Posted
Hi all!
I created repository on GitHub https://github.com/sshumihin/3DCoat_Applinks/tree/master/Applink_Cinema4D.
There are plugins  and source code for Win and Mac by Cinema version.
Usage:
Unzip zip, install, enjoy.
Video tutorial on Vimeo http://www.vimeo.com/19510449.
Svyatoslav S.
Note:
This seems to have an updated applink for R17: https://github.com/sshumihin/3DCoat_Applinks/tree/master/Applink_Cinema4D
On 1/18/2014 at 11:19 AM, Decade said:
You don't need to do anything as drastic as move your Cinema 4D program folder.
Cinema 4D has 2 possible locations for plugin install : In the program files 'plugins' folder & in the user's 'plugins' folder.
Just open Cinema 4D's preferences from Edit > Preferences.
In the bottom left of the window is a button that says 'Open preferences folder'. I like to create a desktop shortcut to this folder.
Move the App-link folder into the 'Plugins' folder you find here. Then you won't have problems any more.
In general, you should always try to install your plugins here not in the programs folder, unless you're specifically instructed otherwise.
- If the "Import From 3D-Coat" feature doesn't work:
Going to File>Open in Original App and in C4D clicking on "Import From 3D-Coat", does work.
  • Replies 75
  • Created
  • Last Reply
Top Posters In This Topic
  • sshadows
    13
  • Aleksey
    11
  • gswartz
    6
  • Tony Nemo
    4
  • 3 months later...
Posted
Applink dont support non-latin symbols. Please, rename username to english.
  • 5 months later...
Posted
Hi all!
Now, i made plugin for C4D R12 on Windows(32/64). For a while... Later, i will compile for R11. Installer include.
Usage:
A new version of the Applink for Cinema4D R13 available. Only for Windows 32/64.
Added two features for Exporter:
- checkbox "Skip Import Dialog" (allows to skip 3D-Coat import dialog, default options will be used);
- checkbox "Skip Export Dialog" (allows to skip 3D-Coat export dialog. Previous settings will be used);
Have a nice day.
ApplinkCinema4DR13win_v1.00.zip
  • 10 months later...
  • 7 months later...
Posted
Thank you soooooooooooo much!!!
  • 2 weeks later...
Posted
I'm playing with the v4 demo and I am also running cinema 4d r14. I installed the latest applink from this thread but when I then click the Export to 3D Coat button and then go into 3d coat, nothing shows up. In the script console in c4d I don't see any errors. Has anyone else gotten this applink to work with 3d coat 4 and c4d 14? Thanks.
Posted
Try to change the path for preferences to 3DCoat-V4.
post-3858-0-88500300-1370116769_thumb.gi
Posted
Thanks for the help. I'm not sure if that did it or if it was the fact that I might not have actually had the mesh selected before hitting export... lol. I updated my prefs and tried to export again but nothing. Then I realized I didn't have the mesh selected. Anyway, now it's importing but the applink video for c4d doesn't show dropping a voxel object, only pixel painting and I'm getting some odd results. Please see this video to see what I'm running into. Notice that each side of the cube has these lines that don't exist on the original cube and around the edges it looks like they're doubled. Why is this happening? Thanks.
Posted
Oh, sorry, the password for the video is 3dcoat.
Posted
gswartz, it`is a normal work of 3DC with voxel modeling, not a bug of applink.
Posted
So you're saying that when I bring a model into 3d coat that I'll get artifacts on it that I then have to try and get rid of?
Posted
I tried the same thing with the applink and got a warning about the size so I chose automapping and got this:
post-1430-0-86879400-1370314487_thumb.pn
I used C4D 11.5.
