Member ArtaWorks Posted August 27, 2023 Member Report Share Posted August 27, 2023 I have a stack of sculpt objects all are done with AUTOTOPO and then baked from retopo menu. All of them are done the same and yet one of the objects starts a new UV set and I can't get rid of it. There is only one thing differentiating it from the other Poly Groups and it's the grey thin bar you can see on screengrab. I'm at my wits end and can't find where it comes from. I want everyting to have one UV set. If you know what this is, help. Thanks Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted August 27, 2023 Report Share Posted August 27, 2023 2 hours ago, ArtaWorks said: I'm at my wits end and can't find where it comes from. If you choose "Keep UV" then you have two sets of UVs there. Check it out before baking. Quote Link to comment Share on other sites More sharing options...
Member Solution ArtaWorks Posted August 28, 2023 Author Member Solution Report Share Posted August 28, 2023 21 hours ago, Oleg_Shapo said: If you choose "Keep UV" then you have two sets of UVs there. Check it out before baking. Thank you, Wasn't the issue however. With Silas on discord I managed to understand. I had to select Edgeloops to open up UV menu in the Retopo room. Incredibly puzzling. Not something anyone will figure out unles they click on random. Option to merge UVs was available and that fixed my problem. Solved 1 Quote Link to comment Share on other sites More sharing options...
