Member giobianco63 Posted April 13 Member Report Share Posted April 13 HI, Is it possible to adapt the size of the stencil to the overall dimensions (Bounding box) of the object? I have a stencil that I created with the aspect ratio of the mesh... but I can't scale it precisely on the theoretical bounding box of the mesh. Also because when I try to climb it the image disappears and then appears once I release the mouse button. Or perhaps it would be enough to have the possibility of putting a scaling value to be able to scale it precisely. Version 3DCoat 2024.15 Giovanni Quote Link to comment Share on other sites More sharing options...
Member giobianco63 Posted April 13 Author Member Report Share Posted April 13 Among other things, is it possible to have two stencils with the same size, and if you change with the other stencil that the size on the screen does not change?...because at the moment as soon as you switch to the other stencil the size is different. Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted April 14 Report Share Posted April 14 23 hours ago, giobianco63 said: Also because when I try to climb it the image disappears and then appears once I release the mouse button. You need to switch the stencil display mode. Quote Link to comment Share on other sites More sharing options...
Member giobianco63 Posted April 14 Author Member Report Share Posted April 14 4 hours ago, Oleg Shapov said: You need to switch the stencil display mode. yes but that is used to turn the stencil on or off, I meant that when I climbed it it disappeared...but by pressing "alt" the stencil always remains active.... Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted April 15 Report Share Posted April 15 16 hours ago, giobianco63 said: yes but that is used to turn the stencil on or off, I meant that when I climbed it it disappeared...but by pressing "alt" the stencil always remains active.... That's how it works. And it seems to look comfortable. Quote Link to comment Share on other sites More sharing options...
