An RTX A2000 12GB should handle 3D-Coat comfortably, and the fact that sometimes only 3D-Coat crashes while other times Windows itself crashes points toward a lower-level problem (driver, hardware, power, or graphics API) rather than a graphics settings issue.
Windows 3DCoat 2026.09 RC
Portable 3DCoat, 3DCoat Textura, 3DCoat Print
Jul 20 2026
- Fixed an issue where shader previews would incorrectly render as black or solid white, ensuring that your custom color, gloss, metalness, and emissive settings are now accurately displayed.
- Procedural node-based materials now correctly respect layer color blend modes
- Selecting blending modes like Normal Map, Emissive, or Occlusion will no longer automatically change your selected Color Channel, while still rendering exactly as expected.
- When using the 'Convert To Object Nodes' menu item to convert old smart materials into nodes, textures like Color, Depth, and Gloss are now automatically created as separate, minimized UVW texture nodes and connected to the material, giving you more flexibility to edit them.
- Fixed print shader
- Fixed Emissive in PBM shader
- Fixed toon shader
OK! That worked, thank you very much. Sorry for all the questions, but you must admit, to a newcomer, trying to understand 3d coat is like climbing a flat wall. There are no logical clues about what to do and how, I have to say.
Well, I imported the mesh, and it's editable! But now, when I simply move a polygon on a low-poly object, it's extremely slow. Clearly it's trying to compute something in the background, or something. Also I know this is a "retopo" mesh (Is it trying to find a base mesh that's not there?). So it seems I still have to do something different to do simple modeling operations.
I'll ask one last question, if you can help Carlosan. And that's do I need to do something to put this model into "normal low poly modeling mode?" Otherwise I can't do anything with it.
Like I said, maybe I'm trying to use 3d coat in a way that it's not meant to be - but man.... I wish there were some more standard operations or normal functionality, like "import a mesh and start modeling on it" without all these strange steps. It's frustrating.
Carrots:
The MatCap shader hasn't changed since 2022; you can easily remove that highlight by deleting the line C.xyz+=vec3(fr2,fr2,fr2); or by downloading the GLSL file attached.
mcubes.glsl
Windows 3DCoat 2026.08 RC
3DCoat-2026-08.exe
3DCoatTextura-2026-08.exe
3DCoatPrint-2026-08.exe
- Added the new inGizmoTransform node, which connects to the UVWTexture, TriPlanar, and FragCoord nodes to control texture position, rotation, and scaling.
- Selecting a node with transform properties now automatically spawns an interactive 3D Gizmo in the viewport, letting you visually move, rotate, and scale it in perfect, two-way sync with the node's numeric values.
- Fixed an issue in the node graph where a locked preview would prevent you from temporarily previewing other nodes by hovering over them with Ctrl pressed.
- Fixed a bug in orthographic projection where models would only update after releasing the brush stroke, as the camera's performance optimization incorrectly assumed the model was out of view.
- A Projection mapping mode has been added to the nodes.
- Resolved critical normal mapping issues on sculpt objects, ensuring that fine surface details are correctly preserved even when using Soft Displacement
- Support for matrix-type properties in the node system
- Bugs and crashes have been fixed.
- Added the highly requested 'Auto Pick' and 'Ghosted' options to the top bar in the Print3D room
- Significantly accelerated the rendering of node previews and channel viewing (via CTRL+hover), while eliminating lag, unnecessary loading popups, and fixing bugs with black material previews and layer masking.
Well, I watched the videos and it didn't help me with my specific roadblock.
I'm trying to edit an imported model, with the modeling tools. I imported an FBX into the modeling room, and it looks like the attached screenshot. I can't seem to "edit" the mesh as is.
I did get one thing to work (sort of?), which was autotopo. I got a "colored" mesh that I could interact with. Which was in addition to my existing mesh (why didn't it edit my existing mesh, I don't know). But I tried to do it again with different settings, but nothing happened. Now I can't get it to work again?
I did realize I could create new geometry with the primitive tool, and that is colored and "editable." So I understand how to create new geo in the modeling room. But I have existing models, and don't want to re-model them.
I get that when you import a model, it's supposed to be a base for retopo or sculpting - but I can't seem to figure out how to continue modeling my imported meshes.
Maybe 3d coat isn't supposed to do this, and I'm trying to use it in a way that's not intended? But if any one has any help to give, or info to help clarify, I would appreciate it very much!
I woke up this morning with a fresh mind. I guess with my upcoming major surgery this week there was a bit too much swimming around in my pea brain.
I did as suggest in the 3DC forum and deleted the python 3.8.10 folder (" E:\MyDocs\3dcoat2026\python-3-8-10)
And it magically worked!
hi there, might be hard to catch in my video but I use "extra detail" w/ ctrl shift when in voxel mode, then switch to surface, then smooth
your brush settings look like you are not using a brush mode that tesselates the geometry
Previous it was working fine with 2026.01 and Blender 5.0 (portable install of Blender). After the upgrade to 2026.07 it stopped working.
Blender is exporting the objects to the defined folder
C:\Users\kenmo\Documents\3DC2Blender\ApplinkObjects
But nothing appears in 3DCoat when I send an object to the UV, Paint or Retopo rooms.
Prior to the upgrade it always ran very smoothly with no issues.
Last year when I upgraded I had a similar issue and was able to resolve it using the tips on this forum.
None of these tips worked this time.
But after trying for 4 hours I give up.
Not sure why 3DC upgrades have to create these issues. Love 3DC but the upgrade process needs to be smoother.
Any suggestions?
Thanks kindly...
Kenmo
