Member Jessestormer Posted July 17, 2018 Member Report Share Posted July 17, 2018 Is there any way to fine-tune the 'close invisible hull' settings? It fills areas that are 'not-so-invisible' -- I'd love to crank up the ray-angle and samples. I can see the lines that are made from it ray-casting (I'm going to call it that, but I'm not sure exactly that's what's going on) I'd love to just force it to cast a more high-res sample, as to not fill areas that are really quite visible. Fill voids does a great job as long as there isn't some TINY LITTLE hole keeping an internal hull from being removed. Mostly I'm going around and manually repairing tiny holes with the fill tool but they can be easy to miss. Thanks in advance for any help! Quote Link to comment Share on other sites More sharing options...
