Member Chufu Posted March 8, 2009 Member Report Share Posted March 8, 2009 There is a curiosity in 3D-Coat V3Alpha (leatest Version Without CUDA). When I sculpt a Objekt with the Voxelmodeler I can't switch to the Surfacemode. If I do that my Object disapears. Wehen I swicht return to the Voxelmode my Object is back. So the direkt way is closed. Now I must go a special way to change the surface of my Object. Workaround: In the Voxelmode I must save my Objekt in to the obj-Format. Then I can reload it in the Surfacemode. Now I can modeling the Surface. I think this method is a little bit circuitous. Greatings Peter Quote Link to comment Share on other sites More sharing options...
Advanced Member psyborgue Posted March 8, 2009 Advanced Member Report Share Posted March 8, 2009 There is a curiosity in 3D-Coat V3Alpha (leatest Version Without CUDA).When I sculpt a Objekt with the Voxelmodeler I can't switch to the Surfacemode. If I do that my Object disapears. Wehen I swicht return to the Voxelmode my Object is back. So the direkt way is closed. Now I must go a special way to change the surface of my Object. Workaround: In the Voxelmode I must save my Objekt in to the obj-Format. Then I can reload it in the Surfacemode. Now I can modeling the Surface. I think this method is a little bit circuitous. Greatings Peter To paint on voxel objects you must retopo them first. that can be done automatically by right-clicking on a voxel object in the vox-tree and going "quadrangulate and paint" or manually, by going to retopo mode, creating a retopo mesh, laying out UVs, and doing a "merge in scene". Quote Link to comment Share on other sites More sharing options...
