Sometimes there is a confusion comparing a Shader Nodes system with a Material Nodes (and Textures) system.
To work with Texturing Node system on 3DCoat follow this steps:
– Create a Paint Layer, add or create a Material (double click over the material icon)
Here is a set of materials based on the nodes that you can use to learn.
– Add or create a Mask, apply it on the same layer (double click)
Here is a set o mask based on the nodes
The first icon (L2R) is your painted or filled layer, second is the material and 3rd is the mask.
Filters on the other hand, must be apply on a new Layer above the previous Layer (or inside a Group in first place). It take input data from the layers below.
If a layer is inside a group, the layers below it will only be those that are inside the group.
– All the node parameters can be edited individually on Node Inspector
– Or globally on Object Inspector
The Node system’s primary objective is the procedural synthesis of various 2D texture maps, such as Base Color, Normal, Roughness, and Metallic, which define a material’s visual characteristics.
It enables the mapping and construction of these visual elements that define the surface using a structure of graphic nodes.
It does not directly control the mathematical formulas used for lighting or shading calculations.
The behavior of light when interacting with a surface is determined by the shading nodes.
Subsequently, these generated maps are connected to shading networks within a 3D rendering application or game engine.
Latviešu valoda
English
Українська
Español
Deutsch
Français
日本語
Русский
한국어
Polski
中文 (中国)
Português
Italiano
Suomi
Svenska
中文 (台灣)
Dansk
Slovenčina
Türkçe
Nederlands
Magyar
ไทย
हिन्दी
Ελληνικά
Tiếng Việt
Lietuviškai
Eesti
Čeština
Română
Norsk Bokmål
