    • Video clip of my 3D model I completed using Blender 3D and textured painted using 3D Coat 2024. I built the palace model completely from scratch in Blender. Will be using the model in a future digital illustration I have cooking in my mind. PALACE.mp4
    • Please give some steps to reproduce this. Запись экрана 2025-01-21 163533.mp4
    • Hello! What material do you mean? Запись экрана 2025-01-21 162329.mp4
    • Once again, it's a 3rd Party Plugin. It's really easy to criticize something without actually trying it. I know because I was skeptical when it first came out in it's earliest stages a few years ago, but after actually testing it, recently...even for a few minutes...I changed my mind about it, completely. It's like VR Sculpting or using a 3dconnexion device. It's so easy to bash it, without firsthand knowledge or experience. Have you tried it? Then how can you call it useless (and truly know what you are talking about)? Many artists in a studio environment are listening to music on their headphones, and if I had a colleague who wanted to use Voice Command software to make their work more efficient, I would have no problem wearing headphones or earplugs...if it really bothered me that much. Also, there are many artists who work alone in their own office/space. It may not be for everyone, but just because you don't prefer to use it, personally, that doesn't make it worthless for many other users. You honestly will not comprehend how valuable it can be until you actually try it...with an objective mind, rather than a cynical one. Being able to work without having to even look at your keyboard or dig through a tool panel/menu is golden...especially in the Minimal Layout (toggled with the TAB key). For me, it's even faster and more efficient than using a 3DConnexion Space Explorer and all its many buttons + the buttons and ring on the Wacom Tablet. Plus, you don't have to use it, exclusively. You could use the Preset Panel for many tasks and use HMC Voice for switching views, Ortho/Perspective, toggle Symmetry, switching workspaces, etc.
    • Could you please explain this problem in more detail?
    • Take the default voxels sphere create a primitive sphere on intersect mode apply
    • This was fixed a few builds ago. At least I can't replicate it in 2024.32. How did you manage to do it? Запись экрана 2025-01-21 142351.mp4 The bug was successfully reproduced.
    • Please remember that Pilgway staff are still in the middle of an ongoing war, and they still hear air sirens and explosions every single day...and it is possible that some of the staff have to serve in some capacity. I am not saying they are, but if you are not getting the normal rate of communication and features, this could very well have some bearing on it and perhaps why a "Roadmap" is not mentioned. One of their main developers (normally GPU tech related) lives in California...perhaps he is affected by the massive wildfires in the LA area. I don't know, but it's possible that they are doing the best they can in a time of crisis. Just a guess. Also, because 3DCoat is unique in the fact that it uses a Public Beta, you are effectively seeing the Roadmap with each release...as new features are initially included in Beta builds and refined/improved until the next Major Version. The recently added Surface Array, Array, and Photogrammatry features are some of those. There was also an overall performance boost mentioned in one of the most recent builds. There is more on their plate, but they are being quiet about it until the features are ready for a Beta Build. Andrew has never really given a Roadmap because some efforts may take much longer than anticipated. Most software developers are this way because there are too many unknowns during feature development.  Lightwave is a good example, where they generally try to keep users informed about upcoming releases, as they draw near (and are thus in a closed Beta stage of development), but they don't generally lay out a "RoadMap."
    • Michael Pavlovich made a video about the same feature in ZBrush...it was 7minutes. Maybe someone should tell him in the comments that he should have kept it to 30 seconds?
    • Hi everybody and happy new Year!! - Coat 2024.32: >>Fixed problem when you try to fill curve with mesh (or do any other curve constructive operation) not in the Sculpt room. Now it switches to the Sculpt room and them performs the operation. This is causing problems. The Room change hardcoded into the Tool. I dont think that is a good fix. Everytime you Click on an Object in the Sculptree with a Modifier, it does change to Sculpt Room now. has there been a problem how it was before? I also get problems with custom rightmouse menu not showing up at first.
    • Hello I want to report a bug . The intersect option in the primative tool doesn't work the way it should, it just subtract the mesh like the subtract option. I think this can create a bad impression for a new users.
    • Hi, I wanted to report a bug with the Vox Layer tool. When I'm drawing a mask and press Ctrl+Z to go back to a previous state, the Vox Layer doesn’t create anything—it only generates an empty SculptTree Layer. Steps to reproduce the bug: Select the Vox Layer tool. Draw a vertical mask on the left side. Draw another vertical mask on the right side. Press Ctrl+Z because you decide the right mask needs adjustments. Draw the right-side mask again. Click the Apply button to create the layer. Following these steps will reproduce the bug with the Vox Layer tool when using Ctrl+Z. This issue doesn’t occur with Vox Extrude Tool.
    • Hi everyone, on 3Dcoat Textura 2024.32 there is a bug with the "FILL" tool when you use it in the "texture editor" the final result of the material is different from that of the original material, while it is correct when you use it in the view 3d.... Among other things, it would be very useful and convenient to be able to use the "FILL" tool in the 3d view taking into account the UV cuts of the mesh. Another bug....symmetry doesn't work with the "FILL" tool Another bug that had been fixed in previous versions and which has now recurred is that of the size of the imported brushes which for some strange reason are larger than they should actually be... I'm talking about this:
    • Case: Fractal Design Terra review - PC Gamer. Dock: Orico PTM1 10-in-1 Docking Station with Module M.2 SSD Enclosure review - TechRadar. Game Controller: Thrustmaster T300RS GT Edition review- a responsive racing wheel with a few too many rough edges - TechRadar. Headset/Earbuds: Turtle Beach Stealth 700 Gen 3 Review - APH Networks. Laptop: Lenovo ThinkPad X1 Carbon Gen 13 Aura Edition Review - Thurrott.com. Motherboard: The Best Motherboards For AMD Ryzen 7 9800X3D To Unlock Peak Gaming Performance - Wccftech. Motherboard: Pulsar XBOARD QS Mechanical Keyboard review- A content creator's dream - XDA. Headset/Earbuds: Huawei FreeBuds Pro 4 review - ANC headphones with lossless audio - NotebookCheck.net Reviews. Headset/Earbuds: SteelSeries Arctis GameBuds review- I’ll never go back to bulky over-ear gaming headsets - Laptop Mag. Keyboard: Gamakay TK75 V2 Silent mechanical keyboard review- More than just a quiet gimmick - NotebookCheck.net Reviews. Keyboard: Logitech G Pro X TKL Rapid review - PC Gamer. Monitor/Projector: Asus ProArt Display 5K review- 27-inch Retina for a bargain - Apple Insider. Monitor/Projector: OrangePi 4A Review- Coming for the king - Tom's Hardware. Motherboard: Asus TUF Gaming B860M-Plus WiFi review - PC Gamer. SSD: Silicon Power PX10 1TB USB 3.2 Gen 2 External SSD - Mad Shrimps. Case: Montech Heritage Pro Review - The Leather Case - TechPowerUp. CPU/GPU/AIO/SSD Cooler: be quiet! Light Loop 360 mm AIO Review - TechPowerUp. Keyboard: Logitech G Pro X TKL Rapid Review - PCMag. Misc: Anker 335 Charger (67W) review- a great-value tri-port wall charger with no frills - TechRadar. Sound Card/DAC: WiiM Amp Pro Review- Name a Better Network Amp, We'll Wait - WIRED (may require registration or subscription). SSD: Solidigm D7-PS1010 3.84TB Enterprise SSD Review - Best-In-Class - TweakTown. Dock: Plugable USB-C Dual 4K Display HDMI or DisplayPort Horizontal Docking Station review - TechRadar. Game Controller: Logitech G RS Wheel Hub and RS Track Wheel review - PC Gamer. Headset/Earbuds: These Beyerdynamic headphones deliver impressively accurate sound and all-day comfort - ZDNET. Keyboard: Razer BlackWidow V4 Pro 75% review - PC Gamer. Keyboard: Lemokey P1 HE review- A premium, beautiful gaming keyboard that feels (and sounds) great - XDA. Monitor/Projector: Asus ProArt PA27JCV 5K professional monitor review- Redefining pixel density and color accuracy - Tom's Hardware. Mouse Pad/Mat: RAM: Crucial Pro Overclocking DDR5-6400 2x16GB Review - APH Networks. Sound Card/DAC: Fosi Audio K7 Gaming Desktop DAC-Headphone Amplifier Review - TechPowerUp.
    • We closely monitor all proposals from respected users and pass them on to the developers.
