    • Gorbatovsky
      CADQuader 2026.21 — updated build for Windows, released November 28 Thank you for providing complex models and detailed feedback! In this new build, we have focused primarily on mesh quality and workflows for low-poly geometry. • We have improved the preparation of complex CAD bodies—including those imported from Plasticity—prior to meshing. The processing of micro-chamfers and short edges now accounts for the mesh step size, ensuring that the original shape, sharp features, and holes are preserved. • On a test model of a cap, we eliminated excessive mesh convergence at a single point, achieved a more uniform distribution of quads, and improved the visor geometry. • Several issues related to seams, narrow regions, and depth visualization have been resolved. Previous enhancements to TankBaker and Vortex have been retained. • After the "Create Low Poly" operation, successfully processed source bodies are now automatically hidden and marked with a green indicator in the project tree. This state is fully supported by Undo/Redo functions and is preserved when saving your project.
    • Gorbatovsky
      CADQuader 2026.21 - follow-up on your UX feedback Thank you for the detailed report and the test models. The updated Windows build dated November 28 addresses the following points from your list: 1. Active tool: opening and closing Low Poly preserves the active tool instead of switching back to Orbit. If you deliberately choose another tool while the panel is open, that choice is kept. 2. Deleted meshes returning: reopening Low Poly no longer restores deleted mesh objects. The temporary preview is separate from generated objects in the scene, and closing an old panel cannot erase a newly opened panel's preview. 3. Density and parameter changes: changes now update the visible preview as well as the mesh calculation. You can inspect the result before clicking Create Low Poly; that button creates the actual scene objects. 4. Remembering settings: configured bodies retain their mesh settings, and new bodies reuse the last-used options. Relax settings and manual U/V face overrides are also retained, including through project save/load. 5. Display changes and the inverted-hull effect: opening Low Poly preserves the existing scene display modes. Depth and overlapping-preview rendering issues have also been corrected. 6. Wireframe on unrelated objects: the temporary Low Poly preview is limited to the target bodies. Opening the panel no longer forces the preview wireframe onto unrelated objects. 7. Changing the target selection: selecting different bodies while Low Poly is open now updates its targets and preview. Closing and reopening the panel is no longer necessary. 8. Selection appearance: selected bodies use a consistent warm shaded highlight. The RGB surface-analysis display remains a separate mode rather than being used as the selection highlight. 9. Pinched center seams - improved, with a limitation: shared CAD-edge matching and narrow-strip handling have been corrected. The closed bodies in the supplied Wendall test model pass the shared-edge checks. This update does not add automatic symmetry detection; the existing explicit symmetry controls remain available. These fixes are not a guarantee that every pinched seam in a Plasticity model is resolved. 10. Move tool picking: Move now uses the same body picking and Shift-add/Ctrl-remove behavior as Select. It no longer expands the selection to every body sharing an imported group name. 11. Scale origin cube: corrected its face orientation and depth ordering. The center cube draws in front of its spokes, and the displayed pivot stays fixed during a drag. 12. Rotation gizmo: replaced the half-circle display with complete XYZ rings. Dragging follows the selected ring, and the gizmo stays at its original pivot throughout the rotation. An additional workflow improvement: Create Low Poly hides successfully processed source bodies and marks them green in the Outliner. This is included in Undo/Redo and saved with the project. The version number remains 2026.21, so please install the updated full Windows package dated November 28 and rebuild your meshes. The application and installer are digitally signed by PILGWAY LLC. Download: https://cadquader.com/?lang=en Please let me know if any of the original cases still behave incorrectly, ideally with the model and the settings used.
    • Gorbatovsky
      A new version will be released today, featuring improved mesh-generation algorithms. Thank you very much for the models. Furthermore, almost all of your suggestions regarding the UX will be incorporated. May I use several of your models to create a promotional video?
    • Gorbatovsky
      Thanks for the interesting file. I am working on the error.
    • Gorbatovsky
      Viewport performance also depends on the number of polygons. Insert simple Box. How many frames per second? Box_Simple.step
    • carrots
      3DCoat 2026.31 Portable for Windows: https://drive.google.com/file/d/1JDvKAP6hGe9RD05UYbXXl6gRsmekf8V9/view?usp=sharing Nov 27 2026 - Fixed an issue in Node Graph Presets where switching from a multi-component material to another preset left parts of the previous material behind, allowing you to browse and preview complex materials seamlessly. - Added clear, artist-friendly names and helpful tooltip descriptions for all nodes and categories in the Node Editor, making it much easier to browse and understand what each node does. - Separated the primary light intensity control in the Navigation Bar from Exposure in the Render Room, allowing you to adjust viewport brightness for sculpting and painting independently without affecting your render exposure settings. - Fixed distorted, overly strong bump relief and excessive glossiness appearing on surfaces at certain angles when "Compute Normals From Displacement (Skip Normal Map)" is enabled. - Significantly accelerated compilation of Node Graph edits, prioritizing immediate 3D viewport updates and showing a non-blocking progress bar instead of UI freezes while new material changes compile in the background. - Sped up loading of Node Materials and Node Graph presets, making complex materials and high-resolution AVIF textures open much faster. 3DCoat 2026.30 Nov 25 2026 - Fixed an issue with compiling add-ons that use CoreAPI
    • IHearNoise
      1. Is it a bug if I can't erase rust or dirt material on it's own layer? I can erase metal or wood, but when I try to erase rust or dirt, nothing happens. I've checked, these layers are unlocked. 2. Is it possible to prevent a material to be added onto a layer as soon as I click the material? It would be nice to see the preview first, like it was before. Now when I click a material, it fills the whole layer and perhaps the whole model with the material and then I have to start erasing the parts I don't want the material to be added onto. 3. And how do I rotate a texture now? For example, if there is a wood texture and I want to rotate the wood seams to go the other direction. It used to be possible when there was the preview window, like when using the stencils. There is a rotate node but I don't know how to hook it up with the rest of the nodes.
    • carrots
      1. Okay, I’ll separate the exposure so that it can be adjusted independently for the viewport and for rendering. 2. The "Cast Shadows" option has been moved to the Navigation Bar menu. Please note that the lighting settings for "Cast Shadows" are now derived from the brightest light source in the render room; this allows you to adjust the lighting and shadows to create a more comfortable environment for sculpting.
    • Mike Choo
      Hey, really excited about this - just bought a perm license as I hope this is gonna save a lot of retopo 🙏🏾 Viewport performance is very low - on some models I'm getting 0.1fps on the display refresh, which is sadly unusable. Not found anything in preferences to help with this - any tips? System details: 4090fe 128Gb Ram Win 11 Nvidia Game Driver 621.14 Cheers!
    • zandernice
      POD-KV2_002-WIndow2.stp   I couldnt get this mesh to quad - just errors out POD-KV2_002-WIndow2.stp
    • wendallhitherd
      No problem! Thanks for helping to accelerate the workflows Worth mentioning I am basically a novice with CAD and like I said im not fully aware of "cad antipatterns" like I am with pure polygons, its possible I am supplying terrible data. But that might actually be useful test case to see awful data hahaha One thing I will also mention. Hot on the tail of this app is Hard Craft.   https://github.com/polozad/hardcraft-dist/releases I don't think hard craft is trying to do what this app is doing -- in HC you go patch by patch and curate the quadrangulation, which is obviously slower than getting a great automatic result, however, it is useful to be able to customize / override the algorithms settings per patch to fix bad automatic detection. As well, in HC, there are some options to choose flow lines from drawn point to point connections / lines, and rails. I think the main thing that would make CadQuader surpass something like hardcraft is the better automatic algorithm of course but also if there was increased control per patch, the user could refine or work around bad plasticity data by just nudging settings until the patch resolved well. Without these finer controls, CADQuader could have the same issue as Exoside QuadRemesher where -- it's fully automatic, and you get what you get,  and the only solution to bad results is manual rebuild or going back to the source data to make it more 'remesher friendly'. Great automatic results is preferred of course but also exposing detailed configuration would help user work around edge cases the algorithm doesn't handle well.
    • Gorbatovsky
      Huge thanks for the models from Plasticity. I’m already working with them—you’re an absolute legend! And thanks for the suggestions on how to use the software, too. We’re incorporating everything into our workflow.
    • wendallhitherd
      - the move tool selection algorithm is different than the selection tool. It should be the same. When you select using the move tool, it seems to grab all bodies, instead of the current solid, like the selection tool. - there seems to be a bug with the scale tool's origin cube. It orbits the wrong direction as the view is rotated, and it always seems to draw behind its spokes - the rotate tool only seems to show a hemi circle, not an entire circle. It should just look like a typical rotation gizmo, either like the blender one or like the 3dcoat one. Further, when used, it offsets itself away from the object pivot. It should stay pinned to its original location while the rotation mouse move is occurring.
    • wendallhitherd
      Hey folks, picked up cadquader (happy to support development of new stuff lke this here is an 2025-06-09.stp.stp containing a bunch of test objects I made when trying to learn how to use plasticity. I have noticed a few bugs / UX issues: - active tool keeps changing back to orbit view mode (instead of select or other tools) when launching / closing the "low poly" popup menu instead of restoring the tool I had open. - Low poly popup menu seems to have bad caching of previous quadded meshes / restores deleteds when open panel. I delete the low polys from the outliner, and open the tool options, and the lowpolys I deleted come back. - scrolling density / float fields in tool options takes a while to update the re-quad mesh but does not actually update the view until you use "create low poly" button. The low poly should either not be recalculated on scroll float fields / update any field and only recalculate when "create low poly" is clicked, or it should update the view as well as the model on change event - The field overrides are reset to default in quadrify / low poly tool options instead of retaining the last set. This is annoying because If I find a good set of quad options, I cannot reuse them without re-setting them -  - there is a weird inverted hull back faces effect on the quad meshes when the tool options menu is open for the low poly generation. In order to see the backface culled front-face quads only I have to close the menu. Ideally, it should not change my view settings except maybe forcing on wire frame. -  - When the low poly menu is open, it shows wire frame on meshes that are not part of my selection set. Ideally it should only show the wireframe for the quadded object I am currently working on so it is not confusing what is currently being quadded - It is possible, when low poly mesh window is open, to change your selection of objects in the viewport. However this seems to have no effect on updating the quad remesh target. In order to change your quad remesh target batch you must close the low poly tool and re-open it again after.    - The selection display mode is unclear / ambiguous. It seems to be showing some world normal for selected objects. It should instead show a blender style outline or a shaded fill instead. Having your selected objects being filled with an entirely different color scheme is a bit jarring to use and also unclear the intent to someone used to other softwares. - there seems to be issues with pinched mid-lines where quads are pinched at center seams. This might be an issue with how plasticity does symmetrizing (it just midline slices and duplicates) but it would be good if the program was symmetry detecting / symmetry aware and would resolve the midline  without causing these pinched triangles.
    • Mihu83
      I'm testing version 2026.30 and this new light setup is kinda weird. Sculpt Room is way darker by default than previous 3DC versions and there is huge difference between Sculpt//Render room, especially with extra lights in Render room. Seems like Render room Exposure and light setting in Sculpt room are now linked together and that is causing problems - user gonna need to adjust exposure between rooms with each time switching between rooms. Most of the shaders doesn't look like they used to and to make it look any good, it needs a lot of messing around with light and contrast... constantly. Also, is there some On/Off toggle for this new viewport light system? Oh, Cast shadows is now gone?   p.s. GPU performance seems to be better now, so that's one good thing.
    • webmaster
      Black Friday sale ! CADQuader: Automatic quad-dominant mesh generation from CAD models (STEP/IGES).View the full article
    • webmaster
    • Suzuki Masatomo
      There is one more thing: it seems that locking the environment map in the viewport isn't working either.
    • webmaster
      Black Friday sale !!!! Real-Time Soft Shadows in 3DCoat in Sculpt Room!View the full article
