    • philnolan3d
      I solved the problem. It's not in Smooth it's in Clean Clay. My mistake.
    • philnolan3d
      I just installed 2026 so I'll say that one.
      On vetsion 2025 or 2026 ?
    • philnolan3d
      There used to be a Reduce option for the Smoothing tool in Surface mode but it's gone. I need to reduce polys only in a certain area.
    • 3Dmoat
      Is this still ongoing? I cant get the second panel to pull up at all.
      New Project Folder option Baked Textures: Cavity, AO, Normal, Geometry are still saved on Global Temp folder   That maps must be saved on Project Folder > data > Temp * the folder was created, but it is empty
      Simple Mask Node lacks of Degree Map  - Old Node   - New Node
      Yes, when you add a mask the Out Material is visible. The mask unhide any Material assigned to the layer. Quit the mask and paint over the mesh to see the material applied. We can apply materials in different ways, by painting with a brush, using stencils, or using the fill tool   Try this: paint some strokes over a paint mesh As you can see, only a paint icon is show on the layer   Now add a simple Material on the Node Inspector and a Out Material   A new icon is show on the Layer, right to the paint icon: is the Material icon   On Node Inspector Panel, switch on Show in Object Inspector   On Object Inspector Panel change any parameter, like Gloss in this case   To see the original Color or Gloss previously painted use this nodes   Use GeometryIN node to visualize Normals
    • Dekkard
      I watched this video but I don’t remember seeing him use an actual paint node . What he did do was group a bunch of painted layers and applied a material and material mask on the group . Can I do a paint On that material mask node . Maybe I am not using the correct terminology .  In substance , I can use generators , projection as well as a paint layer if need be like in the attached image1 .  How can I do something similar in 3dCoat  ?   Or like in image 2 . Can I bring in the painted stencil image in to use as a mask as well  Thanks
      Yes you can Dud you have seen this introductory video ?  ?
    • Dekkard
      Very new to 3dCoat and this node base workflow is what got me interesting coming from Substance and Mari background .  Do we have the ability to have a paint node or a layer that we can add to this non-destructive material workflow  ? For example if I have a Mask network  , can I add a paint node/layer for some manual painting on top ?   Thanks
      Minimize width size on Node Inspector Panel or any other Panel, some parameters can't be selected anymore
    • chrisd
      Try exporting as Triangles, not Quads, to see if that has different options. I know quads are typically preferred, but triangles might be needed here to get a better result.
    • tomas aceytuno
      I'll look into what you mentioned; it seems like the solution lies there. Unfortunately, the version I'm using doesn't have many more export options than what you can see in the screenshot. Thanks for the tip and your help Chrisd.
    • chrisd
      You may have already tried this, but just in case you have not, per vertex normals export from Plasticity may improve the result. That works with other applications to get a good result, but I do not have Plasticity to test. Searching online indicates using Refacet when exporting OBJ exports per vertex normals.
      Suppose I need to know which node corresponds to these parameters. There is no way to select the parameter in the Object Editor so that the Node Editor automatically refreshes the node and also displays it in the Node Inspector.   Hence my proposal to maintain the groups for: Better visualization in Node Editor. Automatically creating separate categories in Object Editor. Ability to save these groups as Favorites that can be easily inserted into any Node Editor.
      To open a project with nodes applied on the mesh takes 1 min of loading (+o-)
      Bibisco is a novel writing software that helps you plan, organize and write your story without getting lost https://bibisco.com/ If writing feels overwhelming, it’s not a lack of talent. You start with an idea you care about. Then the story begins to grow. Characters appear. Scenes multiply. Relationships start to intertwine. Little by little, the story turns into something bigger than a single idea. And it becomes harder to see how everything fits together. Not because the idea isn’t good enough, but because a novel is a complex structure.
    • tomas aceytuno
      I think I've found the problem after many tests: deleting drivers, installing older ones, and switching between different software. If you incorporate Plasticity into your workflow and export .obj files, it saves them with characteristics that can make them look bad. After many tests and trying different workflows: If I export .obj files from Plasticity and use that file, I have these problems. If I use the Plasticity bridge with Blender and export .obj files from Blender or use 3D Coat AppLink, the problem doesn't exist. Problem: Plasticity is the problem. I'm using Plasticity 25.11.2 (I haven't updated). I've read that they've optimized the export to meshes. I don't know if it's fixed, but if you encounter this problem, you now know why it might be happening. Another way to work is to export .obj files in Plasticity with TRI Topology and adjust the MAX. Setting the width to 0.001 or 0.0001 will export a dense mesh that you can then convert or load into voxels. This is all information in case it's helpful for you with Plasticity. Thanks for your help, CarloSan.
    • For The Moment
      Hi, I noticed this question asked a lot elsewhere but haven't seen the solution, I discovered for myself, brought up anywhere else. When Applink brings back materials to Blender, often times those materials don't appear in a Cycles render. I found this is because Coat also brings back a set of empty materials and inserts them into a Collection. These empty materials get confused for the materials containing color data. You can reassign the materials but I found it easier just to delete the entire Applink collection. Is deleting the Applink Collection always practical or will there be some instances where that Collection needs to be kept?
