Member John Strieder Posted February 18, 2011 Member Report Share Posted February 18, 2011 Hello everybody, is it possible to change the font- or (better) GUI-Size in 3D-Coat? Thanks in Advance, Strieder Quote Link to comment Share on other sites More sharing options...
Psmith Posted February 18, 2011 Report Share Posted February 18, 2011 John: It is possible - but limited to available space in whichever "Panel" the text appears. So, you might be able to go up 1 to 1.5 point sizes - with "BOLD" text, but that's about it. It's slightly complex and it involves using a program called "FontGen". I've done this, myself and I'll attach the little program to this post. Here are Andrew's instructions for use: There is no [easy?] way to change font right now.Ok, maybe I will send you program to experiment. I attached archive, unpack it somewhere. Run, choose 1024 x 1024, font, size. START Copy files Font00.dds and Font00.bf to Unicode folder (keep backup of older files). Greg Smith FontGen (1).rar Quote Link to comment Share on other sites More sharing options...
Member John Strieder Posted February 19, 2011 Author Member Report Share Posted February 19, 2011 Thanks Greg and Andrew, unfortuantely it seems like the tool doesn't generate a .dds-file here :S BTW, that's my suggestion for 3D-Coat: a sort of scalable inerface for people with big monitors and/or eye complaints Quote Link to comment Share on other sites More sharing options...
Member CoatFly Posted March 4, 2012 Member Report Share Posted March 4, 2012 I tried the FontGen (1).rar , but like John says. it dont generate the .dds file. i guess i need a pixel size of 16 to make it readable. maby 14 works to. John suggestion is good. Quote Link to comment Share on other sites More sharing options...
New Member maz-1 Posted June 1, 2013 New Member Report Share Posted June 1, 2013 I tried the FontGen (1).rar , but like John says. it dont generate the .dds file. i guess i need a pixel size of 16 to make it readable. maby 14 works to. John suggestion is good. A tga file is generated instead.Simply convert Font00.tga to Font00.dds.There is dds plugin for photoshop and gimp. Quote Link to comment Share on other sites More sharing options...
