SL Sculpty Export Defect
BUILD: 3.5.05A
OS: Windows Vista 64 bit SP2
HARDWARE: (If applicable)
BUG DESCRIPTION: SL Sculpty Export has line of noise across center of image.
STEPS TO REPRODUCE: Perform steps in http://www.3d-coat.com/forum/index.php?showtopic=3288 (approximate. current UI is not identical to that shown in the tutorial.)
SL Sculpty Export suddenly produces a sculpty map image that has a 2 pixel high line of noise through the center of the image.
This did not occur the last time I tried the tutorial at http://www.3d-coat.com/forum/index.php?showtopic=3288 . Last night I returned to this aspect of the 3D Coat product to learn about it and the export consistently produces defective output like the attached image.
