Showing results for tags 'sculpting tools'.
Found 3 results
  1. hello, I'm new to 3DCoat and trying to learn this software. I'm following a tutorial for voxel sculpting. Each time I try to make a shape using sphere voxel tool, the shape has a weird angle, if I increase the depth of the brush the angle is greater the same is the case when I cut through the shape. Why is this happening and how can I solve this?
  2. I have had experience with sculpting in blender, but wanted to try 3dcoat after hearing about its voxel features. Right now i only have the demo but havent tried it for long. Im a little confused with the brush layout. im not sure what the difference is to clay engine, voxel tools and claydraw. Is voxel sculpting always enabled with all these tools or do they work differently and seperately? Where do the surface tools come in? Ive been planning on getting the new suface laptop studio with 11th gen icore 7 with 32 gb of ram. With how much power 3d software needs, will that be enough, especially for high amount of details and sculpting full body characters and objects? because 3dcoat has voxels, do i still need to use subdivide, retopology and remesh when sculpting, or can it be completely voxel sculpting with none of those options?
  3. heyas, guys! still watching hours of tutorials and demos (thanks!)... have some newbie questions that i hope haven't been asked 100 times before. PS: i'm using 4beta14a1GL 1: Smooth Tool how come sometimes this aggressively melts the model down to nothing, and sometimes it barely does ANYthing? i've tried different strengths, sizes... it just usually ends up doing the opposite of what i want? (ie: melting my mesh when i want a faint little adjustment, or barely doing anything noticeable when i want the mesh to melt.) 2: Pinch Tool & Creases the pinch tool isn't behaving the way i expect. not sure if this would be a bug or feedback/complaint. it pulls the mesh together in the middle, but it also creates a dent around the stroke. i don't want the indentation. i tried to make a crease by using the extrude tool (inverse mode, of course), with a sharp pointy brush tip. that created a decent little trench. but then i wanted the pinch tool to pinch the sides of the trench together to make a skinnier trench, it actually made a wider, yet shallower trench. so what's a technique for creating creases? 3: Tools that Go into Voxel Mode i threw some presets on the preset floater. the move tool, and the translate tool. sometimes when i switch to the translate tool, it pops up and says "This preset will switch your [sic] to voxel mode." sometimes it doesn't. sometimes the move tool makes this pop up. the thing is, i thought i was IN voxel mode and never left it. i haven't switched anything to surface mode. that i know of? i'm not using the tools in the surface subsection. i never change room tabs. nothing ever pops up and tells me i'm leaving voxel mode, or entering surface mode. 4: Translating in Symmetry how come this tool doesn't obey symmetry? like, say if i paint in a sphere for an eyeball, and i want to move the eyeballs closer to the centerline. i don't want to smush them or parts of them over with the move tool, i want to actually translate them side to side. but the translate tool appears in the middle of the two eyes. and even if i move it to one side of the centerline or the other, it just moves both sides in the same direction. 5: Mannikin Parts Symmetry on different Layers i wanted to turn the humanoid mannikin into a digigrade mannikin. so i was monkeying around with the left lower leg. and the stuff i did there didn't translate to the right lower leg, because it was on a different layer. except the posing tool, which affected both parts. can someone explain the different symmetries going on? and give me some pointers on how to edit the shin, then duplicate (clone?) it to make the shank, and then how to get the corresponding right side parts? i found the clone command, but there are different clones that weren't explained very well on the wiki, and i'm not sure which ones are linked clones and which are just independent copies? thanks a bunch!
