For testing purposes, could you disable/remove the 3060 and try again with updated drivers for the RTX 4070 Ti? With those baking features being GPU accelerated, I wonder if there is some internal conflict sending the commands to the GPU. It may not know which one to use (the developer may not have expected use cases where 2 different GPU's were used in a machine). I just tried to repeat the steps you took and had no crashes or issues, so I do think it's likely a GPU conflict of some sort.
AO Curv Baking Test.mp4
GIMP 3.0.6 Released
2025-10-06
by GIMP Team
We are happy to announce the third micro-release GIMP 3.0.6. During our development of GIMP 3.2 we’ve found and fixed a number of bugs and regressions. We have backported many of those bugfixes to this stable release, so you don’t have to wait for the upcoming 3.2 release candidate to receive them!
Release Highlights
Improve usability of sliders
Workaround for Windows language-specific crashes
Fix for Text Outline crashes
Better transparency handling with filters and transforms
Theme colors for Brush, Font, and Palette
Updated non-destructive filter code
Palette import updates
Printing improvements for flatpak
Improvements for macOS
Improved security for image imports
Build process improved
Assorted fixes
Hey! So i have checked all my projects with earlier version (2025.10) and it is working as intended
I guess 2025.11 just dont work for me.. Also, forgot to mmention - I am using 3D Coat Textura, not regular one
To apply an alpha brush along a curve around a curved surface in 3DCoat, you should use the Curves tool in the Paint Room or the Curves editor to define the curve path, then apply your alpha to it, ensuring the curve follows the object's local space.
I've been use this link. It works up to Blender 4.5.3. (Fails in 5.0 alpha. Sends ok but get back fails.) Could be the alpha version.
https://github.com/AndrewShpagin/io-coat3d
