511628032},{"value":7},{"value":92},{"value":334},{"value":8510412152},{"value":0},{"value":6175485712},{"value":6175485712},{"value":4335097510,"symbolLocation":0,"symbol":"ReadyList"},{"value":64},{"value":4329890718},{"value":0},{"value":4338429400,"symbolLocation":0,"symbol":"IsInExitState"},{"value":1000000000},{"value":4337010840,"symbolLocation":0,"symbol":"comms::cStr::def_str"},{"value":100000000}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6175485696},"sp":{"value":6175485648},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58927709,"name":"com.apple.NSEventThread","threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":247420181020672},{"value":0},{"value":247420181020672},{"value":2},{"value":4294967295},{"value":0},{"value":17179869184},{"value":0},{"value":2},{"value":0},{"value":0},{"value":57607},{"value":0},{"value":18446744073709551569},{"value":8510413912},{"value":0},{"value":4294967295},{"value":2},{"value":247420181020672},{"value":0},{"value":247420181020672},{"value":6176055432},{"value":8589934592},{"value":21592279046},{"value":18446744073709550527},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6647989048},"cpsr":{"value":4096},"fp":{"value":6176055280},"sp":{"value":6176055200},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647913524},"far":{"value":0}},"frames":[{"imageOffset":3124,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":12},{"imageOffset":78648,"symbol":"mach_msg2_internal","symbolLocation":76,"imageIndex":12},{"imageOffset":38756,"symbol":"mach_msg_overwrite","symbolLocation":484,"imageIndex":12},{"imageOffset":4008,"symbol":"mach_msg","symbolLocation":24,"imageIndex":12},{"imageOffset":510988,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":15},{"imageOffset":505128,"symbol":"__CFRunLoopRun","symbolLocation":1208,"imageIndex":15},{"imageOffset":502248,"symbol":"CFRunLoopRunSpecific","symbolLocation":572,"imageIndex":15},{"imageOffset":1435532,"symbol":"_NSEventThread","symbolLocation":140,"imageIndex":16},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":58927710,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":647020,"symbol":"CheckFileThread(void*)","symbolLocation":184,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":1},{"value":0},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":334},{"value":8510412152},{"value":0},{"value":6176632656},{"value":6176632656},{"value":2},{"value":1000000000},{"value":4335104000,"symbolLocation":40,"symbol":"AppExchange::LastExportParams"},{"value":4337010840,"symbolLocation":0,"symbol":"comms::cStr::def_str"},{"value":1},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6176632640},"sp":{"value":6176632592},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58927812,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":23779200,"symbol":"void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, CaptureTrajectory::CaptureTrajectory()::$_0>>(void*)","symbolLocation":228,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":0},{"value":3000000},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":2},{"value":0},{"value":0},{"value":8759},{"value":5624889344},{"value":334},{"value":8510412152},{"value":0},{"value":6177206096},{"value":6177206096},{"value":4337033216,"symbolLocation":32,"symbol":"DrawMod"},{"value":4336994024,"symbolLocation":0,"symbol":"Widgets::CurrentTime"},{"value":3000000},{"value":50000000},{"value":4336994040,"symbolLocation":0,"symbol":"Widgets::WholeScreen"},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6177206080},"sp":{"value":6177206032},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58927854,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":19637576,"symbol":"void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, fn_POST_RENDERlic()::$_1>>(void*)","symbolLocation":224,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":60},{"value":0},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":1099511628034},{"value":256},{"value":1099511628032},{"value":5554323584},{"value":320464},{"value":334},{"value":8510412152},{"value":0},{"value":6178352960},{"value":6178352960},{"value":4338429400,"symbolLocation":0,"symbol":"IsInExitState"},{"value":6178353012},{"value":4335022080,"symbolLocation":40,"symbol":"_MergedGlobals"},{"value":60000000000},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6178352944},"sp":{"value":6178352896},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58927855,"frames":[{"imageOffset":20824,"symbol":"__recvfrom","symbolLocation":8,"imageIndex":12},{"imageOffset":19618404,"symbol":"GetNeighbourPackets()","symbolLocation":224,"imageIndex":0},{"imageOffset":19637928,"symbol":"void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, void (*)()>>(void*)","symbolLocation":52,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":128},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":50051},{"value":4337003952,"symbolLocation":0,"symbol":"LiDat"},{"value":18446744067062209551},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":29},{"value":8510412128},{"value":0},{"value":14},{"value":6178926320},{"value":0},{"value":329757913},{"value":6178926192},{"value":4337000448,"symbolLocation":8,"symbol":"pyBindPreprocessor::pyDefClasses"},{"value":1},{"value":6178926160},{"value":4338429400,"symbolLocation":0,"symbol":"IsInExitState"},{"value":5000000000}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4315585124},"cpsr":{"value":2684358656},"fp":{"value":6178926480},"sp":{"value":6178926160},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647931224},"far":{"value":0}}},{"id":58927856,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":19638080,"symbol":"void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, fn_POST_RENDERlic()::$_2>>(void*)","symbolLocation":88,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":243},{"value":0},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":334},{"value":8510412152},{"value":0},{"value":6179499904},{"value":6179499904},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6179499888},"sp":{"value":6179499840},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58927857,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":19639048,"symbol":"void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, fn_POST_RENDERlic()::$_3>>(void*)","symbolLocation":904,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":5},{"value":0},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":334},{"value":8510412152},{"value":0},{"value":6180073216},{"value":6180073216},{"value":30000000000},{"value":0},{"value":5000000000},{"value":3000000000},{"value":0},{"value":4337010840,"symbolLocation":0,"symbol":"comms::cStr::def_str"},{"value":4338429400,"symbolLocation":0,"symbol":"IsInExitState"},{"value":1000000000}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6180073200},"sp":{"value":6180073152},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58931819,"frames":[{"imageOffset":7020,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":10}],"threadState":{"x":[{"value":6205632512},{"value":53887},{"value":6205095936},{"value":6205631360},{"value":5193732},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6205631344},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6648163180},"far":{"value":0}}}], "usedImages" : [ { "source" : "P", "arch" : "arm64", "base" : 4295966720, "CFBundleShortVersionString" : "2026.01", "CFBundleIdentifier" : "com.Pilgway.-DCoat", "size" : 36847616, "uuid" : "d392e462-7082-3703-892e-96a650c13893", "path" : "\/Applications\/3DCoat-2026.01\/3DCoat.app\/Contents\/MacOS\/3DCoat", "name" : "3DCoat", "CFBundleVersion" : "1" }, { "source" : "P", "arch" : "arm64", "base" : 4383244288, "size" : 3948544, "uuid" : "88bffd37-99d8-36ab-9b95-9f54b30bd667", "path" : "\/Applications\/3DCoat-2026.01\/3DCoat.app\/Contents\/MacOS\/Python", "name" : "Python" }, { "source" : "P", "arch" : "arm64", "base" : 4369088512, "size" : 5636096, "uuid" : "8206ed5d-f904-3e12-87a9-a14097f58481", "path" : "\/Applications\/3DCoat-2026.01\/3DCoat.app\/Contents\/MacOS\/libfbxsdk.dylib", "name" : "libfbxsdk.dylib" }, { "source" : "P", "arch" : "arm64e", "base" : 4368515072, "size" : 49152, "uuid" : "9a87f143-aa9d-3c46-b2e8-b3fb9215e33e", "path" : "\/usr\/lib\/libobjc-trampolines.dylib", "name" : "libobjc-trampolines.dylib" }, { "source" : "P", "arch" : "arm64e", "base" : 4577427456, "CFBundleShortVersionString" : "329.2", "CFBundleIdentifier" : "com.apple.AGXMetalG13X", "size" : 6914048, "uuid" : "85754bfd-af86-38d8-997e-2a50a45ef2a0", "path" : "\/System\/Library\/Extensions\/AGXMetalG13X.bundle\/Contents\/MacOS\/AGXMetalG13X", "name" : "AGXMetalG13X", "CFBundleVersion" : "329.2" }, { "source" : "P", "arch" : "arm64e", "base" : 4394270720, "CFBundleShortVersionString" : "1.0", "CFBundleIdentifier" : "com.apple.AppleMetalOpenGLRenderer", "size" : 425984, "uuid" : "993a7f68-a0cf-32ec-bd84-9a23cd55b5e2", "path" : "\/System\/Library\/Extensions\/AppleMetalOpenGLRenderer.bundle\/Contents\/MacOS\/AppleMetalOpenGLRenderer", "name" : "AppleMetalOpenGLRenderer", "CFBundleVersion" : "1" }, { "source" : "P", "arch" : "arm64", "base" : 4394909696, "size" : 16384, "uuid" : "5973ec29-8c62-3285-97ee-5797aef28b1c", "path" : "\/Users\/USER\/Documents\/*\/_opcode.cpython-311-darwin.so", "name" : "_opcode.cpython-311-darwin.so" }, { "source" : "P", "arch" : "arm64", "base" : 4564058112, "size" : 81920, "uuid" : "6c214dd2-6044-3285-949b-8d8ba72ca17b", "path" : "\/Users\/USER\/Documents\/*\/_ctypes.cpython-311-darwin.so", "name" : "_ctypes.cpython-311-darwin.so" }, { "source" : "P", "arch" : "arm64", "base" : 4395401216, "size" : 32768, "uuid" : "167d8231-8346-37b6-9d67-149a1fe3df21", "path" : "\/Users\/USER\/Documents\/*\/_struct.cpython-311-darwin.so", "name" : "_struct.cpython-311-darwin.so" }, { "source" : "P", "arch" : "arm64", "base" : 4395171840, "size" : 49152, "uuid" : "51d31d0d-1dcc-31ad-b6c1-73d57e544a3a", "path" : "\/Users\/USER\/Documents\/*\/math.cpython-311-darwin.so", "name" : "math.cpython-311-darwin.so" }, { "source" : "P", "arch" : "arm64e", "base" : 6648156160, "size" : 51832, "uuid" : "c0519bf8-8fc4-3222-a4a7-d98af817277c", "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib", "name" : "libsystem_pthread.dylib" }, { "size" : 0, "source" : "A", "base" : 0, "uuid" : "00000000-0000-0000-0000-000000000000" }, { "source" : "P", "arch" : "arm64e", "base" : 6647910400, "size" : 243188, "uuid" : "bf2be9c2-05ea-372a-ad72-80441cad5380", "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib", "name" : "libsystem_kernel.dylib" }, { "source" : "P", "arch" : "arm64e", "base" : 6646677504, "size" : 528968, "uuid" : "89e4e823-2117-3e30-92da-4fdfec463893", "path" : "\/usr\/lib\/system\/libsystem_c.dylib", "name" : "libsystem_c.dylib" }, { "source" : "P", "arch" : "arm64e", "base" : 6647209984, "size" : 577528, "uuid" : "eb94c9fe-91da-3e9f-9c45-7b476feaaeae", "path" : "\/usr\/lib\/libc++.1.dylib", "name" : "libc++.1.dylib" }, { "source" : "P", "arch" : "arm64e", "base" : 6648635392, "CFBundleShortVersionString" : "6.9", "CFBundleIdentifier" : "com.apple.CoreFoundation", "size" : 5500928, "uuid" : "b670b809-77c2-36d2-ac51-eddc00ce8d74", "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation", "name" : "CoreFoundation", "CFBundleVersion" : "3603.1.407" }, { "source" : "P", "arch" : "arm64e", "base" : 6715092992, "CFBundleShortVersionString" : "6.9", "CFBundleIdentifier" : "com.apple.AppKit", "size" : 21563232, "uuid" : "93588b4a-92ed-31d5-941c-fde64e4b5ed8", "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit", "name" : "AppKit", "CFBundleVersion" : "2575.70.55" } ], "sharedCache" : { "base" : 6643515392, "size" : 5039767552, "uuid" : "bbc7de5b-a6f2-3c3b-9bd5-c3e69c75bc82" }, "vmSummary" : "ReadOnly portion of Libraries: Total=1.7G resident=0K(0%) swapped_out_or_unallocated=1.7G(100%)\nWritable regions: Total=1.2G written=8853K(1%) resident=1253K(0%) swapped_out=7600K(1%) unallocated=1.2G(99%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 128K 1 \nActivity Tracing 256K 1 \nCG image 784K 5 \nColorSync 608K 32 \nCoreAnimation 1296K 25 \nCoreGraphics 32K 2 \nCoreUI image data 992K 7 \nDispatch continuations 80.0M 1 \nFoundation 16K 1 \nKernel Alloc Once 32K 1 \nMALLOC 1.0G 116 \nMALLOC guard page 288K 18 \nMALLOC_LARGE (reserved) 45.8M 1 reserved VM address space (unallocated)\nOpenGL GLSL 256K 3 \nSTACK GUARD 56.2M 14 \nStack 15.0M 17 \nVM_ALLOCATE 53.3M 2333 \n__AUTH 5350K 681 \n__AUTH_CONST 75.6M 924 \n__CTF 824 1 \n__DATA 29.7M 914 \n__DATA_CONST 29.0M 941 \n__DATA_DIRTY 2770K 338 \n__FONT_DATA 2352 1 \n__GLSLBUILTINS 5174K 1 \n__INFO_FILTER 8 1 \n__LINKEDIT 650.5M 11 \n__OBJC_RO 61.4M 1 \n__OBJC_RW 2397K 1 \n__TEXT 1.0G 959 \n__TEXT (graphics) 44.3M 3 \n__TPRO_CONST 128K 2 \nmapped file 258.7M 49 \npage table in kernel 1253K 1 \nshared memory 976K 16 \n=========== ======= ======= \nTOTAL 3.4G 7423 \nTOTAL, minus reserved VM space 3.4G 7423 \n", "legacyInfo" : { "threadTriggered" : { "queue" : "com.apple.main-thread" } }, "logWritingSignature" : "f0ac1de52e9b5fdb95c328d9b4ffe7f307c813f4", "trialInfo" : { "rollouts" : [ { "rolloutId" : "65a8173205d942272410674b", "factorPackIds" : { "SIRI_HOME_AUTOMATION_SERVER_FLOW_DEPRECATION" : "65d39fa4cb0e2417d11ce5f6" }, "deploymentId" : 240000001 }, { "rolloutId" : "64628732bf2f5257dedc8988", "factorPackIds" : { }, "deploymentId" : 240000001 } ], "experiments" : [ ] } }
