New Member deadlyjimmy Posted February 23, 2017 New Member Report Share Posted February 23, 2017 Hi, I was working with my trial version of 3D Coat, and I noticed that it generates UV islands that are completely aligned with the wire frame without some over extension. With the painted UV that I exported from 3D Coat, I get this seam line in 3DS MAX. Is there a setting to automatically fill up the uv island edges? Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted February 23, 2017 Contributor Report Share Posted February 23, 2017 Your map lacks 'padding' around each island. Edit>General>Padding: Always Make Padding. In realtime Padding Mode use "Take interpolated color". Quote Link to comment Share on other sites More sharing options...
New Member deadlyjimmy Posted February 23, 2017 Author New Member Report Share Posted February 23, 2017 It seems that my padding width was set way too high and that was causing an error. Thank you, Tony. Problem solved. Quote Link to comment Share on other sites More sharing options...
