Contributor sshadows Posted December 26, 2011 Contributor Report Share Posted December 26, 2011 Hi, Cinemates! It is a Cinema4D Appllink for MacOS, for a while to R13. This version does have some limitations - the second tab is disabled by some reasons. I will fixed it in future versions. How to install: 1. Download .zip file. 2. Unzip this file. 3. Start this file from Finder. 4. Cinema R13 must be installed at path to: "/Applications/MAXON/CINEMA 4D R13/" 5. Follow by the Installer. Just click to NEXT button. 6. After installation, start a Cinema4D. 7. In Plugins Menu, you found a section "Applink 3DCoat". 8. Set a TEMP Folder. 9. Note, that Exchange Folder setup correctly. 10. Select object or objects, set preferences. 11. Push Export button. 12. Switch to 3D-Coat application. Work in. 13. After done work, File->Open In Original App. 14. Wait. 15. Switch to Cinema4D. 16. Set preferences in Import section. 17. Push Import button. 18. Enjoy. Known issue: 1. Plugin crashed by Import object with n-gons more than 4. Applink_Cinema4D_R13.pkg.zip Quote Link to comment Share on other sites More sharing options...
Contributor sshadows Posted December 30, 2011 Author Contributor Report Share Posted December 30, 2011 Applink for Cinema R12 and R11.5. Applink_Cinema4D_R12.pkg.zip Applink_Cinema4D_R115.pkg.zip Quote Link to comment Share on other sites More sharing options...
Contributor sshadows Posted October 8, 2012 Author Contributor Report Share Posted October 8, 2012 Andrew asked me to share a source code. Welcome. P.S. Version without triangulate. Applink_Cinema4D_R13MacOS_SRC.zip Quote Link to comment Share on other sites More sharing options...
Member Anadin Posted November 21, 2012 Member Report Share Posted November 21, 2012 Interestingly the R13 exporter was working fine in R14 with Beta4 of 3CoatV4 but is not working with R14 and Beta5 of 3DCoatv4 it still works 3DCoatv3.7 Has the exchange data format changed or something? Quote Link to comment Share on other sites More sharing options...
Member Anadin Posted November 21, 2012 Member Report Share Posted November 21, 2012 OK sorry, ignore me I reset the exchange path and it is working again. Quote Link to comment Share on other sites More sharing options...
Contributor sshadows Posted May 28, 2013 Author Contributor Report Share Posted May 28, 2013 Hello! This is a new applink for Cinema4D R14. Enjoy. ApplinkCinema4DR14.zip Quote Link to comment Share on other sites More sharing options...
Member Anadin Posted June 30, 2013 Member Report Share Posted June 30, 2013 Fantastic! thanks sshadows! Quote Link to comment Share on other sites More sharing options...
Taros Posted July 14, 2013 Report Share Posted July 14, 2013 Important infos for AppLink users who have problems: http://3d-coat.com/forum/index.php?showtopic=10198&p=96605 Best wishes Chris Quote Link to comment Share on other sites More sharing options...
Contributor sshadows Posted October 12, 2013 Author Contributor Report Share Posted October 12, 2013 (edited) Hi all! I made a new applink for Cinema R15. Its worked for both V3 & V4. Cheers! ApplinkCinemaR15.pkg.zip Edited October 12, 2013 by sshadows Quote Link to comment Share on other sites More sharing options...
Member maxtab Posted October 27, 2013 Member Report Share Posted October 27, 2013 this topic only for MacOs user? If yes, were i acan read about windows user. Thanks Quote Link to comment Share on other sites More sharing options...
Contributor sshadows Posted October 27, 2013 Author Contributor Report Share Posted October 27, 2013 Yes, only for Mac-users. Topic for Win-users is there http://3d-coat.com/forum/index.php?showtopic=7574&page=2 Quote Link to comment Share on other sites More sharing options...
Member TBA3D Posted November 11, 2013 Member Report Share Posted November 11, 2013 Hi all! I made a new applink for Cinema R15. Its worked for both V3 & V4. Cheers! Thanks for the updated version! Quote Link to comment Share on other sites More sharing options...
Contributor sshadows Posted June 14, 2014 Author Contributor Report Share Posted June 14, 2014 Hi, all! I created repository on GitHub https://github.com/sshumihin/3DCoat_Applinks/tree/master/Applink_Cinema4D. There are plugins and source code for Win and Mac by Cinema version. Welcome. Svyatoslav S. 1 Quote Link to comment Share on other sites More sharing options...
