Showing results for tags 'drag'.
Found 2 results
  1. Hello! I just bought it today, hoping that it works because in trial version it doesn't work. Basically what I was trying to say I'm trying to have multiples quads when dragging which is quicker than clicking at each quad. But it doesn't work for no reason. I created points for each quads and then drag the first quad across the screen by holding right click. But it's didn't work, it just gave me only one quad than giving me multiple quads. Does anyone have same problem? Any suggestions? Thank you guys
  2. So I decided to give the sculpting tools a shot so that I can fairly compare 3D Coat to my existing workflow to determine if it justifies the cost to purchase and have run into a few problems trying to replicate my previous workflow. I am wanting to find out how I can achieve the same results I get in Sculptris when I use the Grab tool. I found a tool in 3D Coat called Move, but it only grabs 1 pixel and drags this.. kind of works more like the Pinch tool from Sculptris. If anyone knows the name/way to use the right tool to achieve the same result please advise. EDIT I also have seen a Pointers counter at the bottom of the 3D Coat program and every time my cursor is over my model, it starts to rapidly count down. It was at -7000 a little ago and is now all the way to -12000. As this number decreases.. I am seeing my memory getting chewed up. this can't be good right? DOUBLE EDIT The larger the brush size the faster it decreases, the smaller the brush size the slower it decreases. I'm not clicking just hovering my cursor over the model with the Move tool selected. TRIPLE EDIT Is there a way to change how much detail is added or removed when you are sculpting. In Sculptris I was able to adjust the tessellation level so that it would either work without adding any new polygons or it would add extreme quantities of them. Using this method I was able to control the polycount in areas where high detail was not required. I'm just trying to determine how to achieve this same result inside of 3D Coat.
