    • Kayess
      nope...  RealityScan works on it´s own, yeah - but the tools do not seem to do anything, besides giving me this msg when importing a ply. I also follwed along the video series you linked, interesting stuff. But the only relation between RS and 3DC was importting a mesh (I think it was fbx) into 3DC and just do normal sculpting pass. I thought with the photogrammetry tool we could calculate the mesh via RS API and get this directly into 3DC or something like a bridge to push the mesh over from one app to the other back´n forth. Or even drag in images into 3DC and under the hood, RS does the math or something like this... but... no
      On windows version, when we select the Edge Scatter, 3DC automatically switch to the recently baked NM texture. This is not working as expected, it is a bug * Reported Thanks for point it up
      Is RealityScan working now ?
    • erisan
      Yes, I have thanks. This crash in this thread is achieved by following different steps than the thread you linked to. See the video for precise steps. Is this crash also related to OpenGL?
    • Kayess
      So I re-installed RS directly in C: drive and set path to engine. When I import a ply, exported from RS, I still get:
    • Kayess
      OK - then I have to re-install RS to my C: Thank you so much for this competent support and very quick replying - this helped me a lot ! best regards
      RS only work w/3DC if it is installed on drive C: Check this playlist to see 3DC <> RS full workflow Hope it help
    • Kayess
      Okee, I can expand it and browse for a ply, las or laz file. Maybe I got this totally wrong, but I was assuming this tools to be kind of a live bridge between RS and 3DC - but I guess, this is not the case. I exported a ply from RS for testing (it seems to just export a sparse point cloud, around 27MB filesize). When I hit "Generate Mesh", I get: and that´s about it.   I also tested with another ply exported from another app - but after hitting "Generatge Mesh" it just flashes quickly and still nothing happens. So I guess, I am using this tool totally wrong. May you can explain, what it is used for and what is the main benefit of using this, instead of staying in RC for mesh generation? Thanks in advance    Edit: Oh - RS is installed on Drive D, not C !
      Expand Tool option Parameters, Point Cloud must pick the location of the pointcloud model hmmm... could be perrmissions ? try running 3DC as administrator * RealityScan was installed on dive C:/ ?   if that step isn't working, another option will be to downgrade to Reality Capture and try again.
    • Kayess
      Hello Carlosan and thank you very much for this quick hint. So yes, I think this is activated, but the tools seem to be not: I set the path to engine a few times now, but when I click again, it defaults to C: Documents/3dCoat once again... Maybe something wrong with windows permissions? Cheers
      Hello Have you read the developer's response?
      Hello RCapture extension must be turned on (Windows > Panels > Extensions) Is it ?
    • Kayess
      hi there, I am unsing latest RealiyScan 2.1 Version with 3DCoat 2025.17 and I am experiencing the same issue as mentioned above: I can set the path to .exe and nothing happens (even after a restart) Maybe this is (still) broken? Cheers
    • erisan
      Crash occurs just after pressing Choose Texture in Smart Material editor at 0:40 (I stopped recording prior to the crash). So another crash while randomly following a page in the docs. All these crashes on macOS makes erodes my confidence and interest in 3dcoat and I wonder if anyone uses it professionally on mac? Perhaps you should stop selling 3DC for macOS. I cannot understand how anyone can put up with such unstable software on macOS. ------------------------------------- Translated Report (Full Report Below) ------------------------------------- Process:               3DCoat [24617] Path:                  /Applications/3DCoat-2026.01/3DCoat.app/Contents/MacOS/3DCoat Identifier:            com.Pilgway.-DCoat Version:               2026.01 (1) Code Type:             ARM-64 (Native) Parent Process:        launchd [1] User ID:               501 Date/Time:             2026-04-29 00:44:52.3086 +0200 OS Version:            macOS 15.7.5 (24G624) Report Version:        12 Anonymous UUID:        F9229ABC-4732-A1D8-BEB3-C9B32A468FA6 Sleep/Wake UUID:       97B0F65B-0D68-4C5D-A6D8-0342E11878C4 Time Awake Since Boot: 1600000 seconds Time Since Wake:       8049 seconds System Integrity Protection: enabled Crashed Thread:        0  Dispatch queue: com.apple.main-thread Exception Type:        EXC_BAD_ACCESS (SIGSEGV) Exception Codes:       KERN_PROTECTION_FAILURE at 0x000000016f50fff8 Exception Codes:       0x0000000000000002, 0x000000016f50fff8 Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11 Terminating Process:   exc handler [24617] VM Region Info: 0x16f50fff8 is in 0x16bd0c000-0x16f510000;  bytes after start: 58736632  bytes before end: 7       REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL       MALLOC_TINY                 16bc00000-16bd00000    [ 1024K] rw-/rwx SM=PRV         GAP OF 0xc000 BYTES --->  STACK GUARD                 16bd0c000-16f510000    [ 56.0M] ---/rwx SM=NUL  stack guard for thread 0       Stack                       16f510000-16fd0c000    [ 8176K] rw-/rwx SM=SHM  thread 0 Thread 0 Crashed::  Dispatch queue: com.apple.main-thread 0   libsystem_pthread.dylib                  0x18c42ebc0 ___chkstk_darwin + 60 1   3DCoat                                   0x10106832c Widgets::DestroyDeadWidgets() + 40 2   3DCoat                                   0x1010682f4 GlobalProcessWidgets() + 12 3   3DCoat                                   0x101946dd4 comms::cMain_OnRender(comms::cRect const&) + 148 4   3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 5   3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 6   3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 7   3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 8   3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 9   3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 10  3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 11  3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 12  3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 13  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 14  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 15  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 16  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 17  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 18  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 19  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 20  3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 21  3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 22  3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 23  3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 24  3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 25  3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 26  3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 27  3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 28  3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 29  3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 30  3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 31  3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 32  3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 33  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 34  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 35  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 36  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 37  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 38  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 39  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 40  3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 41  3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 42  3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 43  3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 44  3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 45  3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 46  3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 47  3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 48  3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 49  3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 50  3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 51  3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 52  3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 53  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 54  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 55  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 56  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 57  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 58  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 59  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 60  3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 61  3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 62  3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 63  3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 64  3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 65  3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 66  3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 67  3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 68  3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 69  3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 70  3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 71  3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 72  3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 73  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 74  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 75  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 76  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 77  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 78  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 79  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 80  3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 81  3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 82  3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 83  3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 84  3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 85  3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 86  3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 87  3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 88  3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 89  3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 90  3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 91  3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 92  3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 93  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 94  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 95  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 96  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 97  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 98  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 99  3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 100 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 101 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 102 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 103 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 104 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 105 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 106 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 107 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 108 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 109 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 110 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 111 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 112 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 113 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 114 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 115 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 116 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 117 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 118 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 119 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 120 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 121 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 122 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 123 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 124 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 125 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 126 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 127 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 128 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 129 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 130 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 131 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 132 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 133 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 134 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 135 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 136 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 137 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 138 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 139 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 140 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 141 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 142 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 143 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 144 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 145 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 146 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 147 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 148 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 149 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 150 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 151 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 152 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 153 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 154 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 155 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 156 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 157 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 158 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 159 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 160 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 161 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 162 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 163 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 164 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 165 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 166 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 167 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 168 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 169 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 170 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 171 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 172 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 173 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 174 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 175 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 176 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 177 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 178 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 179 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 180 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 181 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 182 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 183 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 184 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 185 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 186 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 187 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 188 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 189 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 190 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 191 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 192 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 193 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 194 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 195 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 196 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 197 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 198 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 199 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 200 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 201 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 202 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 203 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 204 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 205 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 206 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 207 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 208 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 209 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 210 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 211 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 212 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 213 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 214 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 215 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 216 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 217 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 218 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 219 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 220 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 221 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 222 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 223 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 224 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 225 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 226 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 227 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 228 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 229 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 230 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 231 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 232 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 233 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 234 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 235 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 236 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 237 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 238 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 239 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 240 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 241 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 242 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 243 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 244 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 245 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 246 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 247 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 248 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 249 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 250 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 251 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 252 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 253 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 254 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 255 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 256 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 257 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 258 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 259 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 260 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 261 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 262 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 263 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 264 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 265 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 266 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 267 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 268 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 269 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 270 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 271 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 272 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 273 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 274 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 275 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 276 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 277 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 278 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 279 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 280 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 281 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 282 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 283 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 284 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 285 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 286 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 287 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 288 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 289 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 290 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 291 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 292 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 293 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 294 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 295 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 296 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 297 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 298 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 299 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 300 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 301 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 302 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 303 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 304 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 305 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 306 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 307 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 308 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 309 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 310 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 311 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 312 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 313 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 314 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 315 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 316 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 317 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 318 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 319 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 320 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 321 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 322 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 323 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 324 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 325 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 326 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 327 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 328 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 329 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 330 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 331 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 332 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 333 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 334 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 335 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 336 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 337 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 338 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 339 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 340 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 341 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 342 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 343 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 344 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 345 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 346 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 347 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 348 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 349 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 350 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 351 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 352 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 353 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 354 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 355 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 356 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 357 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 358 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 359 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 360 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 361 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 362 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 363 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 364 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 365 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 366 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 367 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 368 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 369 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 370 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 371 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 372 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 373 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 374 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 375 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 376 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 377 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 378 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 379 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 380 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 381 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 382 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 383 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 384 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 385 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 386 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 387 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 388 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 389 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 390 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 391 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 392 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 393 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 394 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 395 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 396 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 397 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 398 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 399 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 400 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 401 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 402 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 403 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 404 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 405 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 406 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 407 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 408 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 409 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 410 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 411 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 412 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 413 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 414 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 415 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 416 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 417 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 418 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 419 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 420 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 421 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 422 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 423 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 424 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 425 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 426 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 427 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 428 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 429 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 430 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 431 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 432 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 433 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 434 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 435 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 436 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 437 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 438 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 439 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 440 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 441 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 442 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 443 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 444 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 445 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 446 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 447 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 448 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 449 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 450 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 451 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 452 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 453 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 454 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 455 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 456 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 457 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 458 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 459 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 460 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 461 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 462 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 463 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 464 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 465 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 466 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 467 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 468 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 469 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 470 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 471 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 472 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 473 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 474 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 475 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 476 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 477 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 478 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 479 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 480 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 481 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 482 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 483 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 484 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 485 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 486 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 487 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 488 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 489 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 490 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 491 3DCoat                                   0x10105926c BaseWidget::CallPaintCallbacks() + 88 492 3DCoat                                   0x101058fbc BaseWidget::_draw() + 288 493 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 494 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 495 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 496 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 497 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 498 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 499 3DCoat                                   0x1010590bc BaseWidget::_draw() + 544 500 3DCoat                                   0x10105dcb4 Widgets::DrawWidgets() + 580 501 3DCoat                                   0x10107d560 IntfWidget2::OnRender() + 176 502 3DCoat                                   0x100d5cfb4 comms::cWidgets::Render(int) + 164 503 3DCoat                                   0x101946f5c comms::cMain_OnRender(comms::cRect const&) + 540 504 3DCoat                                   0x100d648e8 cMacMain_OneIterationOfMessageLoop() + 1708 505 3DCoat                                   0x100d6b2f4 ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*) + 60 506 3DCoat                                   0x101ebeee0 ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>) + 600 507 3DCoat                                   0x101aea5f8 TextureKeeper::Activate() + 336 508 3DCoat                                   0x101afa86c TextureKeeper::UpdatePreview() + 96 509 3DCoat                                   0x101afaf64 tkDrawPnPreview(long) + 156 510 3DCoat                                   0x1000f8580 _tcallback<void>::call() + 228 Thread 1: 0   libsystem_pthread.dylib                  0x18c42eb6c start_wqthread + 0 Thread 2: 0   libsystem_pthread.dylib                  0x18c42eb6c start_wqthread + 0 Thread 3: 0   libsystem_kernel.dylib                   0x18c3f51c8 __semwait_signal + 8 1   libsystem_c.dylib                        0x18c2d16f4 nanosleep + 220 2   libc++.1.dylib                           0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3   3DCoat                                   0x1013c64a0 comms::SavingThread() + 56 4   3DCoat                                   0x1013ae6a8 void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, void (*)()>>(void*) + 52 5   libsystem_pthread.dylib                  0x18c433bc8 _pthread_start + 136 6   libsystem_pthread.dylib                  0x18c42eb80 thread_start + 8 Thread 4: 0   libsystem_kernel.dylib                   0x18c3fa46c __accept + 8 1   3DCoat                                   0x1013dc324 httpListenThread(void*) + 300 2   libsystem_pthread.dylib                  0x18c433bc8 _pthread_start + 136 3   libsystem_pthread.dylib                  0x18c42eb80 thread_start + 8 Thread 5: 0   libsystem_kernel.dylib                   0x18c3f51c8 __semwait_signal + 8 1   libsystem_c.dylib                        0x18c2d16f4 nanosleep + 220 2   libc++.1.dylib                           0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3   3DCoat                                   0x101e467b0 FileWaitThread(void*) + 112 4   libsystem_pthread.dylib                  0x18c433bc8 _pthread_start + 136 5   libsystem_pthread.dylib                  0x18c42eb80 thread_start + 8 Thread 6:: com.apple.NSEventThread 0   libsystem_kernel.dylib                   0x18c3f1c34 mach_msg2_trap + 8 1   libsystem_kernel.dylib                   0x18c404338 mach_msg2_internal + 76 2   libsystem_kernel.dylib                   0x18c3fa764 mach_msg_overwrite + 484 3   libsystem_kernel.dylib                   0x18c3f1fa8 mach_msg + 24 4   CoreFoundation                           0x18c51ec0c __CFRunLoopServiceMachPort + 160 5   CoreFoundation                           0x18c51d528 __CFRunLoopRun + 1208 6   CoreFoundation                           0x18c51c9e8 CFRunLoopRunSpecific + 572 7   AppKit                                   0x19056178c _NSEventThread + 140 8   libsystem_pthread.dylib                  0x18c433bc8 _pthread_start + 136 9   libsystem_pthread.dylib                  0x18c42eb80 thread_start + 8 Thread 7: 0   libsystem_kernel.dylib                   0x18c3f51c8 __semwait_signal + 8 1   libsystem_c.dylib                        0x18c2d16f4 nanosleep + 220 2   libc++.1.dylib                           0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3   3DCoat                                   0x100191f6c CheckFileThread(void*) + 184 4   libsystem_pthread.dylib                  0x18c433bc8 _pthread_start + 136 5   libsystem_pthread.dylib                  0x18c42eb80 thread_start + 8 Thread 8: 0   libsystem_kernel.dylib                   0x18c3f51c8 __semwait_signal + 8 1   libsystem_c.dylib                        0x18c2d16f4 nanosleep + 220 2   libc++.1.dylib                           0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3   3DCoat                                   0x1017a1780 void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, CaptureTrajectory::CaptureTrajectory()::$_0>>(void*) + 228 4   libsystem_pthread.dylib                  0x18c433bc8 _pthread_start + 136 5   libsystem_pthread.dylib                  0x18c42eb80 thread_start + 8 Thread 9: 0   libsystem_kernel.dylib                   0x18c3f51c8 __semwait_signal + 8 1   libsystem_c.dylib                        0x18c2d16f4 nanosleep + 220 2   libc++.1.dylib                           0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3   3DCoat                                   0x1013ae548 void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, fn_POST_RENDERlic()::$_1>>(void*) + 224 4   libsystem_pthread.dylib                  0x18c433bc8 _pthread_start + 136 5   libsystem_pthread.dylib                  0x18c42eb80 thread_start + 8 Thread 10: 0   libsystem_kernel.dylib                   0x18c3f6158 __recvfrom + 8 1   3DCoat                                   0x1013a9a64 GetNeighbourPackets() + 224 2   3DCoat                                   0x1013ae6a8 void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, void (*)()>>(void*) + 52 3   libsystem_pthread.dylib                  0x18c433bc8 _pthread_start + 136 4   libsystem_pthread.dylib                  0x18c42eb80 thread_start + 8 Thread 11: 0   libsystem_kernel.dylib                   0x18c3f51c8 __semwait_signal + 8 1   libsystem_c.dylib                        0x18c2d16f4 nanosleep + 220 2   libc++.1.dylib                           0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3   3DCoat                                   0x1013ae740 void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, fn_POST_RENDERlic()::$_2>>(void*) + 88 4   libsystem_pthread.dylib                  0x18c433bc8 _pthread_start + 136 5   libsystem_pthread.dylib                  0x18c42eb80 thread_start + 8 Thread 12: 0   libsystem_kernel.dylib                   0x18c3f51c8 __semwait_signal + 8 1   libsystem_c.dylib                        0x18c2d16f4 nanosleep + 220 2   libc++.1.dylib                           0x18c365f38 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 84 3   3DCoat                                   0x1013aeb08 void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, fn_POST_RENDERlic()::$_3>>(void*) + 904 4   libsystem_pthread.dylib                  0x18c433bc8 _pthread_start + 136 5   libsystem_pthread.dylib                  0x18c42eb80 thread_start + 8 Thread 13: 0   libsystem_pthread.dylib                  0x18c42eb6c start_wqthread + 0 Thread 0 crashed with ARM Thread State (64-bit):     x0: 0x0000000000000000   x1: 0xffffec99bbc5287f   x2: 0xffffec99bbc5287f   x3: 0x0000000fffffc088     x4: 0x0000000000000000   x5: 0x000000016f5139a0   x6: 0x36323032206c6972   x7: 0xffffffff0011b500     x8: 0x0000000000000021   x9: 0x0000000000004300  x10: 0x000000016f50f700  x11: 0x000000016f510000    x12: 0x00000000016e3600  x13: 0x000000000003202a  x14: 0x0000000000000006  x15: 0x8f5c28f5c28f5c29    x16: 0x000000018c42eb84  x17: 0x00000001fb4293e8  x18: 0x0000000000000000  x19: 0x000000016f513b18    x20: 0x000000010286e9e8  x21: 0x0000000102861000  x22: 0x000000010262e000  x23: 0x000000010262e000    x24: 0x000000010262e188  x25: 0x0000000000000000  x26: 0x000000010263c000  x27: 0x000000010263c000    x28: 0x0000000102814000   fp: 0x000000016f513a40   lr: 0x000000010106832c     sp: 0x000000016f513a00   pc: 0x000000018c42ebc0 cpsr: 0x80001000    far: 0x000000016f50fff8  esr: 0x92000007 (Data Abort) byte read Translation fault Binary Images:        0x1000f4000 -        0x102417fff com.Pilgway.-DCoat (2026.01) <d392e462-7082-3703-892e-96a650c13893> /Applications/3DCoat-2026.01/3DCoat.app/Contents/MacOS/3DCoat        0x105430000 -        0x1057f3fff Python (*) <88bffd37-99d8-36ab-9b95-9f54b30bd667> /Applications/3DCoat-2026.01/3DCoat.app/Contents/MacOS/Python        0x1046b0000 -        0x104c0ffff libfbxsdk.dylib (*) <8206ed5d-f904-3e12-87a9-a14097f58481> /Applications/3DCoat-2026.01/3DCoat.app/Contents/MacOS/libfbxsdk.dylib        0x104624000 -        0x10462ffff libobjc-trampolines.dylib (*) <9a87f143-aa9d-3c46-b2e8-b3fb9215e33e> /usr/lib/libobjc-trampolines.dylib        0x110d60000 -        0x1113f7fff com.apple.AGXMetalG13X (329.2) <85754bfd-af86-38d8-997e-2a50a45ef2a0> /System/Library/Extensions/AGXMetalG13X.bundle/Contents/MacOS/AGXMetalG13X        0x105eb4000 -        0x105f1bfff com.apple.AppleMetalOpenGLRenderer (1.0) <993a7f68-a0cf-32ec-bd84-9a23cd55b5e2> /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer        0x105f50000 -        0x105f53fff _opcode.cpython-311-darwin.so (*) <5973ec29-8c62-3285-97ee-5797aef28b1c> /Users/USER/Documents/*/_opcode.cpython-311-darwin.so        0x1100a0000 -        0x1100b3fff _ctypes.cpython-311-darwin.so (*) <6c214dd2-6044-3285-949b-8d8ba72ca17b> /Users/USER/Documents/*/_ctypes.cpython-311-darwin.so        0x105fc8000 -        0x105fcffff _struct.cpython-311-darwin.so (*) <167d8231-8346-37b6-9d67-149a1fe3df21> /Users/USER/Documents/*/_struct.cpython-311-darwin.so        0x105f90000 -        0x105f9bfff math.cpython-311-darwin.so (*) <51d31d0d-1dcc-31ad-b6c1-73d57e544a3a> /Users/USER/Documents/*/math.cpython-311-darwin.so        0x18c42d000 -        0x18c439a77 libsystem_pthread.dylib (*) <c0519bf8-8fc4-3222-a4a7-d98af817277c> /usr/lib/system/libsystem_pthread.dylib                0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???        0x18c3f1000 -        0x18c42c5f3 libsystem_kernel.dylib (*) <bf2be9c2-05ea-372a-ad72-80441cad5380> /usr/lib/system/libsystem_kernel.dylib        0x18c2c4000 -        0x18c345247 libsystem_c.dylib (*) <89e4e823-2117-3e30-92da-4fdfec463893> /usr/lib/system/libsystem_c.dylib        0x18c346000 -        0x18c3d2ff7 libc++.1.dylib (*) <eb94c9fe-91da-3e9f-9c45-7b476feaaeae> /usr/lib/libc++.1.dylib        0x18c4a2000 -        0x18c9e0fff com.apple.CoreFoundation (6.9) <b670b809-77c2-36d2-ac51-eddc00ce8d74> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation        0x190403000 -        0x19189375f com.apple.AppKit (6.9) <93588b4a-92ed-31d5-941c-fde64e4b5ed8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit External Modification Summary:   Calls made by other processes targeting this process:     task_for_pid: 0     thread_create: 0     thread_set_state: 0   Calls made by this process:     task_for_pid: 0     thread_create: 0     thread_set_state: 0   Calls made by all processes on this machine:     task_for_pid: 42     thread_create: 0     thread_set_state: 792 VM Region Summary: ReadOnly portion of Libraries: Total=1.7G resident=0K(0%) swapped_out_or_unallocated=1.7G(100%) Writable regions: Total=1.2G written=8853K(1%) resident=1253K(0%) swapped_out=7600K(1%) unallocated=1.2G(99%)                                 VIRTUAL   REGION  REGION TYPE                        SIZE    COUNT (non-coalesced)  ===========                     =======  =======  Accelerate framework               128K        1  Activity Tracing                   256K        1  CG image                           784K        5  ColorSync                          608K       32  CoreAnimation                     1296K       25  CoreGraphics                        32K        2  CoreUI image data                  992K        7  Dispatch continuations            80.0M        1  Foundation                          16K        1  Kernel Alloc Once                   32K        1  MALLOC                             1.0G      116  MALLOC guard page                  288K       18  MALLOC_LARGE (reserved)           45.8M        1         reserved VM address space (unallocated) OpenGL GLSL                        256K        3  STACK GUARD                       56.2M       14  Stack                             15.0M       17  VM_ALLOCATE                       53.3M     2333  __AUTH                            5350K      681  __AUTH_CONST                      75.6M      924  __CTF                               824        1  __DATA                            29.7M      914  __DATA_CONST                      29.0M      941  __DATA_DIRTY                      2770K      338  __FONT_DATA                        2352        1  __GLSLBUILTINS                    5174K        1  __INFO_FILTER                         8        1  __LINKEDIT                       650.5M       11  __OBJC_RO                         61.4M        1  __OBJC_RW                         2397K        1  __TEXT                             1.0G      959  __TEXT (graphics)                 44.3M        3  __TPRO_CONST                       128K        2  mapped file                      258.7M       49  page table in kernel              1253K        1  shared memory                      976K       16  ===========                     =======  =======  TOTAL                              3.4G     7423  TOTAL, minus reserved VM space     3.4G     7423  ----------- Full Report ----------- {"app_name":"3DCoat","timestamp":"2026-04-29 00:44:52.00 +0200","app_version":"2026.01","slice_uuid":"d392e462-7082-3703-892e-96a650c13893","build_version":"1","platform":1,"bundleID":"com.Pilgway.-DCoat","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 15.7.5 (24G624)","roots_installed":0,"name":"3DCoat","incident_id":"272C19B5-897F-4439-AAA6-B0C0B20CE9A4"} {   "uptime" : 1600000,   "procRole" : "Foreground",   "version" : 2,   "userID" : 501,   "deployVersion" : 210,   "modelCode" : "MacBookPro18,3",   "coalitionID" : 279655,   "osVersion" : {     "train" : "macOS 15.7.5",     "build" : "24G624",     "releaseType" : "User"   },   "captureTime" : "2026-04-29 00:44:52.3086 +0200",   "codeSigningMonitor" : 1,   "incident" : "272C19B5-897F-4439-AAA6-B0C0B20CE9A4",   "pid" : 24617,   "translated" : false,   "cpuType" : "ARM-64",   "roots_installed" : 0,   "bug_type" : "309",   "procLaunch" : "2026-04-29 00:41:45.0400 +0200",   "procStartAbsTime" : 38753204011325,   "procExitAbsTime" : 38757697678934,   "procName" : "3DCoat",   "procPath" : "\/Applications\/3DCoat-2026.01\/3DCoat.app\/Contents\/MacOS\/3DCoat",   "bundleInfo" : {"CFBundleShortVersionString":"2026.01","CFBundleVersion":"1","CFBundleIdentifier":"com.Pilgway.-DCoat"},   "storeInfo" : {"deviceIdentifierForVendor":"B4EC1335-D606-5986-A13F-E8A0D8C6D7C0","thirdParty":true},   "parentProc" : "launchd",   "parentPid" : 1,   "coalitionName" : "com.Pilgway.-DCoat",   "crashReporterKey" : "F9229ABC-4732-A1D8-BEB3-C9B32A468FA6",   "appleIntelligenceStatus" : {"state":"unavailable","reasons":["selectedSiriLanguageIneligible","selectedLanguageIneligible"]},   "codeSigningID" : "com.Pilgway.-DCoat",   "codeSigningTeamID" : "T2DD9H2G7P",   "codeSigningFlags" : 570495745,   "codeSigningValidationCategory" : 6,   "codeSigningTrustLevel" : 4294967295,   "codeSigningAuxiliaryInfo" : 0,   "instructionByteStream" : {"beforePC":"S4Fd+OoDAJFfAQvrCQEAVEoBCeujAABUXwEL62MAAFTqL3+pwANf1g==","atPC":"a4Ff+OoDAJE\/BUDxwwAAVEoFQNFLAUD5KQVA0T8FQPGI\/\/9USgEJyw=="},   "bootSessionUUID" : "B25E2C84-D367-40CD-9E0B-31868C7D77AD",   "wakeTime" : 8049,   "sleepWakeUUID" : "97B0F65B-0D68-4C5D-A6D8-0342E11878C4",   "sip" : "enabled",   "vmRegionInfo" : "0x16f50fff8 is in 0x16bd0c000-0x16f510000;  bytes after start: 58736632  bytes before end: 7\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      MALLOC_TINY                 16bc00000-16bd00000    [ 1024K] rw-\/rwx SM=PRV  \n      GAP OF 0xc000 BYTES\n--->  STACK GUARD                 16bd0c000-16f510000    [ 56.0M] ---\/rwx SM=NUL  stack guard for thread 0\n      Stack                       16f510000-16fd0c000    [ 8176K] rw-\/rwx SM=SHM  thread 0",   "exception" : {"codes":"0x0000000000000002, 0x000000016f50fff8","rawCodes":[2,6162546680],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_PROTECTION_FAILURE at 0x000000016f50fff8"},   "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":24617},   "vmregioninfo" : "0x16f50fff8 is in 0x16bd0c000-0x16f510000;  bytes after start: 58736632  bytes before end: 7\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      MALLOC_TINY                 16bc00000-16bd00000    [ 1024K] rw-\/rwx SM=PRV  \n      GAP OF 0xc000 BYTES\n--->  STACK GUARD                 16bd0c000-16f510000    [ 56.0M] ---\/rwx SM=NUL  stack guard for thread 0\n      Stack                       16f510000-16fd0c000    [ 8176K] rw-\/rwx SM=SHM  thread 0",   "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":792,"task_for_pid":42},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},   "faultingThread" : 0,   "threads" : [{"triggered":true,"id":58927509,"threadState":{"x":[{"value":0},{"value":18446722743757252735},{"value":18446722743757252735},{"value":68719460488},{"value":0},{"value":6162561440},{"value":3905236818734115186},{"value":18446744069415744768},{"value":33},{"value":17152},{"value":6162544384},{"value":6162546688},{"value":24000000},{"value":204842},{"value":6},{"value":10330176681277348905},{"value":6648163204,"symbolLocation":0,"symbol":"___chkstk_darwin"},{"value":8510411752},{"value":0},{"value":6162561816},{"value":4337363432,"symbolLocation":0,"symbol":"IRS"},{"value":4337307648,"symbolLocation":528,"symbol":"bc"},{"value":4335001600,"symbolLocation":455,"symbol":"GetTextInFile(char const*, char const*)::s"},{"value":4335001600,"symbolLocation":455,"symbol":"GetTextInFile(char const*, char const*)::s"},{"value":4335001992,"symbolLocation":0,"symbol":"cMacMain_WindowedWindow"},{"value":0},{"value":4335058944,"symbolLocation":936,"symbol":"get_array_lecsems2(char const*, char**, char*, short)::strtmp"},{"value":4335058944,"symbolLocation":936,"symbol":"get_array_lecsems2(char const*, char**, char*, short)::strtmp"},{"value":4336992256,"symbolLocation":88,"symbol":"m_SmudgeTool"}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4312171308},"cpsr":{"value":2147487744},"fp":{"value":6162561600},"sp":{"value":6162561536},"esr":{"value":2449473543,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":6648163264,"matchesCrashFrame":1},"far":{"value":6162546680}},"queue":"com.apple.main-thread","frames":[{"imageOffset":7104,"symbol":"___chkstk_darwin","symbolLocation":60,"imageIndex":10},{"imageOffset":16204588,"symbol":"Widgets::DestroyDeadWidgets()","symbolLocation":40,"imageIndex":0},{"imageOffset":16204532,"symbol":"GlobalProcessWidgets()","symbolLocation":12,"imageIndex":0},{"imageOffset":25505236,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":148,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0},{"imageOffset":16142956,"symbol":"BaseWidget::CallPaintCallbacks()","symbolLocation":88,"imageIndex":0},{"imageOffset":16142268,"symbol":"BaseWidget::_draw()","symbolLocation":288,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16142524,"symbol":"BaseWidget::_draw()","symbolLocation":544,"imageIndex":0},{"imageOffset":16161972,"symbol":"Widgets::DrawWidgets()","symbolLocation":580,"imageIndex":0},{"imageOffset":16291168,"symbol":"IntfWidget2::OnRender()","symbolLocation":176,"imageIndex":0},{"imageOffset":13012916,"symbol":"comms::cWidgets::Render(int)","symbolLocation":164,"imageIndex":0},{"imageOffset":25505628,"symbol":"comms::cMain_OnRender(comms::cRect const&)","symbolLocation":540,"imageIndex":0},{"imageOffset":13043944,"symbol":"cMacMain_OneIterationOfMessageLoop()","symbolLocation":1708,"imageIndex":0},{"imageOffset":13071092,"symbol":"ProcessRenderCycle(bool (*)(BaseWidget*), BaseWidget*)","symbolLocation":60,"imageIndex":0},{"imageOffset":31239904,"symbol":"ShowModalMessageBox(char const*, char const*, StringsList&, unsigned int, BaseClass*, BaseWidget*, std::__1::function<void (int)>, int, int, int, bool, bool, bool, bool, std::__1::function<void (int)>)","symbolLocation":600,"imageIndex":0},{"imageOffset":27223544,"symbol":"TextureKeeper::Activate()","symbolLocation":336,"imageIndex":0},{"imageOffset":27289708,"symbol":"TextureKeeper::UpdatePreview()","symbolLocation":96,"imageIndex":0},{"imageOffset":27291492,"symbol":"tkDrawPnPreview(long)","symbolLocation":156,"imageIndex":0},{"imageOffset":17792,"symbol":"_tcallback<void>::call()","symbolLocation":228,"imageIndex":0}]},{"id":58927641,"frames":[{"imageOffset":7020,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":10}],"threadState":{"x":[{"value":6172618752},{"value":17155},{"value":6172082176},{"value":6172617600},{"value":5193734},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6172617488},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6648163180},"far":{"value":0}}},{"id":58927642,"frames":[{"imageOffset":7020,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":10}],"threadState":{"x":[{"value":6173192192},{"value":32003},{"value":6172655616},{"value":6173191040},{"value":5193732},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6173191024},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6648163180},"far":{"value":0}}},{"id":58927670,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":19735712,"symbol":"comms::SavingThread()","symbolLocation":56,"imageIndex":0},{"imageOffset":19637928,"symbol":"void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, void (*)()>>(void*)","symbolLocation":52,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":0},{"value":500000000},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":334},{"value":8510412152},{"value":0},{"value":6173765456},{"value":6173765456},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6173765440},"sp":{"value":6173765392},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58927673,"frames":[{"imageOffset":37996,"symbol":"__accept","symbolLocation":8,"imageIndex":12},{"imageOffset":19825444,"symbol":"httpListenThread(void*)","symbolLocation":300,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":6174912060},{"value":9876},{"value":6174912512},{"value":419432703},{"value":0},{"value":0},{"value":37926},{"value":43780},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":30},{"value":8510412248},{"value":0},{"value":9876},{"value":9},{"value":2},{"value":0},{"value":0},{"value":16},{"value":4337000448,"symbolLocation":8,"symbol":"pyBindPreprocessor::pyDefClasses"},{"value":4337010840,"symbolLocation":0,"symbol":"comms::cStr::def_str"},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4315792164},"cpsr":{"value":536875008},"fp":{"value":6174912448},"sp":{"value":6174912000},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647948396},"far":{"value":0}}},{"id":58927674,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":30746544,"symbol":"FileWaitThread(void*)","symbolLocation":112,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":1},{"value":0},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":1099511628034},{"value":256},{"value":1099511628032},{"value":7},{"value":92},{"value":334},{"value":8510412152},{"value":0},{"value":6175485712},{"value":6175485712},{"value":4335097510,"symbolLocation":0,"symbol":"ReadyList"},{"value":64},{"value":4329890718},{"value":0},{"value":4338429400,"symbolLocation":0,"symbol":"IsInExitState"},{"value":1000000000},{"value":4337010840,"symbolLocation":0,"symbol":"comms::cStr::def_str"},{"value":100000000}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6175485696},"sp":{"value":6175485648},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58927709,"name":"com.apple.NSEventThread","threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":247420181020672},{"value":0},{"value":247420181020672},{"value":2},{"value":4294967295},{"value":0},{"value":17179869184},{"value":0},{"value":2},{"value":0},{"value":0},{"value":57607},{"value":0},{"value":18446744073709551569},{"value":8510413912},{"value":0},{"value":4294967295},{"value":2},{"value":247420181020672},{"value":0},{"value":247420181020672},{"value":6176055432},{"value":8589934592},{"value":21592279046},{"value":18446744073709550527},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6647989048},"cpsr":{"value":4096},"fp":{"value":6176055280},"sp":{"value":6176055200},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647913524},"far":{"value":0}},"frames":[{"imageOffset":3124,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":12},{"imageOffset":78648,"symbol":"mach_msg2_internal","symbolLocation":76,"imageIndex":12},{"imageOffset":38756,"symbol":"mach_msg_overwrite","symbolLocation":484,"imageIndex":12},{"imageOffset":4008,"symbol":"mach_msg","symbolLocation":24,"imageIndex":12},{"imageOffset":510988,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":15},{"imageOffset":505128,"symbol":"__CFRunLoopRun","symbolLocation":1208,"imageIndex":15},{"imageOffset":502248,"symbol":"CFRunLoopRunSpecific","symbolLocation":572,"imageIndex":15},{"imageOffset":1435532,"symbol":"_NSEventThread","symbolLocation":140,"imageIndex":16},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}]},{"id":58927710,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":647020,"symbol":"CheckFileThread(void*)","symbolLocation":184,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":1},{"value":0},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":334},{"value":8510412152},{"value":0},{"value":6176632656},{"value":6176632656},{"value":2},{"value":1000000000},{"value":4335104000,"symbolLocation":40,"symbol":"AppExchange::LastExportParams"},{"value":4337010840,"symbolLocation":0,"symbol":"comms::cStr::def_str"},{"value":1},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6176632640},"sp":{"value":6176632592},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58927812,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":23779200,"symbol":"void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, CaptureTrajectory::CaptureTrajectory()::$_0>>(void*)","symbolLocation":228,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":0},{"value":3000000},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":2},{"value":0},{"value":0},{"value":8759},{"value":5624889344},{"value":334},{"value":8510412152},{"value":0},{"value":6177206096},{"value":6177206096},{"value":4337033216,"symbolLocation":32,"symbol":"DrawMod"},{"value":4336994024,"symbolLocation":0,"symbol":"Widgets::CurrentTime"},{"value":3000000},{"value":50000000},{"value":4336994040,"symbolLocation":0,"symbol":"Widgets::WholeScreen"},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6177206080},"sp":{"value":6177206032},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58927854,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":19637576,"symbol":"void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, fn_POST_RENDERlic()::$_1>>(void*)","symbolLocation":224,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":60},{"value":0},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":1099511628034},{"value":256},{"value":1099511628032},{"value":5554323584},{"value":320464},{"value":334},{"value":8510412152},{"value":0},{"value":6178352960},{"value":6178352960},{"value":4338429400,"symbolLocation":0,"symbol":"IsInExitState"},{"value":6178353012},{"value":4335022080,"symbolLocation":40,"symbol":"_MergedGlobals"},{"value":60000000000},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6178352944},"sp":{"value":6178352896},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58927855,"frames":[{"imageOffset":20824,"symbol":"__recvfrom","symbolLocation":8,"imageIndex":12},{"imageOffset":19618404,"symbol":"GetNeighbourPackets()","symbolLocation":224,"imageIndex":0},{"imageOffset":19637928,"symbol":"void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, void (*)()>>(void*)","symbolLocation":52,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":128},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":50051},{"value":4337003952,"symbolLocation":0,"symbol":"LiDat"},{"value":18446744067062209551},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":29},{"value":8510412128},{"value":0},{"value":14},{"value":6178926320},{"value":0},{"value":329757913},{"value":6178926192},{"value":4337000448,"symbolLocation":8,"symbol":"pyBindPreprocessor::pyDefClasses"},{"value":1},{"value":6178926160},{"value":4338429400,"symbolLocation":0,"symbol":"IsInExitState"},{"value":5000000000}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4315585124},"cpsr":{"value":2684358656},"fp":{"value":6178926480},"sp":{"value":6178926160},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647931224},"far":{"value":0}}},{"id":58927856,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":19638080,"symbol":"void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, fn_POST_RENDERlic()::$_2>>(void*)","symbolLocation":88,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":243},{"value":0},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":334},{"value":8510412152},{"value":0},{"value":6179499904},{"value":6179499904},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6179499888},"sp":{"value":6179499840},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58927857,"frames":[{"imageOffset":16840,"symbol":"__semwait_signal","symbolLocation":8,"imageIndex":12},{"imageOffset":55028,"symbol":"nanosleep","symbolLocation":220,"imageIndex":13},{"imageOffset":130872,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&)","symbolLocation":84,"imageIndex":14},{"imageOffset":19639048,"symbol":"void* std::__1::__thread_proxy[abi:ne200100]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, fn_POST_RENDERlic()::$_3>>(void*)","symbolLocation":904,"imageIndex":0},{"imageOffset":27592,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":10},{"imageOffset":7040,"symbol":"thread_start","symbolLocation":8,"imageIndex":10}],"threadState":{"x":[{"value":4},{"value":0},{"value":1},{"value":1},{"value":5},{"value":0},{"value":52},{"value":0},{"value":8493315352,"symbolLocation":0,"symbol":"clock_sem"},{"value":16387},{"value":17},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":334},{"value":8510412152},{"value":0},{"value":6180073216},{"value":6180073216},{"value":30000000000},{"value":0},{"value":5000000000},{"value":3000000000},{"value":0},{"value":4337010840,"symbolLocation":0,"symbol":"comms::cStr::def_str"},{"value":4338429400,"symbolLocation":0,"symbol":"IsInExitState"},{"value":1000000000}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6646732532},"cpsr":{"value":1610616832},"fp":{"value":6180073200},"sp":{"value":6180073152},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6647927240},"far":{"value":0}}},{"id":58931819,"frames":[{"imageOffset":7020,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":10}],"threadState":{"x":[{"value":6205632512},{"value":53887},{"value":6205095936},{"value":6205631360},{"value":5193732},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6205631344},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6648163180},"far":{"value":0}}}],   "usedImages" : [   {     "source" : "P",     "arch" : "arm64",     "base" : 4295966720,     "CFBundleShortVersionString" : "2026.01",     "CFBundleIdentifier" : "com.Pilgway.-DCoat",     "size" : 36847616,     "uuid" : "d392e462-7082-3703-892e-96a650c13893",     "path" : "\/Applications\/3DCoat-2026.01\/3DCoat.app\/Contents\/MacOS\/3DCoat",     "name" : "3DCoat",     "CFBundleVersion" : "1"   },   {     "source" : "P",     "arch" : "arm64",     "base" : 4383244288,     "size" : 3948544,     "uuid" : "88bffd37-99d8-36ab-9b95-9f54b30bd667",     "path" : "\/Applications\/3DCoat-2026.01\/3DCoat.app\/Contents\/MacOS\/Python",     "name" : "Python"   },   {     "source" : "P",     "arch" : "arm64",     "base" : 4369088512,     "size" : 5636096,     "uuid" : "8206ed5d-f904-3e12-87a9-a14097f58481",     "path" : "\/Applications\/3DCoat-2026.01\/3DCoat.app\/Contents\/MacOS\/libfbxsdk.dylib",     "name" : "libfbxsdk.dylib"   },   {     "source" : "P",     "arch" : "arm64e",     "base" : 4368515072,     "size" : 49152,     "uuid" : "9a87f143-aa9d-3c46-b2e8-b3fb9215e33e",     "path" : "\/usr\/lib\/libobjc-trampolines.dylib",     "name" : "libobjc-trampolines.dylib"   },   {     "source" : "P",     "arch" : "arm64e",     "base" : 4577427456,     "CFBundleShortVersionString" : "329.2",     "CFBundleIdentifier" : "com.apple.AGXMetalG13X",     "size" : 6914048,     "uuid" : "85754bfd-af86-38d8-997e-2a50a45ef2a0",     "path" : "\/System\/Library\/Extensions\/AGXMetalG13X.bundle\/Contents\/MacOS\/AGXMetalG13X",     "name" : "AGXMetalG13X",     "CFBundleVersion" : "329.2"   },   {     "source" : "P",     "arch" : "arm64e",     "base" : 4394270720,     "CFBundleShortVersionString" : "1.0",     "CFBundleIdentifier" : "com.apple.AppleMetalOpenGLRenderer",     "size" : 425984,     "uuid" : "993a7f68-a0cf-32ec-bd84-9a23cd55b5e2",     "path" : "\/System\/Library\/Extensions\/AppleMetalOpenGLRenderer.bundle\/Contents\/MacOS\/AppleMetalOpenGLRenderer",     "name" : "AppleMetalOpenGLRenderer",     "CFBundleVersion" : "1"   },   {     "source" : "P",     "arch" : "arm64",     "base" : 4394909696,     "size" : 16384,     "uuid" : "5973ec29-8c62-3285-97ee-5797aef28b1c",     "path" : "\/Users\/USER\/Documents\/*\/_opcode.cpython-311-darwin.so",     "name" : "_opcode.cpython-311-darwin.so"   },   {     "source" : "P",     "arch" : "arm64",     "base" : 4564058112,     "size" : 81920,     "uuid" : "6c214dd2-6044-3285-949b-8d8ba72ca17b",     "path" : "\/Users\/USER\/Documents\/*\/_ctypes.cpython-311-darwin.so",     "name" : "_ctypes.cpython-311-darwin.so"   },   {     "source" : "P",     "arch" : "arm64",     "base" : 4395401216,     "size" : 32768,     "uuid" : "167d8231-8346-37b6-9d67-149a1fe3df21",     "path" : "\/Users\/USER\/Documents\/*\/_struct.cpython-311-darwin.so",     "name" : "_struct.cpython-311-darwin.so"   },   {     "source" : "P",     "arch" : "arm64",     "base" : 4395171840,     "size" : 49152,     "uuid" : "51d31d0d-1dcc-31ad-b6c1-73d57e544a3a",     "path" : "\/Users\/USER\/Documents\/*\/math.cpython-311-darwin.so",     "name" : "math.cpython-311-darwin.so"   },   {     "source" : "P",     "arch" : "arm64e",     "base" : 6648156160,     "size" : 51832,     "uuid" : "c0519bf8-8fc4-3222-a4a7-d98af817277c",     "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",     "name" : "libsystem_pthread.dylib"   },   {     "size" : 0,     "source" : "A",     "base" : 0,     "uuid" : "00000000-0000-0000-0000-000000000000"   },   {     "source" : "P",     "arch" : "arm64e",     "base" : 6647910400,     "size" : 243188,     "uuid" : "bf2be9c2-05ea-372a-ad72-80441cad5380",     "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",     "name" : "libsystem_kernel.dylib"   },   {     "source" : "P",     "arch" : "arm64e",     "base" : 6646677504,     "size" : 528968,     "uuid" : "89e4e823-2117-3e30-92da-4fdfec463893",     "path" : "\/usr\/lib\/system\/libsystem_c.dylib",     "name" : "libsystem_c.dylib"   },   {     "source" : "P",     "arch" : "arm64e",     "base" : 6647209984,     "size" : 577528,     "uuid" : "eb94c9fe-91da-3e9f-9c45-7b476feaaeae",     "path" : "\/usr\/lib\/libc++.1.dylib",     "name" : "libc++.1.dylib"   },   {     "source" : "P",     "arch" : "arm64e",     "base" : 6648635392,     "CFBundleShortVersionString" : "6.9",     "CFBundleIdentifier" : "com.apple.CoreFoundation",     "size" : 5500928,     "uuid" : "b670b809-77c2-36d2-ac51-eddc00ce8d74",     "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",     "name" : "CoreFoundation",     "CFBundleVersion" : "3603.1.407"   },   {     "source" : "P",     "arch" : "arm64e",     "base" : 6715092992,     "CFBundleShortVersionString" : "6.9",     "CFBundleIdentifier" : "com.apple.AppKit",     "size" : 21563232,     "uuid" : "93588b4a-92ed-31d5-941c-fde64e4b5ed8",     "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",     "name" : "AppKit",     "CFBundleVersion" : "2575.70.55"   } ],   "sharedCache" : {   "base" : 6643515392,   "size" : 5039767552,   "uuid" : "bbc7de5b-a6f2-3c3b-9bd5-c3e69c75bc82" },   "vmSummary" : "ReadOnly portion of Libraries: Total=1.7G resident=0K(0%) swapped_out_or_unallocated=1.7G(100%)\nWritable regions: Total=1.2G written=8853K(1%) resident=1253K(0%) swapped_out=7600K(1%) unallocated=1.2G(99%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               128K        1 \nActivity Tracing                   256K        1 \nCG image                           784K        5 \nColorSync                          608K       32 \nCoreAnimation                     1296K       25 \nCoreGraphics                        32K        2 \nCoreUI image data                  992K        7 \nDispatch continuations            80.0M        1 \nFoundation                          16K        1 \nKernel Alloc Once                   32K        1 \nMALLOC                             1.0G      116 \nMALLOC guard page                  288K       18 \nMALLOC_LARGE (reserved)           45.8M        1         reserved VM address space (unallocated)\nOpenGL GLSL                        256K        3 \nSTACK GUARD                       56.2M       14 \nStack                             15.0M       17 \nVM_ALLOCATE                       53.3M     2333 \n__AUTH                            5350K      681 \n__AUTH_CONST                      75.6M      924 \n__CTF                               824        1 \n__DATA                            29.7M      914 \n__DATA_CONST                      29.0M      941 \n__DATA_DIRTY                      2770K      338 \n__FONT_DATA                        2352        1 \n__GLSLBUILTINS                    5174K        1 \n__INFO_FILTER                         8        1 \n__LINKEDIT                       650.5M       11 \n__OBJC_RO                         61.4M        1 \n__OBJC_RW                         2397K        1 \n__TEXT                             1.0G      959 \n__TEXT (graphics)                 44.3M        3 \n__TPRO_CONST                       128K        2 \nmapped file                      258.7M       49 \npage table in kernel              1253K        1 \nshared memory                      976K       16 \n===========                     =======  ======= \nTOTAL                              3.4G     7423 \nTOTAL, minus reserved VM space     3.4G     7423 \n",   "legacyInfo" : {   "threadTriggered" : {     "queue" : "com.apple.main-thread"   } },   "logWritingSignature" : "f0ac1de52e9b5fdb95c328d9b4ffe7f307c813f4",   "trialInfo" : {   "rollouts" : [     {       "rolloutId" : "65a8173205d942272410674b",       "factorPackIds" : {         "SIRI_HOME_AUTOMATION_SERVER_FLOW_DEPRECATION" : "65d39fa4cb0e2417d11ce5f6"       },       "deploymentId" : 240000001     },     {       "rolloutId" : "64628732bf2f5257dedc8988",       "factorPackIds" : {       },       "deploymentId" : 240000001     }   ],   "experiments" : [   ] } }
    • Elemeno
      need a polish brush that works properly for polishing hard surfaces
    • stabbedbyapanda
      Oh ok, thank you. Do you know if this is isolated to just textura? or if its in 3D coat as well
      Hello This issue was reported as bug to developers. Thanks for point it up.
    • stabbedbyapanda
      Am I really the only person having this issue? Do staff or mods browse the forums to help people?
