Hey! So i have checked all my projects with earlier version (2025.10) and it is working as intended
I guess 2025.11 just dont work for me.. Also, forgot to mmention - I am using 3D Coat Textura, not regular one
To apply an alpha brush along a curve around a curved surface in 3DCoat, you should use the Curves tool in the Paint Room or the Curves editor to define the curve path, then apply your alpha to it, ensuring the curve follows the object's local space.
I've been use this link. It works up to Blender 4.5.3. (Fails in 5.0 alpha. Sends ok but get back fails.) Could be the alpha version.
https://github.com/AndrewShpagin/io-coat3d
Where can i find this fixed version ? Dont find it in extensions.blender.org anymore. The "Pointer to 3dcoat Applink" in link above is also not working here. Sorry, maybe im just too blind to find it. And would it also work with 2024.31 or do i have to be on 3DC 2025 ?
I'm having a bit of trouble with 2025.11 in Windows 11. I have an RTX 4070ti super and 128 gigs of ram.
I have a PPP model and I want to rebuild the cavity map and the ambient occlusion. I've tried deleting them, and then recreating - 3DC immediately crashes. I then have tried to select the layer with the existing map and recreate it, and the same thing happens. Immediate crash. Attached is a screen grab for the crash I am seeing.
Any idea on what I can do to fix it? I'm supposed to be presenting this tomorrow evening, so any help would be appreciated.
Paul Griswold
Assistant Professor of Animation
MTSU - the #1 Animation Program in TN!
