Member jettyart Posted January 7 Member Report Share Posted January 7 Hi guys, thank you for your great product. I think i've found a bug. When you have multires turned on with a surface mode - shortcuts stops working, they are won't work. Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted January 7 Report Share Posted January 7 2 hours ago, jettyart said: they are won't work Hello. What shortcuts are we talking about? And what version are you using? Quote Link to comment Share on other sites More sharing options...
Member jettyart Posted January 8 Author Member Report Share Posted January 8 For example: situation like these - you have an object in the "S" and you have multires and then use your shortcut on 1,2,3,4. And they're isn't working. Version 2023.19 Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted January 8 Report Share Posted January 8 1 hour ago, jettyart said: And they're isn't working Let me ask you what actions you assigned for shortcuts 1,2,3,4? Quote Link to comment Share on other sites More sharing options...
Member jettyart Posted January 10 Author Member Report Share Posted January 10 Cut off Sphere Move Extrude Quote Link to comment Share on other sites More sharing options...
Solution Oleg Shapov Posted January 10 Solution Report Share Posted January 10 30 minutes ago, jettyart said: Cut off Sphere Move Extrude When a multi-resolution level is added, the order of the tools changes and your voxel tools such as Sphere or Extrude are not called up in "S" mode, so the hotkeys may not correspond to the tools. I'll ask the developer what can be done about it. Quote Link to comment Share on other sites More sharing options...
