Member davesenter Posted May 13, 2014 Member Report Share Posted May 13, 2014 Hello, I'm trying to export my normal map bakes but when I export the PSD, I open up the file in GIMP and the normal map is empty. I know the bake worked because I can set the normal map layer to Standard blend and see the normal map on my mesh. I've tried exporting different formats without any luck. The research I've done hasn't given a solid answer. Any ideas? Quote Link to comment Share on other sites More sharing options...
Member davesenter Posted May 13, 2014 Author Member Report Share Posted May 13, 2014 Found the issue - In the UV room, there were several material layers from each bake. After deleting them I rebaked the maps and it worked! Quote Link to comment Share on other sites More sharing options...
