Member skamierski Posted March 20, 2010 Member Report Share Posted March 20, 2010 hi, i just installed 3D Coat with Cuda Support vut it didnt work, so i tried some things to solve the problem. And i found a solution, which i like to share. I dont know if someone has posted this earlier. I Installed the newest cuda drivers and development kit (http://developer.nvidia.com/object/cuda_3_0_downloads.html) as written at the end of the installation. 3D Coat didnt want to start. A message was shown, that cudart.dll is missing. Reinstalling of drivers didnt help. How i fixed the issue: 1. go into the cuda development kit folder. Mine was at C:\Cuda 2. go into the bin or bin64 ( dependent what bit OS u are using, 32bit or 64bit ) 3. copy the cudart_XX_XX.dll ( xx stands for version number ) 4. paste the cudart_XX_XX.dll into the root folder of your 3d coat installation. 5. rename the cudart_XX_XX.dll to cudart.dll and you are done. 6. Start your Cuda supported 3D Coat i hope this can help someone cheers² 1 Quote Link to comment Share on other sites More sharing options...
New Member Littleshots Posted May 26, 2010 New Member Report Share Posted May 26, 2010 Thank you for the description. Your solution worked like a charm. Quote Link to comment Share on other sites More sharing options...
Member skamierski Posted July 29, 2010 Author Member Report Share Posted July 29, 2010 Thank you for the description. Your solution worked like a charm. nice that i could help u Quote Link to comment Share on other sites More sharing options...
