  • 0
[Fixed] Basic objects question
Skaties
Question
GOOGLE
Hello, I am a blender user and have been using 3dcoat since may 2022. UDIMs work perfectly, Retopo and Paint are a dream, only with the basic objects there is a problem. Example: 1. Convert cuboid to voxel 2. Scale new cuboid smaller and move it outwards and the conversion fails sporadically. The base object is transparent, but not converted to voxel. Only if the center is outside the old cuboid, it works. Other basic objects are also affected. What am I doing wrong or where can I set it?
2x AMD with win11 Pro, an old i4790 with win10 pro and back to 3dcoat 2023.12, but also here these problems.
Ask for help.
Thanks, skaties
2 answers to this question
  • 0
Hello, faster than expected the bug is fixed with the 2023.16:
"- Fixed problem with voxel primitives - sometimes "Apply" had no effect, trace mode worked with strange irregular spacing."
Thank you very much. This is sensational!!! Skaties
  • 1
What do you have in mind?
Could you please write more detailed steps for repeating the error?
Answer this question...
