Member riuthamus Posted April 3, 2016 Member Report Share Posted April 3, 2016 So, I am attempting to make a model that has the facial elements (eyes, mouth, eyebrows) on a different set of models. The main reason for this is that I want to make those elements changeable via our game engine, but to save space I want to try and put all the eyes and mouths and such on the same diffuse/normal/roughness set of maps. How would I go about doing this in 3d coat? a quick search didnt turn up much so I probably dont know what the right thing to ask is... If you need me to explain this better or show pictures/video to explain what I want to do, let me know. Quote Link to comment Share on other sites More sharing options...
Member Solution riuthamus Posted April 3, 2016 Author Member Solution Report Share Posted April 3, 2016 Actually, I think i solved this myself. I was not aware you could import multiple objects into the same scene and then merge the uv map to another uv map set... this is epic! <3 Consider this solved. Quote Link to comment Share on other sites More sharing options...
