Member Andy C Posted January 6, 2018 Member Report Share Posted January 6, 2018 on version 4.8.03 I've got an issue (see pic - applying the text just resulted in the line) wherein text won't appear. If it applies at all, it applies as if it were just a click and drag with a sculpt tool. I 'solved' it once by deleting my 3d coat user files, but it's just recurred a few days later. I wonder if anyone else encountered/fixed this? I saw mention of something similar in the forum but that said it was fixed early in v4 life cycle. Quote Link to comment Share on other sites More sharing options...
Advanced Member houGenie Posted January 7, 2018 Advanced Member Report Share Posted January 7, 2018 Hi, I have version 4.8.08 and it works for me with the same settings. And it seems you have enough resolution for the plane. Interesting ... Quote Link to comment Share on other sites More sharing options...
Member Andy C Posted January 7, 2018 Author Member Report Share Posted January 7, 2018 Thanks for replying. yes, I'm puzzled. It works 'out of the box' but something in user settings after a while, stops it working. I've tried most of the settings in the text dialogue with same non result. For completeness I'll mention that voxel text in empty space simply doesn't 'apply' (i.e. it doesn't appear). My inner geek wonders if there's a logging feature that can be turned on in 3d coat. I will try 4.08.7 (seems to be latest Beta I believe) for a bit and see if it happens again. Quote Link to comment Share on other sites More sharing options...
Member Andy C Posted January 14, 2018 Author Member Report Share Posted January 14, 2018 I've just had similar problems with curves - the green/red balls don't appear. I renamed parts of user profile data (documents\3d-coatv48\) to test, and found renaming toolspresets (so the software recreates it) fixed curves issue. I guess would fix the above as well, but can't test at the moment. sharing as it's better than renaming whole user profile. Quote Link to comment Share on other sites More sharing options...
