    • Sal_GC
      Wil be testing the new version very soon. Will report any findings.
    • carrots
      Windows 3DCoat 2026.15 HOTFIX Portable 3DCoat, 3DCoat Textura   - The default folder for 3DCoat Textura has been changed from 3DCoatTextura to 3DCoatTextura2026 to avoid version conflicts. - Fixed an error in exporting to Blender when the script path parameter did not have quotes. - Fixed an issue where unwanted trails appeared in the viewport when moving objects along an axis using a hotkey instead of the transform gizmo. - Fixed an issue with color distortion in grouped painting layers. - Fixed an issue where the layer list in the "Take Other Layer As Mask" menu duplicated every time it was opened. - Fixed an issue where node-generated materials in Per-pixel Painting appeared dark. - Remove debug information from NodeGraph - Fix node baking with using the gizmo - Matrix property type support in NodeGraph - Fix minor bugs & crashes - Restore hard glsl validation for NodeGraph - Renamed the 'Vector' node category to 'Math' and moved organic textures from 'Pattern' into dedicated 'Noise' categories, while keeping all your existing projects fully compatible. - Bake color, metall and gloss to voxels (volumetrics) - Texture Loading ProgressBar - Support for depth blending with underlying layers (GPU PPP)
    • Norris Lin
      I would like to report a bug potentially relate to this patch note from 2025.12 patch: - New plane pick mechanics: if you click quickly, the RMB menu appears. Click longer to select a point and a plane. [that was before] Changed: Hold RMB to move the plane's central point over the surface, but keep it normal. Press CTRL to move the plane along the normal. I have attached a video here to detail the bug. I would really appreciate if the developer can look into this. Thanks! 3Dcoat_bug_072726.mp4
    • Norris Lin
    • Mihu83
      This particular mesh is something like 1,8 mill and surface mode.
    • Dmitriy Nos
      Is the sculpt mesh dense enough? I've noticed some distortion in the retopo mesh if the sculpt resolution is low.
    • Mihu83
      Yeah, that was a bug in version 2025.17, which I stil use. It seems like version 2026.12 works correctly.
    • Dmitriy Nos
      My hidden retopo objects are not unwrap. Correct me. Запись экрана 2026-07-27 193441.mp4
      Hello This bug was reported and it will be fixed on the next release soon thanks for point it up
    • Kseniia
      Hi! I've just updated my 3DCoatTextura to 2026 version and am having a lot of issues. I already fixed some of them, but now I have a problem that clipping mask (via RMB click on the layer) doesn't work at all, though it has an arrow icon on the layer. I can create a working clipping mask via Layer Blending panel. But it's just not comfortable switching to this panel each time I need to create or delete the clipping mask. I didn't have this issue in 2025 version. Anyone faced same issue?
      Cleaned up ui, some improvements to layout etc   https://github.com/LiamSmyth/LKS_3DCTools/releases
      This bug will be solved on the next release soon. thanks for point it up
    • ewl
      I have also tested this on another project and it does the same thing where it shifts colours the moment they are put into a folder.
    • ewl
      Some more details, the folder is set to passthough already and still same result, also I This is Textura 2026. I also tested on trail version of full 3d Coat 2026 and the same issue. I have had someone test on the project file on 3D coat 2024 and the issue didnt happen. Is  this a 2026 issue?
      Hi The group layer is set to Pass-through ? Pass-through: Select the method of color blending between the previous layer(s) color and the current color
    • ewl
      Hi, im struggling with an issue with grouping in Textura 2026. When I group layers the colours seem to shift to blue. Anyone have any idea why this is happening. Gold is normal, blue is when I add layers to a group
    • Sal_GC
      Got it! Will be sending soon.
    • Empyror
    • carrots
      Please send me `Documents\3DCoat2026\Log.txt`. Also, check the box next to "Python Terminal" and restart 3DCoat; this should reveal the errors explaining why AVIF isn't working. .
