Showing results for tags 'task management'.
  1. Hey everyone, I have 3 doubts: 1) Saving a mesh or object from VoxTree in 3b format. Can this 3b object keep all the work done on layers of sculpture related to it? In the test I did, the 3B file does not save sculpt layers relating to the mesh of the VoxTree layer that I saved in .3b when I import this .3b file. With you, do the same thing happen? ---------------------------------------------------------------------- 2) I was thinking of separating objects from VoxTree (dismember the project into mini projects) where the main file could be lighter and smaller ( just a container for the mini files .3b files that are part of the same project ). An example would be a sculpture of a character. I separated in the Vox tree : * Character Container |_ character mesh |_ Clothes |_ Accessories. I would like to do something similar to what happens in the Blender program. Having a main file and in it I would use the Append or Link method as needed. When I worked on a 3b mesh and saved, it would automatically modify file 3b. and in the main project this file would be updated and modified. Could I do something like that? ------------------------------------------------------- 3) You could kindly indicate to me an open source or free program so that I can fully organize myself in my private projects in the sense of task and asset management, calendar and etc (preferably it is just a single program for better usability). The program I was testing was Redmine, but it's complicated in upgrades and stuff. I also saw an opensource program called Tactic, but I did not understand anything, very complicated and I did not find any video that would explain the running beginner users like me. thank you
