    • Sal_GC
      I have tried to use it many times and I find it interesting but really haven't got around it so far. I am waiting and see what they have in mind with it.
    • stabbedbyapanda
      Ty Carlosan for the suggestion. Sadly im trying to do handpainted textures and the single polygon stroke is basically face select/fill which is useful to know! (Didnt know about it.) Also I noticed some weird behavior with it too, when painting with it as well from an angle. I'm starting to wonder if these are bugs just within Textura. Or if there is some weird camera setting overriding Connective painting. If Connective painting just worked then i would be find :/ https://gyazo.com/f26b6ee54dc613905aec006bf10111e5
    • Elemeno
      its jsut pointless , it doesnt serve a purpose
    • Sal_GC
      This is a huge leap for 3D Coat! I have been a 3DC user for years and I have always tested every new build that comes out and this new feature is one of my most expected capabilities over the years. This would definitely increase the polish/speed/quality of texturing in3DC. This would cut reliance on stencils and their resolution, making texturing a much more flexible process with procedurals + stencils, all running on the GPU. Great! Instamat does the substance painter+designer combo, but it doesnt come close to 3DC's fine control for texture painting. It is a great material authoring tool, and it coming with a painter is great, no doubt about it, but 3D Coat lets you also produce geometry, which for a game artist, is unvaluable. The more 3DC improves and polishes the modelling tools, the lesser roundtrips, the 1 app workflow would be almost complete for game prop artists. 3DC + Blender + Cascadeur + UE = gold.    Hopefully we could get some AA in viewport with the new GPU capabilities, without having to go render room. Great news, I hope the team can really consolidate this major change.
    • AbnRanger
      And the problem with that is...?
    • Elemeno
      hopefully its not the smart hybrid lol
    • stabbedbyapanda
      Program: 3D Coat Textura Issue: Connective Painting stops working all together for certain models, works when I have a Test Model. Also Edges are constantly bleeding around edges, seems theres no tool to restrict on planes of faces, besides selection and hiding, which is really inconvenient and slow. Im trying to learn this software... but honestly this issue has blocked my progress every step of the way. I did a bunch of research and googling and tutorial watching last week, trying to fix it, with no luck. Then I tried making a test model just to see if maybe there was something wrong with the original model and for some reason it suddenly started working.. that is connective painting. Now once again it's not working i made a new model and it stopped working. Posting a Gif link below. This link shows the uv unwrap that i have at the end as well. Since it seems like im the only user to ever have this issue it must be something i'm doing but I have no idea. Only thing I can think of is maybe UVs. I tried asking for help on another Discord for a few days, with no real luck. https://gyazo.com/2a49d3a335a2be0b6ef1b123e6fe5c2a   Any help is appreciated!
    • SERGYI
      Hello. Thank you for your detailed steps for reproducing the problem. I repeated them 6 times before I was able to crash 3DCoat in the Debug build under Xcode. The crash happened inside the OpenGL function glReadPixels. The output error message in Xcode is: Terminating due to blacklisting by kernel driver. The source code around the call is correct. I have described the problem to Copilot. Here are some phrases from its answer: This crash is not caused by your code but by Apple's GPU driver on macOS arm64. The "Terminating due to blacklisting by kernel driver" message indicates that the driver detected an unsafe or unsupported OpenGL call sequence and forcibly killed the process. It's a rare, intermittent bug in Apple's OpenGL stack, especially when using glReadPixels under heavy load or with certain pixel formats. Apple has deprecated OpenGL in favor of Metal. The OpenGL implementation is no longer actively maintained, so rare crashes like this persist. glReadPixels stalls the GPU pipeline and copies framebuffer data back to CPU memory. If called at the wrong time, the driver may flag it as unsafe. Since Apple no longer supports OpenGL, you cannot rely on future fixes. For long-term stability on macOS, consider migrating to Metal. The answer indirectly explains why reducing "Desired vertex count" mitigates the problem. Because it reduces the load and thus the likelihood that the graphics driver will flag the operation as unsafe. I have no quick workaround for this problem today. Migrating to Metal is unreal because 3DCoat is developed exclusively under Windows, so all programmers work only with OpenGL and GLSL.
    • AbnRanger
      They absolutely are working on it. It's my understanding that the developer (Alexander) who has been working on the Retopo/Modeling tools...with a CAD development background...has been and continues to work on a CAD module which will function very similar to Plasticity, and the module will provide a smooth workflow between Solid Surface and Polygonal/Voxel Modeling environments. In the meantime, you can use some NURBS style tools in the Modeling workspace (in the Sculpt Workspace too, in the CURVES section of the tool panel) and convert those to geometry or NURBS/Solid Surface export.
    • Mihu83
      Pretty cool, but I hope it won't become a resource hog, because 3DC can already be heavy with GPU usage.
    • DustyShinigami
      Okay. I suspect I may have to do it in Maya. I did try adding a bit more thickness this time, but yeah, the edges/distance is fairly close. Thanks.
      yes, try this but if the model is very small or the front and back faces are very close... will be a difficult task
    • DustyShinigami
      Is this in 2025 or 2026? EDIT: Wait, never mind. I thought it was a totally different Snap option from its drop-down list. You mean to enable Snap to Closest Normal and add Additional Extrusion...?
    • DustyShinigami
      I don't suppose there's a way of preventing points/geo from automatically snapping to points that are behind it? I'm working on an item of clothing and I've had to add thickness. The problem is, every time I re-add/build the geo on the front, it keeps snapping to the geo behind. You can usually see/feel that snap when directly over a point behind, at which point you have to place it out the way, but sometimes it can still force it to snap through. I've tried unticking Auto Snap, changing the Snap type, and I have backface culling enabled, but nothing seems to work. Thanks
    • OutOfShadow
      Very exciting. I hope they'll also add the CAD tools at some point. Would be very useful for hard surface stuff. Then I can skip substance and plasticity.
    • DustyShinigami
      After deleting the coloured faces, it allows me to remove the red seams. It's just strange it doesn't allow me to remove the red seams with faces there.
