Showing results for tags 'crash'.
  1. Hello! I am having an issue with our floating licenses of 3D Coat. 4.5.40 and 4.7 are crashing on startup while 4.5.23 runs fine. On startup, the interface just quits BOOM. I get the load screen, then the interface window comes up briefly, then it shuts off. Machine specs are: iMacs Retina 5k 27 inch late 2015 3.2 Ghz Intel i5 16 GB Ram 1867 MHz DDR3 AMD Radeon R9 M390 2048 MB I have attached the crash report. Excelsior! Eric Kunzendorf Jacksonville University ekunzen@ju.edu 3DCoatCrashReport.txt
  2. 1. Create voxel model 2. Switch to paint room 3. Start paint -> then program crush immediately I'm on mac, version 4.5.40.
  3. Hello 3D COAT community I'm new to come here and testing 3D COAT4.5 in trial mode on my computer. As the title says, 3D COAT crashes when I implement "calculate occlusion" in texture menu. So I couldn't use some of the smart materials. The error message is as follows: "The procedure entry point? destroy@task_base@internal@interface5@tbb@SAXAAVtask@4@@z could not be located in the dynamic link library tbb_debug.dll" I ues windows 7 64bit I have no idea what to do so I really appreciate if someone gives me any information. Thanks!
  4. Hi guys! I'm keen to know if this problem's being looked at for the next stable build or if it's been fixed in a beta already - I can't use the beta at work as we're mid project. Thanks for any news you can offer! I'm regularly moving between PC and Mac at work (we paid extra for the dual platform license) and in .19 I'm battling the problem of windows saved files crashing mac 3D Coat on load. The app just hangs and has to be force quit. Both have the latest stable build of 3d coat. The other way has no problems: Mac saved files open fine on windows. I'm only working in the paint room. Sorry I couldn't put this in the support/paint room forum, I don't have permission to create a topic. Thanks!
  5. I was attempting to apply the Vox Extrude tool after making a selection, the layer was in surface mode, but it was the only layer visible. There were several other layers but they were turned off. I was having some odd behavior with the auto-save previously where I would see the counter counting down and I would ctrl-s save, which would cause the count-down to disappear as it should but then it would re-appear and start counting where it left off before I saved, as though it wasn't recognizing my save attempt. Then, when I put my above note into the crash reporter and tried to send my crash I got this error: Fatal error: Cannot access empty property in /var/www/vhosts/3dcoat.com/httpdocs/typo3conf/ext/bug_report/pi1/class.tx_bugreport_pi1.php on line 107 So I've attached my crash output to this post as well as the above comments. Hope that helps fix things!
  6. Hi. Version: 4.5.19(DX64) on Windows7 Home Steps to reproduce: 1. Run 3D-Coat 2. Open any project or not to open anything. 3. Windows -> Popups -> Color Swatches 4. Click dropdown on Color Swatches window, then click "Load..." 5. Click Cancel 6. Wait a few seconds... 7. Crash. See screenshot in attachment.
  7. I hate to be a nuisance from day one but I've installed and reinstalled the program and turned off my Firewall and antivirus but it still won't open up with any of the four options. I have Windows 10 so I waited and used the Start menu to try each. It just gives a "Can't open log file." !!Crash!!.log response for all of them. I have an AMD Radeon R9 200 series with 3 Gigs and 16 gigs of main ram. I just updated to Radeon Crimson 15.112 so it's OpenGL 6.14.10 and OpenCL 2.0.4.0, if that helps. Again, I just bought the program and am unable to launch it even once. I contacted support and Andrew suggested this but it made no difference. With the time change it may be a while before he can get back to me again. "Please delete folder MyDocuments/3D-CoatV45/ Possibly some files got corrupted there so it crashes. Try no-CUDA version." The only file in that folder was a single xml. I deleted the folder as suggested. It still crashes with same error trying both no-Cuda. Even tried CUDA again but same. I can't find a log file anywhere either. Please note that I did install the 64 bit program on my E: drive, not the C:, but I do this with all other programs without any problem most of the time. Any help appreciated.
  8. Sharur3D
    Voxelization crash
    Hello, I got 3DCoat in order to do some destruction sculpting. Unfortunately, it constantly crashes when I substract (error message says: increase size of virtual memory). And I did just like it was described in one of the earlier posts. The issue keeps repeating. Also, I can import objects, which have more than 10 mil polygons, but that's not the biggest problem. Also, there's a problem, that 3DCoat automatically merges complex objects into one mesh. It completely destroys meshes like brick wall, made from separate bricks. Anybody has this issue, know how to fix it?
  9. Hi there, i just found out about 3d coating and wanted to test it. Im still running snow leopard but i noticed that this is still supported. if im correct this system has openGL 3.2, but i have a Ate RadeonHD 4750. When i open the application it immediately crashes. Whish they had some more easier way to find the specs needed. If any of you guys know something or can help. C&C is welcome
  10. Hello, I am pretty desperate. I really like 3dcoat so far but it is always crashing on me. While I use the UV tools, it simply crashes at random times. I did manage to get my seaming done tough, and now when i try to unwrap, i crashes. I did try another machine too, it crashes aswell. The model i try to UV is made in Blender My Pc is running Win 8.1 Pro 64-Bit Intel Core i5 4670K @3.40 GHz 8GB Ram Saphhire 7870XT with Boost I recreated the crash and here is the error log Version:3D-COAT 4.1.17(DX64) Memory status: OK pointers: 47553 Video: AMD Radeon HD 7800 Series AMD Radeon HD 7800 Series AMD Radeon HD 7800 Series AMD Radeon HD 7800 Series AMD Radeon HD 7800 Series AMD Radeon HD 7800 Series iDisplay (Microsoft Corporation - WDDM v1.1) nproc: 4 (1)object: (E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\UV-3.3b) vert: 13881 poly: 0 rt:256x256 undo: (1) tool: uv_mapper_tool NumMeshLoads: 1 Time since mesh loading: 10 s VoxelTool: 0 RetopoTool: 3 UV_Tool: 1 40BC082C c:\3dcoat\3d-coat\3d-coatv4\3d-coat\abf\abf_core.cpp line 1187 [+0], UnwrapCluster::ExportUV+588 405A5137 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\uv_mapper.cpp line 7769 [+0], ClusteredMesh::Unwrap+567 405BAC71 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\uv_mapper.cpp line 10252 [+0], UV_map_Tool::Unwrap+33 404114AA c:\3dcoat\3d-coat\3d-coatv4\3d-coat\uv_mapper.h line 1308 [+0], UV_map_Tool::ActivateExtraCommandTemp+346 402A73D2 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\peninterface.cpp line 18568 [+0], PenInterface::ActivateEnumMode+66 4046503B c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.cpp line 1067 [+12], BaseWidget::CallCallbacks+395 4046D9BE c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.cpp line 2868 [+14], sp_click+78 4046E4B6 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.cpp line 3041 [+0], SPLBUp+134 4006098C c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.h line 603 [+0], wpcallback<PenInterface>::call+892 4046503B c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.cpp line 1067 [+12], BaseWidget::CallCallbacks+395 40467976 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.cpp line 1690 [+5], Widgets::ProcessWindowsMessages+758 40481F12 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.cpp line 6839 [+0], IntfWidget1::OnButtonUp+130 407A9D86 c:\3dcoat\3d-coat\3d-coatv4\comms\cwidget.cpp line 486 [+26], comms::cWidgets::HandleInputEvents+1110 40E7EEAA c:\3dcoat\3d-coat\3d-coatv4\main.cpp line 114 [+0], comms::cMain_OnRender+74 407C1690 c:\3dcoat\3d-coat\3d-coatv4\comms\cwinmain.cpp line 616 [+0], cWinMain_OnRender+176 407C6807 c:\3dcoat\3d-coat\3d-coatv4\comms\cwinmain.cpp line 2064 [+0], cWinMain_OneIterationOfMessageLoop+247 407C971C c:\3dcoat\3d-coat\3d-coatv4\comms\cwinmain.cpp line 2344 [+15], WinMain+10460 40F3DC93 f:\dd\vctools\crt_bld\self_64_amd64\crt\src\crt0.c line 263 [+33], __tmainCRTStartup+391 314616AD line 0 [+0], BaseThreadInitThunk+13 33AB4409 line 0 [+0], RtlUserThreadStart+29 33AB4409 line 0 [+0], RtlUserThreadStart+29 General information: Exception code:C0000005 3D-COAT 4.1.17(DX64) Memory status before run: Memory load: 31 TotalPhys: 4216586240 AvailPhys: 1535922176 TotalPageFile: 4216586240 AvailPageFile: 1307389952 TotalVirtual: 4294836224 AvailVirtual: 4092317696 Memory status after crash: Memory load: 35 TotalPhys: 4216586240 AvailPhys: 1175879680 TotalPageFile: 4216586240 AvailPageFile: 891506688 TotalVirtual: 4294836224 AvailVirtual: 3596349440 AvailVirtual: 3596349440 Module found D:\Program Files\3D-Coat-V4\3d-CoatDX64S.exe (\3d-CoatDX64S.exe) Handle: 0000000140000000 Base address: 0000000140000000 Module found C:\WINDOWS\SYSTEM32\ntdll.dll (ntdll.dll) Handle: 00007FFA33A60000 Base address: 00007FFA33A60000 Module found C:\WINDOWS\system32\KERNEL32.DLL (KERNEL32.DLL) Handle: 00007FFA31460000 Base address: 00007FFA31460000 Module found C:\WINDOWS\system32\KERNELBASE.dll (KERNELBASE.dll) Handle: 00007FFA30F40000 Base address: 00007FFA30F40000 Module found C:\WINDOWS\system32\apphelp.dll (apphelp.dll) Handle: 00007FFA2F9F0000 Base address: 00007FFA2F9F0000 Module found C:\WINDOWS\AppPatch\AppPatch64\AcLayers.DLL (C:\WINDOWS\AppPatch\AppPatch64\AcLayers.DLL) Handle: 00007FFA033D0000 Base address: 00007FFA033D0000 Module found C:\WINDOWS\system32\msvcrt.dll (msvcrt.dll) Handle: 00007FFA31D00000 Base address: 00007FFA31D00000 Module found C:\WINDOWS\system32\USER32.dll (USER32.dll) Handle: 00007FFA33650000 Base address: 00007FFA33650000 Module found C:\WINDOWS\system32\SHLWAPI.dll (SHLWAPI.dll) Handle: 00007FFA31390000 Base address: 00007FFA31390000 Module found C:\WINDOWS\SYSTEM32\sfc.dll (sfc.dll) Handle: 00007FFA1E2F0000 Base address: 00007FFA1E2F0000 Module found C:\WINDOWS\SYSTEM32\WINSPOOL.DRV (WINSPOOL.DRV) Handle: 00007FFA2C6E0000 Base address: 00007FFA2C6E0000 Module found C:\WINDOWS\system32\GDI32.dll (GDI32.dll) Handle: 00007FFA337D0000 Base address: 00007FFA337D0000 Module found C:\WINDOWS\SYSTEM32\combase.dll (combase.dll) Handle: 00007FFA317F0000 Base address: 00007FFA317F0000 Module found C:\WINDOWS\system32\RPCRT4.dll (RPCRT4.dll) Handle: 00007FFA33920000 Base address: 00007FFA33920000 Module found C:\WINDOWS\SYSTEM32\sfc_os.DLL (sfc_os.DLL) Handle: 00007FFA287E0000 Base address: 00007FFA287E0000 Module found C:\WINDOWS\SYSTEM32\SortWindows61.dll (SortWindows61.dll) Handle: 00007FFA1DBB0000 Base address: 00007FFA1DBB0000 Module found C:\WINDOWS\system32\IMM32.DLL (IMM32.DLL) Handle: 00007FFA31410000 Base address: 00007FFA31410000 Module found C:\WINDOWS\system32\MSCTF.dll (MSCTF.dll) Handle: 00007FFA33510000 Base address: 00007FFA33510000 Module found C:\WINDOWS\system32\WS2_32.dll (WS2_32.dll) Handle: 00007FFA31330000 Base address: 00007FFA31330000 Module found C:\WINDOWS\system32\COMDLG32.dll (COMDLG32.dll) Handle: 00007FFA31DB0000 Base address: 00007FFA31DB0000 Module found C:\WINDOWS\system32\ADVAPI32.dll (ADVAPI32.dll) Handle: 00007FFA31B90000 Base address: 00007FFA31B90000 Module found C:\WINDOWS\system32\SHELL32.dll (SHELL32.dll) Handle: 00007FFA32100000 Base address: 00007FFA32100000 Module found C:\WINDOWS\system32\ole32.dll (ole32.dll) Handle: 00007FFA31F80000 Base address: 00007FFA31F80000 Module found C:\WINDOWS\system32\OLEAUT32.dll (OLEAUT32.dll) Handle: 00007FFA31C40000 Base address: 00007FFA31C40000 Module found D:\Program Files\3D-Coat-V4\tbbmalloc.dll (\tbbmalloc.dll) Handle: 0000000180000000 Base address: 0000000180000000 Module found D:\Program Files\3D-Coat-V4\tbb.dll (\tbb.dll) Handle: 0000000000270000 Base address: 0000000000270000 Module found C:\WINDOWS\SYSTEM32\VERSION.dll (VERSION.dll) Handle: 00007FFA2E8D0000 Base address: 00007FFA2E8D0000 Module found C:\WINDOWS\SYSTEM32\NETAPI32.dll (NETAPI32.dll) Handle: 00007FFA2EA70000 Base address: 00007FFA2EA70000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.9600.16384_none_34a8918f959016ea\COMCTL32.dll (C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.9600.16384_none_34a8918f959016ea\COMCTL32.dll) Handle: 00007FFA30E90000 Base address: 00007FFA30E90000 Module found C:\WINDOWS\SYSTEM32\d3d9.dll (d3d9.dll) Handle: 00007FFA1BD60000 Base address: 00007FFA1BD60000 Module found C:\WINDOWS\SYSTEM32\d3dx9_38.dll (d3dx9_38.dll) Handle: 000000006D3C0000 Base address: 000000006D3C0000 Module found C:\WINDOWS\SYSTEM32\WININET.dll (WININET.dll) Handle: 00007FFA29620000 Base address: 00007FFA29620000 Module found C:\WINDOWS\system32\NSI.dll (NSI.dll) Handle: 00007FFA31600000 Base address: 00007FFA31600000 Module found C:\WINDOWS\SYSTEM32\sechost.dll (sechost.dll) Handle: 00007FFA315A0000 Base address: 00007FFA315A0000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_08e793bfa83a89b5\MSVCR90.dll (C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_08e793bfa83a89b5\MSVCR90.dll) Handle: 000000006FC80000 Base address: 000000006FC80000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_08e793bfa83a89b5\MSVCP90.dll (C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_08e793bfa83a89b5\MSVCP90.dll) Handle: 000000006D2E0000 Base address: 000000006D2E0000 Module found C:\WINDOWS\SYSTEM32\netutils.dll (netutils.dll) Handle: 00007FFA30070000 Base address: 00007FFA30070000 Module found C:\WINDOWS\SYSTEM32\srvcli.dll (srvcli.dll) Handle: 00007FFA30B90000 Base address: 00007FFA30B90000 Module found C:\WINDOWS\SYSTEM32\wkscli.dll (wkscli.dll) Handle: 00007FFA2EA30000 Base address: 00007FFA2EA30000 Module found C:\WINDOWS\SYSTEM32\dwmapi.dll (dwmapi.dll) Handle: 00007FFA2E4A0000 Base address: 00007FFA2E4A0000 Module found C:\WINDOWS\SYSTEM32\iertutil.dll (iertutil.dll) Handle: 00007FFA29860000 Base address: 00007FFA29860000 Module found C:\WINDOWS\SYSTEM32\USERENV.dll (USERENV.dll) Handle: 00007FFA30430000 Base address: 00007FFA30430000 Module found C:\WINDOWS\SYSTEM32\SHCORE.DLL (SHCORE.DLL) Handle: 00007FFA2E670000 Base address: 00007FFA2E670000 Module found C:\WINDOWS\SYSTEM32\profapi.dll (profapi.dll) Handle: 00007FFA30DC0000 Base address: 00007FFA30DC0000 Module found C:\WINDOWS\SYSTEM32\kernel.appcore.dll (kernel.appcore.dll) Handle: 00007FFA2FC40000 Base address: 00007FFA2FC40000 Module found C:\WINDOWS\SYSTEM32\CRYPTBASE.dll (CRYPTBASE.dll) Handle: 00007FFA30C90000 Base address: 00007FFA30C90000 Module found C:\WINDOWS\SYSTEM32\bcryptPrimitives.dll (bcryptPrimitives.dll) Handle: 00007FFA30C30000 Base address: 00007FFA30C30000 Module found C:\WINDOWS\system32\uxtheme.dll (uxtheme.dll) Handle: 00007FFA2FAC0000 Base address: 00007FFA2FAC0000 Module found C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll (C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll) Handle: 00007FFA2C350000 Base address: 00007FFA2C350000 Module found C:\WINDOWS\SYSTEM32\oleacc.dll (oleacc.dll) Handle: 00007FFA2C670000 Base address: 00007FFA2C670000 Module found C:\WINDOWS\SYSTEM32\clbcatq.dll (clbcatq.dll) Handle: 00007FFA31ED0000 Base address: 00007FFA31ED0000 Module found C:\WINDOWS\SYSTEM32\aticfx64.dll (aticfx64.dll) Handle: 00007FFA2E8E0000 Base address: 00007FFA2E8E0000 Module found C:\WINDOWS\SYSTEM32\atiu9p64.dll (atiu9p64.dll) Handle: 00007FFA08CD0000 Base address: 00007FFA08CD0000 Module found C:\WINDOWS\SYSTEM32\atiumd64.dll (atiumd64.dll) Handle: 00007FFA081F0000 Base address: 00007FFA081F0000 Module found C:\WINDOWS\SYSTEM32\atiumd6a.dll (atiumd6a.dll) Handle: 000000006DC60000 Base address: 000000006DC60000 Module found C:\WINDOWS\SYSTEM32\Wintab32.dll (Wintab32.dll) Handle: 00007FFA07050000 Base address: 00007FFA07050000 Module found C:\WINDOWS\SYSTEM32\WTSAPI32.dll (WTSAPI32.dll) Handle: 00007FFA2F9D0000 Base address: 00007FFA2F9D0000 Module found C:\WINDOWS\SYSTEM32\Pen_Tablet.dll (Pen_Tablet.dll) Handle: 00007FFA2C100000 Base address: 00007FFA2C100000 Module found C:\WINDOWS\SYSTEM32\CRYPTSP.dll (CRYPTSP.dll) Handle: 00007FFA306E0000 Base address: 00007FFA306E0000 Module found C:\WINDOWS\system32\rsaenh.dll (rsaenh.dll) Handle: 00007FFA30320000 Base address: 00007FFA30320000 Module found C:\WINDOWS\SYSTEM32\bcrypt.dll (bcrypt.dll) Handle: 00007FFA30910000 Base address: 00007FFA30910000 Log.txt: Loading Xml file "Xmls/Settings.xml"... Can't load file "Xmls/Settings.xml" ------------------------------------------------------------ Graphics card and driver info ------------------------------------------------------------ Direct3D Renderer Adapter: AMD Radeon HD 7800 Series Driver: aticfx64.dll Supported: Vertex shaders 3.0 Pixel shaders 3.0 MRT (targets: 4) Non power of two ------------------------------------------------------------ Registering vertex formats... Added "TIF" image codec. Added "TIFF" image codec. Added "EXR" image codec. - Loading font "Calibri 11"... Can't load file "Fonts/Calibri 11.cFont" - Loading font "Calibri 16"... Can't load file "Fonts/Calibri 16.cFont" - Loading font "Calibri B24"... Can't load file "Fonts/Calibri B24.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma B8"... Can't load file "Fonts/Tahoma B8.cFont" Can't load image file "Textures\WindowsStandard\ToolBar.bmp" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" Version : 3D-COAT 4.1.17(DX64) * Loading shader "Shaders/hud2t.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/hud_smooth.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/hud.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/LinesPointsUI.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/Colored.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/RenderSystem.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/RenderSystem.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/text2.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_COLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_render_color.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_render_normals.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_render_mrt.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_nrm.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_alpha.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_all.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/obj_preview_pen2.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/inrect.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/obj_preview_pen2.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/preview_rect.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/draw_pic_over_curve.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/draw_pic_over_curve.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/preview_fill.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/uv.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/wires.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/wires.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/sphere.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_preview_pen.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/mcubes.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mpreview.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mpreview1.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/Font.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mcubes_rt.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mcubes_nrm.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... ------------------------------------------------------------ WinTab Device Name: WACOM Tablet Max Pressure: 1023 ------------------------------------------------------------ Can't load image file "Levels\Uv\Uv_d" AppLink search path registered: D:\Libraries\Documents/3D-CoatV4/Exchange/ AppLink search path registered: D:\Libraries\Documents/3D-CoatV3/Exchange/ cMeshIO::AddCodec(): Added "Obj" mesh codec. cMeshIO::AddCodec(): Added "Lwo" mesh codec. cMeshIO::AddCodec(): Added "Fbx" mesh codec. cMeshIO::AddCodec(): Added "Stl" mesh codec. cMeshIO::AddCodec(): Added "Ply" mesh codec. cMeshIO::AddCodec(): Added "dae" mesh codec. cMeshIO::AddCodec(): Added "wrl" mesh codec. cMeshIO::LoadMesh(): Loaded mesh file "D:\Program Files\3D-Coat-V4\ToolsPresets\\Sphere.obj". cMeshIO::LoadMesh(): Loaded mesh file "D:\Program Files\3D-Coat-V4\ToolsPresets\\Ring.obj". cMeshIO::LoadMesh(): Loaded mesh file "D:\Program Files\3D-Coat-V4\ToolsPresets\\Cone.obj". cMeshIO::LoadMesh(): Loaded mesh file "D:\Program Files\3D-Coat-V4\ToolsPresets\\Cylinder.obj". cMeshIO::LoadMesh(): Loaded mesh file "D:\Program Files\3D-Coat-V4\ToolsPresets\\Cube.obj". cMeshIO::LoadMesh(): Loaded mesh file "D:\Program Files\3D-Coat-V4\ToolsPresets\\Sector.obj". Loaded image file "textures\pens\rock.tga" Can't load file "D:\Libraries\Documents/3D-CoatV4/license.dat" Can't load file "license.dat" Loaded image file "textures\icons64\Grow_Vox_02.png" Can't load image file "textures\tooltips\Grow_Vox_02.png" Loaded image file "textures\icons64\smooth_Vox.png" Can't load image file "textures\tooltips\smooth_Vox.png" Loaded image file "textures\icons64\Fill.png" Can't load image file "textures\tooltips\Fill.png" Loaded image file "textures\icons64\Clay_Vox.png" Can't load image file "textures\tooltips\Clay_Vox.png" Loaded image file "textures\icons64\Carve.png" Can't load image file "textures\tooltips\Carve.png" Loaded image file "textures\icons64\Blob_Vox.png" Can't load image file "textures\tooltips\Blob_Vox.png" Loaded image file "textures\icons64\Cutoff_Vox.png" Can't load image file "textures\tooltips\Cutoff_Vox.png" Loaded image file "textures\icons64\Airbrush_Vox.png" Can't load image file "textures\tooltips\Airbrush_Vox.png" Loaded image file "textures\icons64\Build_Vox_02.png" Can't load image file "textures\tooltips\Build_Vox_02.png" Loaded image file "textures\icons64\Extrude_Vox.png" Can't load image file "textures\tooltips\Extrude_Vox.png" Loaded image file "textures\icons64\Sphere_Vox.png" Can't load image file "textures\tooltips\Sphere_Vox.png" Loaded image file "textures\icons64\2D_Piant_Vox.png" Can't load image file "textures\tooltips\2D_Piant_Vox.png" Loaded image file "textures\icons64\Plane_Vox.png" Can't load image file "textures\tooltips\Plane_Vox.png" Loaded image file "textures\icons64\Scrape_Vox.png" Can't load image file "textures\tooltips\Scrape_Vox.png" Loaded image file "textures\icons64\Pinch_Vox.png" Can't load image file "textures\tooltips\Pinch_Vox.png" Loaded image file "textures\icons64\Smudge_Vox.png" Can't load image file "textures\tooltips\Smudge_Vox.png" Loaded image file "textures\icons64\Measure.png" Can't load image file "textures\tooltips\Measure.png" Loaded image file "textures\icons64\Pick.png" Can't load image file "textures\tooltips\Pick.png" Loaded image file "textures\icons64\Pose.png" Can't load image file "textures\tooltips\Pose.png" Loaded image file "textures\icons64\Move.png" Can't load image file "textures\tooltips\Move.png" Loaded image file "textures\icons64\Hide.png" Can't load image file "textures\tooltips\Hide.png" Loaded image file "textures\icons64\Cell.png" Can't load image file "textures\tooltips\Cell.png" Loaded image file "textures\icons64\Copy.png" Can't load image file "textures\tooltips\Copy.png" Loaded image file "textures\icons64\Transform.png" Can't load image file "textures\tooltips\Transform.png" Loaded image file "textures\icons64\Instancer.png" Can't load image file "textures\tooltips\Instancer.png" Loaded image file "textures\icons64\Warp.png" Can't load image file "textures\tooltips\Warp.png" Loaded image file "textures\icons64\Axial.png" Can't load image file "textures\tooltips\Axial.png" Loaded image file "textures\icons64\Bass-Releif.png" Can't load image file "textures\tooltips\Bass-Releif.png" Loaded image file "textures\icons64\Vox_Layer.png" Can't load image file "textures\tooltips\Vox_Layer.png" Loaded image file "textures\icons64\LOGO.png" Can't load image file "textures\tooltips\LOGO.png" Loaded image file "textures\icons64\Clone_Copy.png" Can't load image file "textures\tooltips\Clone_Copy.png" Loaded image file "textures\icons64\Clone_VOX.png" Can't load image file "textures\tooltips\Clone_VOX.png" Loaded image file "textures\icons64\Split_Vox.png" Can't load image file "textures\tooltips\Split_Vox.png" Loaded image file "textures\icons64\Merge.png" Can't load image file "textures\tooltips\Merge.png" Loaded image file "textures\icons64\Sketch_Tool.png" Can't load image file "textures\tooltips\Sketch_Tool.png" Loaded image file "textures\icons64\curves.png" Can't load image file "textures\tooltips\curves.png" Loaded image file "textures\icons64\Snake.png" Can't load image file "textures\tooltips\Snake.png" Loaded image file "textures\icons64\Spkie.png" Can't load image file "textures\tooltips\Spkie.png" Loaded image file "textures\icons64\toothPaste.png" Can't load image file "textures\tooltips\toothPaste.png" Loaded image file "textures\icons64\Muscle.png" Can't load image file "textures\tooltips\Muscle.png" Loaded image file "textures\icons64\Primatives.png" Can't load image file "textures\tooltips\Primatives.png" Loaded image file "textures\icons64\Text.png" Can't load image file "textures\tooltips\Text.png" Loaded image file "textures\icons64\Cloth.png" Can't load image file "textures\tooltips\Cloth.png" Loaded image file "textures\icons64\Draw_Surf.png" Can't load image file "textures\tooltips\Draw_Surf.png" Loaded image file "textures\icons64\Pinch_Surf.png" Can't load image file "textures\tooltips\Pinch_Surf.png" Loaded image file "textures\icons64\Shift_Surf.png" Can't load image file "textures\tooltips\Shift_Surf.png" Loaded image file "textures\icons64\Flatten_Surf.png" Can't load image file "textures\tooltips\Flatten_Surf.png" Loaded image file "textures\icons64\Clay_Surf.png" Can't load image file "textures\tooltips\Clay_Surf.png" Loaded image file "textures\icons64\Rapid_Surf.png" Can't load image file "textures\tooltips\Rapid_Surf.png" Loaded image file "textures\icons64\Increase_Res.png" Can't load image file "textures\tooltips\Increase_Res.png" Loaded image file "textures\icons64\Resample.png" Can't load image file "textures\tooltips\Resample.png" Loaded image file "textures\icons64\Clear.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Smooth_All.png" Can't load image file "textures\tooltips\Smooth_All.png" Loaded image file "textures\icons64\Chisel_Surf.png" Can't load image file "textures\tooltips\Chisel_Surf.png" Loaded image file "textures\icons64\Build_Vox_02.png" Can't load image file "textures\tooltips\Build_Vox_02.png" Loaded image file "textures\icons64\Fill.png" Can't load image file "textures\tooltips\Fill.png" Loaded image file "textures\icons64\Inflate_Clay_LC.png" Can't load image file "textures\tooltips\Inflate_Clay_LC.png" Loaded image file "textures\icons64\Extrude_Surf.png" Can't load image file "textures\tooltips\Extrude_Surf.png" Loaded image file "textures\icons64\Gum.png" Can't load image file "textures\tooltips\Gum.png" Loaded image file "textures\icons64\Absolute.png" Can't load image file "textures\tooltips\Absolute.png" Loaded image file "textures\icons64\Freeze_Surf.png" Can't load image file "textures\tooltips\Freeze_Surf.png" Loaded image file "textures\icons64\Hide_Surf.png" Can't load image file "textures\tooltips\Hide_Surf.png" Loaded image file "textures\icons64\Rapid1_Surf.png" Can't load image file "textures\tooltips\Rapid1_Surf.png" Loaded image file "textures\icons64\Rapid2_Surf.png" Can't load image file "textures\tooltips\Rapid2_Surf.png" Loaded image file "textures\icons64\Scratches1_Surf.png" Can't load image file "textures\tooltips\Scratches1_Surf.png" Loaded image file "textures\icons64\Scratches2_Surf.png" Can't load image file "textures\tooltips\Scratches2_Surf.png" Loaded image file "textures\icons64\Mud1_surf.png" Can't load image file "textures\tooltips\Mud1_surf.png" Loaded image file "textures\icons64\Mud2_surf.png" Can't load image file "textures\tooltips\Mud2_surf.png" Loaded image file "textures\icons64\Decimate.png" Can't load image file "textures\tooltips\Decimate.png" Loaded image file "textures\icons64\TSmooth_LC.png" Can't load image file "textures\tooltips\TSmooth_LC.png" Loaded image file "textures\icons64\Draw_Surf.png" Can't load image file "textures\tooltips\Draw_Surf.png" Loaded image file "textures\icons64\Build_Vox_02.png" Can't load image file "textures\tooltips\Build_Vox_02.png" Loaded image file "textures\icons64\CreaseClay_LC.png" Can't load image file "textures\tooltips\CreaseClay_LC.png" Loaded image file "textures\icons64\Reduce_Clay_LC.png" Can't load image file "textures\tooltips\Reduce_Clay_LC.png" Loaded image file "textures\icons64\Extrude_Clay_LC.png" Can't load image file "textures\tooltips\Extrude_Clay_LC.png" Loaded image file "textures\icons64\Snake_Clay_LC.png" Can't load image file "textures\tooltips\Snake_Clay_LC.png" Loaded image file "textures\icons64\Tube_Clay_LC.png" Can't load image file "textures\tooltips\Tube_Clay_LC.png" Loaded image file "textures\icons64\Smudge_Clay_LC.png" Can't load image file "textures\tooltips\Smudge_Clay_LC.png" Loaded image file "textures\icons64\Inflate_Clay_LC.png" Can't load image file "textures\tooltips\Inflate_Clay_LC.png" Loaded image file "textures\icons64\Swirl_Clay_LC.png" Can't load image file "textures\tooltips\Swirl_Clay_LC.png" Loaded image file "textures\icons64\Ripple_LC.png" Can't load image file "textures\tooltips\Ripple_LC.png" Loaded image file "textures\icons64\Flatten_Surf.png" Can't load image file "textures\tooltips\Flatten_Surf.png" Loaded image file "textures\icons64\Wrincle_Clay_LC.png" Can't load image file "textures\tooltips\Wrincle_Clay_LC.png" Loaded image file "textures\icons64\Remove_Clay_LC.png" Can't load image file "textures\tooltips\Remove_Clay_LC.png" Loaded image file "textures\icons64\General_LC.png" Can't load image file "textures\tooltips\General_LC.png" Loaded image file "textures\icons64\Add_Clusters.png" Can't load image file "textures\tooltips\Add_Clusters.png" Loaded image file "textures\icons64\Mark_Seams.png" Can't load image file "textures\tooltips\Mark_Seams.png" Loaded image file "textures\icons64\Mark_Seams_Edge_Loop.png" Can't load image file "textures\tooltips\Mark_Seams_Edge_Loop.png" Loaded image file "textures\icons64\Select_Path.png" Can't load image file "textures\tooltips\Select_Path.png" Loaded image file "textures\icons64\Clear_Clusters.png" Can't load image file "textures\tooltips\Clear_Clusters.png" Loaded image file "textures\icons64\Clear_Seams.png" Can't load image file "textures\tooltips\Clear_Seams.png" Loaded image file "textures\icons64\Auto_Seams.png" Can't load image file "textures\tooltips\Auto_Seams.png" Loaded image file "textures\icons64\Sharp_Seams.png" Can't load image file "textures\tooltips\Sharp_Seams.png" Loaded image file "textures\icons64\Sharp_Seams.png" Can't load image file "textures\tooltips\Sharp_Seams.png" Loaded image file "textures\icons64\Unwrap.png" Can't load image file "textures\tooltips\Unwrap.png" Loaded image file "textures\icons64\Pack1.png" Can't load image file "textures\tooltips\Pack1.png" Loaded image file "textures\icons64\Pack2.png" Can't load image file "textures\tooltips\Pack2.png" Loaded image file "textures\icons64\Auto_Scale.png" Can't load image file "textures\tooltips\Auto_Scale.png" Loaded image file "textures\icons64\Update_Islands.png" Can't load image file "textures\tooltips\Update_Islands.png" Loaded image file "textures\icons64\Restore_UV.png" Can't load image file "textures\tooltips\Restore_UV.png" Loaded image file "textures\icons64\Apply_UV.png" Can't load image file "textures\tooltips\Apply_UV.png" Loaded image file "textures\icons64\Export.png" Can't load image file "textures\tooltips\Export.png" Loaded image file "textures\icons64\Import.png" Can't load image file "textures\tooltips\Import.png" Loaded image file "textures\icons64\Clear.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Invert.png" Can't load image file "textures\tooltips\Invert.png" Loaded image file "textures\icons64\Rotate_Clock.png" Can't load image file "textures\tooltips\Rotate_Clock.png" Loaded image file "textures\icons64\Rotate_AnitClock.png" Can't load image file "textures\tooltips\Rotate_AnitClock.png" Loaded image file "textures\icons64\Flip_U.png" Can't load image file "textures\tooltips\Flip_U.png" Loaded image file "textures\icons64\Flip_V.png" Can't load image file "textures\tooltips\Flip_V.png" Loaded image file "textures\icons64\Relax_UV.png" Can't load image file "textures\tooltips\Relax_UV.png" Loaded image file "textures\icons64\Relax_UV.png" Can't load image file "textures\tooltips\Relax_UV.png" Loaded image file "textures\icons64\ABF.png" Can't load image file "textures\tooltips\ABF.png" Loaded image file "textures\icons64\LSCM.png" Can't load image file "textures\tooltips\LSCM.png" Loaded image file "textures\icons64\Planar.png" Can't load image file "textures\tooltips\Planar.png" Loaded image file "textures\icons64\Hide_UV.png" Can't load image file "textures\tooltips\Hide_UV.png" Loaded image file "textures\icons64\Invert_Hidden.png" Can't load image file "textures\tooltips\Invert_Hidden.png" Loaded image file "textures\icons64\UnHide.png" Can't load image file "textures\tooltips\UnHide.png" Loaded image file "textures\icons64\Unhide_All.png" Can't load image file "textures\tooltips\Unhide_All.png" Loaded image file "textures\icons64\Copy_UV.png" Can't load image file "textures\tooltips\Copy_UV.png" Loaded image file "textures\icons64\Paste.png" Can't load image file "textures\tooltips\Paste.png" Loaded image file "textures\icons64\Add_Split.png" Can't load image file "textures\tooltips\Add_Split.png" Loaded image file "textures\icons64\Select.png" Can't load image file "textures\tooltips\Select.png" Loaded image file "textures\icons64\Mark_Seams.png" Can't load image file "textures\tooltips\Mark_Seams.png" Loaded image file "textures\icons64\Quad.png" Can't load image file "textures\tooltips\Quad.png" Loaded image file "textures\icons64\Pointand_Faces.png" Can't load image file "textures\tooltips\Pointand_Faces.png" Loaded image file "textures\icons64\Cap.png" Can't load image file "textures\tooltips\Cap.png" Loaded image file "textures\icons64\Strokes.png" Can't load image file "textures\tooltips\Strokes.png" Loaded image file "textures\icons64\Brush.png" Can't load image file "textures\tooltips\Brush.png" Loaded image file "textures\icons64\Delete_Polygons.png" Can't load image file "textures\tooltips\Delete_Polygons.png" Loaded image file "textures\icons64\Delete_Edges.png" Can't load image file "textures\tooltips\Delete_Edges.png" Loaded image file "textures\icons64\Collapse_Edge.png" Can't load image file "textures\tooltips\Collapse_Edge.png" Loaded image file "textures\icons64\Split_Ring.png" Can't load image file "textures\tooltips\Split_Ring.png" Loaded image file "textures\icons64\Select_Verts.png" Can't load image file "textures\tooltips\Select_Verts.png" Loaded image file "textures\icons64\Slide_Edge.png" Can't load image file "textures\tooltips\Slide_Edge.png" Loaded image file "textures\icons64\Mark_Seams.png" Can't load image file "textures\tooltips\Mark_Seams.png" Loaded image file "textures\icons64\Mark_Seams_Edge_Loop.png" Can't load image file "textures\tooltips\Mark_Seams_Edge_Loop.png" Loaded image file "textures\icons64\Retopo_Transform.png" Can't load image file "textures\tooltips\Retopo_Transform.png" Loaded image file "textures\icons64\Import.png" Can't load image file "textures\tooltips\Import.png" Loaded image file "textures\icons64\Export.png" Can't load image file "textures\tooltips\Export.png" Loaded image file "textures\icons64\Snap.png" Can't load image file "textures\tooltips\Snap.png" Loaded image file "textures\icons64\Subdivide.png" Can't load image file "textures\tooltips\Subdivide.png" Loaded image file "textures\icons64\Clear.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Relax.png" Can't load image file "textures\tooltips\Relax.png" Loaded image file "textures\icons64\Symmetry.png" Can't load image file "textures\tooltips\Symmetry.png" Loaded image file "textures\icons64\Sculpt_Move.png" Can't load image file "textures\tooltips\Sculpt_Move.png" Loaded image file "textures\icons64\Sculpt_Select_Move.png" Can't load image file "textures\tooltips\Sculpt_Select_Move.png" Loaded image file "textures\icons64\Sculpt_Drag_Points.png" Can't load image file "textures\tooltips\Sculpt_Drag_Points.png" Loaded image file "textures\icons64\Sculpt_Collapse.png" Can't load image file "textures\tooltips\Sculpt_Collapse.png" Loaded image file "textures\icons64\Sculpt_Expand.png" Can't load image file "textures\tooltips\Sculpt_Expand.png" Loaded image file "textures\icons64\Sculpt_Smudge.png" Can't load image file "textures\tooltips\Sculpt_Smudge.png" Loaded image file "textures\icons64\Sculpt_Smooth.png" Can't load image file "textures\tooltips\Sculpt_Smooth.png" Loaded image file "textures\icons64\Sculpt_Move.png" Can't load image file "textures\tooltips\Sculpt_Move.png" Loaded image file "textures\icons64\Sculpt_Select_Move.png" Can't load image file "textures\tooltips\Sculpt_Select_Move.png" Loaded image file "textures\icons64\Sculpt_Drag_Points.png" Can't load image file "textures\tooltips\Sculpt_Drag_Points.png" Loaded image file "textures\icons64\Sculpt_Draw.png" Can't load image file "textures\tooltips\Sculpt_Draw.png" Loaded image file "textures\icons64\Sculpt_Collapse.png" Can't load image file "textures\tooltips\Sculpt_Collapse.png" Loaded image file "textures\icons64\Sculpt_Expand.png" Can't load image file "textures\tooltips\Sculpt_Expand.png" Loaded image file "textures\icons64\Sculpt_Smudge.png" Can't load image file "textures\tooltips\Sculpt_Smudge.png" Loaded image file "textures\icons64\Sculpt_Smudge.png" Can't load image file "textures\tooltips\Sculpt_Smudge.png" Loaded image file "textures\icons64\Sculpt_Flatten.png" Can't load image file "textures\tooltips\Sculpt_Flatten.png" Loaded image file "textures\icons64\Sculpt_Smooth.png" Can't load image file "textures\tooltips\Sculpt_Smooth.png" Loaded image file "textures\icons64\Spin.png" Can't load image file "textures\tooltips\Spin.png" Loaded image file "textures\icons64\Spin_back.png" Can't load image file "textures\tooltips\Spin_back.png" Loaded image file "textures\icons64\Extrude.png" Can't load image file "textures\tooltips\Extrude.png" Loaded image file "textures\icons64\Split.png" Can't load image file "textures\tooltips\Split.png" Loaded image file "textures\icons64\Collapse_Edge.png" Can't load image file "textures\tooltips\Collapse_Edge.png" Loaded image file "textures\icons64\Clear.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Mark_Seams_Edge_Loop.png" Can't load image file "textures\tooltips\Mark_Seams_Edge_Loop.png" Loaded image file "textures\icons64\Edge_Ring.png" Can't load image file "textures\tooltips\Edge_Ring.png" Loaded image file "textures\icons64\Sharp_Seams.png" Can't load image file "textures\tooltips\Sharp_Seams.png" Loaded image file "textures\icons64\Bevel.png" Can't load image file "textures\tooltips\Bevel.png" Loaded image file "textures\icons64\Apply_UV.png" Can't load image file "textures\tooltips\Apply_UV.png" Loaded image file "textures\icons64\Clear_Seams.png" Can't load image file "textures\tooltips\Clear_Seams.png" Loaded image file "textures\icons64\Clear.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Clone.png" Can't load image file "textures\tooltips\Clone.png" Loaded image file "textures\icons64\Subdivide.png" Can't load image file "textures\tooltips\Subdivide.png" Loaded image file "textures\icons64\Hide_UV.png" Can't load image file "textures\tooltips\Hide_UV.png" Loaded image file "textures\icons64\Invert_Hidden.png" Can't load image file "textures\tooltips\Invert_Hidden.png" Loaded image file "textures\icons64\Unhide.png" Can't load image file "textures\tooltips\Unhide.png" Loaded image file "textures\icons64\ExtrudeNormal.png" Can't load image file "textures\tooltips\ExtrudeNormal.png" Loaded image file "textures\icons64\ExtrudeFree.png" Can't load image file "textures\tooltips\ExtrudeFree.png" Loaded image file "textures\icons64\Undercuts.png" Can't load image file "textures\tooltips\Undercuts.png" Loaded image file "textures\icons64\PaintHoleTool.png" Can't load image file "textures\tooltips\PaintHoleTool.png" Loaded image file "textures\icons64\CloseHole.png" Can't load image file "textures\tooltips\CloseHole.png" Loaded image file "textures\icons64\Fit.png" Can't load image file "textures\tooltips\Fit.png" Loaded image file "textures\icons64\Decimate.png" Can't load image file "textures\tooltips\Decimate.png" Loaded image file "textures\icons64\PinHoles2.png" Can't load image file "textures\tooltips\PinHoles2.png" Loaded image file "textures\icons64\Reconstruct.png" Can't load image file "textures\tooltips\Reconstruct.png" Loaded image file "textures\icons64\Bridge.png" Can't load image file "textures\tooltips\Bridge.png" Loaded image file "textures\icons64\VoxExtrude.png" Can't load image file "textures\tooltips\VoxExtrude.png" Loaded image file "textures\icons64\VoxIndent.png" Can't load image file "textures\tooltips\VoxIndent.png" Loaded image file "textures\icons64\ToLine.png" Can't load image file "textures\tooltips\ToLine.png" Loaded image file "textures\icons64\Equidistant.png" Can't load image file "textures\tooltips\Equidistant.png" Loaded image file "textures\icons64\Horizontal.png" Can't load image file "textures\tooltips\Horizontal.png" Loaded image file "textures\icons64\Vertical.png" Can't load image file "textures\tooltips\Vertical.png" Loaded image file "textures\icons64\Edgeloop.png" Can't load image file "textures\tooltips\Edgeloop.png" Loaded image file "textures\icons64\Edgering.png" Can't load image file "textures\tooltips\Edgering.png" Loaded image file "textures\icons64\ShuffleUV.png" Can't load image file "textures\tooltips\ShuffleUV.png" Loaded image file "textures\icons64\settings.png" Can't load image file "textures\tooltips\settings.png" Loaded image file "textures\icons64\SplitNJoints.png" Can't load image file "textures\tooltips\SplitNJoints.png" Loaded image file "textures\icons64\Lute.png" Can't load image file "textures\tooltips\Lute.png" Loaded image file "textures\icons64\SuperPinch.png" Can't load image file "textures\tooltips\SuperPinch.png" Loaded image file "textures\icons64\SubdivideVoxSurf.png" Can't load image file "textures\tooltips\SubdivideVoxSurf.png" Loaded image file "textures\icons64\InfSmooth.png" Can't load image file "textures\tooltips\InfSmooth.png" Loaded image file "textures\icons64\CopyClay64.png" Can't load image file "textures\tooltips\CopyClay64.png" Loaded image file "textures\icons64\Relax_UV.png" Can't load image file "textures\tooltips\Relax_UV.png" Loaded image file "textures\icons64\GU.png" Can't load image file "textures\tooltips\GU.png" Loaded image file "textures\icons64\Noise.png" Can't load image file "textures\tooltips\Noise.png" Loaded image file "textures\icons64\ScaleCL.png" Can't load image file "textures\tooltips\ScaleCL.png" Loaded image file "textures\icons64\StoreSel.png" Can't load image file "textures\tooltips\StoreSel.png" Loaded image file "textures\icons64\RecallSel.png" Can't load image file "textures\tooltips\RecallSel.png" Loaded image file "textures\icons64\ClearSel.png" Can't load image file "textures\tooltips\ClearSel.png" Loaded image file "textures\icons64\PixelArt.png" Can't load image file "textures\tooltips\PixelArt.png" Loaded image file "textures\icons64\QuickPose.png" Can't load image file "textures\tooltips\QuickPose.png" Loaded image file "textures\icons64\FillHoles.png" Can't load image file "textures\tooltips\FillHoles.png" Can't load image file "textures\masks\Arrow_01_prv.tga" Loaded image file "Temp\Arrow_0135782.tga" Can't load image file "textures\masks\fr_prv.tga" Loaded image file "Temp\fr23483.tga" Can't load image file "textures\masks\Grid_prv.tga" Loaded image file "Temp\Grid27501.tga" Can't load image file "textures\masks\honeycomb_prv.tga" Loaded image file "Temp\honeycomb41697.tga" Can't load image file "textures\masks\Misk_01_prv.tga" Loaded image file "Temp\Misk_0132829.tga" Can't load image file "textures\masks\Misk_02_prv.tga" Loaded image file "Temp\Misk_0232851.tga" Can't load image file "textures\masks\Misk_03_prv.tga" Loaded image file "Temp\Misk_0332873.tga" Can't load image file "textures\masks\Noise_01_prv.tga" Loaded image file "Temp\Noise_0135493.tga" Can't load image file "textures\masks\Noise_02_prv.tga" Loaded image file "Temp\Noise_0235516.tga" Can't load image file "textures\masks\Noise_03_prv.tga" Loaded image file "Temp\Noise_0335539.tga" Can't load image file "textures\masks\Noise_04_prv.tga" Loaded image file "Temp\Noise_0435562.tga" Can't load image file "textures\masks\Noise_05_prv.tga" Loaded image file "Temp\Noise_0535585.tga" Can't load image file "textures\masks\Rhombs_prv.tga" Loaded image file "Temp\Rhombs32885.tga" Can't load image file "textures\masks\Triangle_prv.tga" Loaded image file "Temp\Triangle38162.tga" Can't load image file "textures\masks\Cracks_prv.tga" Loaded image file "Temp\Cracks32689.tga" Can't load image file "textures\masks\OT_DiagGrid_straight01_prv.tga" Loaded image file "Temp\OT_DiagGrid_straight0182532.tga" Can't load image file "textures\masks\OT_DiagGrid_straight02_prv.tga" Loaded image file "Temp\OT_DiagGrid_straight0282569.tga" Can't load image file "textures\masks\OT_DiagGrid_straight03_prv.tga" Loaded image file "Temp\OT_DiagGrid_straight0382606.tga" Can't load image file "textures\masks\OT_mask_dented01_prv.tga" Loaded image file "Temp\OT_mask_dented0160138.tga" Can't load image file "textures\masks\OT_mask_dirt02_prv.tga" Loaded image file "Temp\OT_mask_dirt0253715.tga" Can't load image file "textures\masks\OT_mask_dirt03_prv.tga" Loaded image file "Temp\OT_mask_dirt0353744.tga" Can't load image file "textures\masks\OT_mask_dirt04_prv.tga" Loaded image file "Temp\OT_mask_dirt0453773.tga" Can't load image file "textures\masks\OT_textureFX_dirt13_prv.tga" Loaded image file "Temp\OT_textureFX_dirt1371421.tga" Can't load image file "textures\masks\OT_textureFX_dirt14_prv.tga" Loaded image file "Temp\OT_textureFX_dirt1471455.tga" Can't load image file "textures\masks\OT_textureFX_dirt15_prv.tga" Loaded image file "Temp\OT_textureFX_dirt1571489.tga" Can't load image file "textures\masks\OT_textureFX_fingerprints03_prv.tga" Loaded image file "Temp\OT_textureFX_fingerprints03107056.tga" Can't load image file "textures\masks\OT_textureFX_grimy01_prv.tga" Loaded image file "Temp\OT_textureFX_grimy0175631.tga" Can't load image file "textures\masks\OT_textureFX_scratches05_prv.tga" Loaded image file "Temp\OT_textureFX_scratches0592168.tga" Can't load image file "textures\masks\OT_vents05_prv.tga" Loaded image file "Temp\OT_vents0541613.tga" Can't load image file "textures\masks\SkinCracks_prv.tga" Loaded image file "Temp\SkinCracks43680.tga" Can't load image file "textures\masks\SkinCracks1_prv.tga" Loaded image file "Temp\SkinCracks145321.tga" Can't load image file "textures\masks\StoneDirt1_prv.tga" Loaded image file "Temp\StoneDirt142742.tga" Can't load image file "textures\masks\OT_dirt_prv.tga" Loaded image file "Temp\OT_dirt35306.tga" Can't load image file "textures\masks\OT_dirt02_prv.tga" Loaded image file "Temp\OT_dirt0238352.tga" Can't load image file "textures\masks\OT_dirt_bulletHolesDepth01_8_prv.tga" Loaded image file "Temp\OT_dirt_bulletHolesDepth01_8107726.tga" Can't load image file "textures\masks\OT_mask_rust01_prv.tga" Loaded image file "Temp\OT_mask_rust0154470.tga" Can't load image file "textures\masks\OT_random6_prv.tga" Loaded image file "Temp\OT_random642608.tga" Can't load image file "textures\masks\OT_tech3_prv.tga" Loaded image file "Temp\OT_tech336495.tga" Can't load image file "textures\masks\OT_texturefx_dirtmask01_prv.tga" Loaded image file "Temp\OT_texturefx_dirtmask0189802.tga" Can't load image file "textures\masks\OT_texturefx_dirtmask02_prv.tga" Loaded image file "Temp\OT_texturefx_dirtmask0289840.tga" Can't load image file "textures\masks\OT_texturefx_riddled_prv.tga" Loaded image file "Temp\OT_texturefx_riddled80237.tga" Loaded image file "materials\default\Mattress_prv.tga" Loaded image file "materials\default\Fabric_prv.tga" Loaded image file "materials\default\Paper_prv.tga" Loaded image file "materials\default\Kalshuga_prv.tga" Loaded image file "materials\default\Fabric_2_prv.tga" Loaded image file "materials\default\leather_prv.tga" Loaded image file "materials\default\leopard_prv.tga" Loaded image file "materials\default\Elefant_prv.tga" Loaded image file "VoxStamps\Objects\Capsule_preview.png" Loaded image file "VoxStamps\Objects\column_preview.png" Loaded image file "VoxStamps\Objects\Cone_preview.png" Loaded image file "VoxStamps\Objects\Cube_preview.png" Loaded image file "VoxStamps\Objects\Cylinder_preview.png" Loaded image file "VoxStamps\Objects\dodecahedron_preview.png" Loaded image file "VoxStamps\Objects\Icosahedron_preview.png" Loaded image file "VoxStamps\Objects\Sphere_preview.png" Loaded image file "VoxStamps\Objects\Star_preview.png" Loaded image file "VoxStamps\Objects\Torus_preview.png" Loaded image file "VoxStamps\Splines\chain_preview.png" Loaded image file "VoxStamps\Splines\Dragon1_preview.png" Loaded image file "VoxStamps\Splines\Dragon2_preview.png" Loaded image file "VoxStamps\Splines\Dragon3_preview.png" Loaded image file "VoxStamps\Splines\Dragon4_preview.png" Loaded image file "VoxStamps\Splines\Dragon5_preview.png" Loaded image file "VoxStamps\Splines\pipe_segment_preview.png" Loaded image file "VoxStamps\Splines\shlang_preview.png" Loaded image file "VoxStamps\Splines\spring_preview.png" Loaded image file "VoxStamps\Splines\spring2_preview.png" Loaded image file "VoxStamps\Splines\spring3_preview.png" Loaded image file "VoxStamps\Splines\Tentacle_preview.png" Loaded image file "VoxStamps\Splines\WildTeeth_preview.png" Loaded image file "VoxStamps\RtpModels\Capsule_preview.png" Loaded image file "VoxStamps\RtpModels\Cube_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_preview.png" Loaded image file "VoxStamps\RtpModels\GeoSphere_preview.png" Loaded image file "VoxStamps\RtpModels\Patch1_preview.png" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Can't load image file "textures\preview_pen0.tga" Can't load image file "textures\preview_pen5.tga" Can't load image file "Shape1" Can't load image file "Shape1" Can't load image file "Shape1" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Can't load image file "Shape" Can't load image file "Shape" Can't load image file "Shape1" Can't load image file "Shape1" Can't load image file "Shape1" Can't load image file "Shape" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_artman greeble2 strip_HardSurface_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_artman greeble2 strip_HardSurface_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_manyspots_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_manyspots_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_manyscratches_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_manyscratches_mclp.dds" Loaded image file "Unicode\eu\Font00.dds" Locale: German_Luxembourg.1252 Loaded image file "Textures\stdimage.dds" Loaded image file "Temp\pano.dds" Loaded image file "textures\white.dds" Loaded image file "textures\light\baseicons.tga" Can't load image file "textures\default.dds" Loaded image file "textures\2knopki.tga" Loaded image file "textures\smallwhiteicons.dds" Loaded image file "textures\dark\property.tga" Loaded image file "textures\RightArrow.dds" Loaded image file "Textures\light\Navigation.tga" Can't load image file "textures\preview_pen0.tga" Can't load image file "textures\preview_pen1.tga" Can't load image file "textures\preview_pen2.tga" Can't load image file "textures\preview_pen3.tga" Can't load image file "textures\preview_pen4.tga" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_000_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_000_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_chain_227B_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_chain_227B_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_cheshuja_7BF3_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_cheshuja_7BF3_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_003_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_003_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_004_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_004_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_005_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_005_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_007_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_007_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_008_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_008_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Fabric0001_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Fabric0001_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Gem1_70C8_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Gem1_70C8_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Gem1_EC21_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Gem1_EC21_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_hair03_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_hair03_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_hair14_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_hair14_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_knopka_03_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_knopka_03_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_kosichka_20A7_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_kosichka_20A7_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_OT_corroded_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_OT_corroded_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_OT_Speckled03_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_OT_Speckled03_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_OT_Speckled04_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_OT_Speckled04_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Patron_C89D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Patron_C89D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_pen4_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_pen4_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_pen5_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_pen5_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Piramida_8AF9_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Piramida_8AF9_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_pugovka_CC7C_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_pugovka_CC7C_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_randomscratches_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_randomscratches_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Ringmail2_3BD4_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Ringmail2_3BD4_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Ringmail_0C3E_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Ringmail_0C3E_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rings_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rings_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_003_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_003_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_007_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_007_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_011_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_011_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_013_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_013_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_014_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_014_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_005_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_005_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_008_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_008_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_009_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_009_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_sq_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_sq_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_sqgrad_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_sqgrad_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_sqgradstrip_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_sqgradstrip_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_taty_2_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_taty_2_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_004_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_004_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_009_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_009_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_012_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_012_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_wire_9832_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_wire_9832_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Blob2_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Blob2_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Blob_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Blob_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure2_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure2_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure5_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure5_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Gear06_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Gear06_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Skin01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Skin01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Skin02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Skin02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Skin08_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Skin08_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Tech02_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Tech02_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle01_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle01_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle06_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle06_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_Capsule_A87D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_Capsule_A87D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_chain_BE26_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_chain_BE26_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_Edge1_8F5C_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_Edge1_8F5C_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_fabr_kromka_01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_fabr_kromka_01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_Patron_09C2_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_Patron_09C2_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_pen4_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_pen4_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_strip1_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_strip1_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_strip3_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_strip3_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_strip5_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_strip5_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_wire_44D3_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_wire_44D3_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper02_mclp.dds" Loaded image file "PickData\sky.jpg" Loaded image file "PickData\sky.jpg" Loaded image file "PickData\sky.jpg" Loaded image file "textures\grey3.dds" Loaded image file "textures\dark\stdbutton.tga" Loaded image file "Textures\dark\Navigation.tga" Loaded image file "textures\dark\Icons16.tga" Loaded image file "Textures\dark\Locks.tga" Loaded image file "textures\taper32.png" Loaded image file "StartMenu\images\MainLogo3.png" Loaded image file "textures\icons64\Blob_Vox.png" Loaded image file "textures\icons64\Sketch_Tool.png" Loaded image file "textures\icons64\Repair.png" Loaded image file "textures\icons64\im2mesh.png" Loaded image file "textures\icons64\vertexpaint.png" Loaded image file "textures\icons64\ppp.png" Loaded image file "textures\icons64\mv.png" Loaded image file "textures\icons64\ptex.png" Loaded image file "textures\icons64\Cap.png" Loaded image file "textures\icons64\Mark_Seams.png" Loaded image file "textures\icons64\Bass-releif.png" Loaded image file "textures\icons64\Recent.png" Can't load image file "textures\preview_pen0.tga" Loaded image file "StartMenu\images\MainLogo3.png" Loaded image file "textures\icons64\Blob_Vox.png" Loaded image file "textures\icons64\Sketch_Tool.png" Loaded image file "textures\icons64\Repair.png" Loaded image file "textures\icons64\im2mesh.png" Loaded image file "textures\icons64\vertexpaint.png" Loaded image file "textures\icons64\ppp.png" Loaded image file "textures\icons64\mv.png" Loaded image file "textures\icons64\ptex.png" Loaded image file "textures\icons64\Cap.png" Loaded image file "textures\icons64\Mark_Seams.png" Loaded image file "textures\icons64\Bass-releif.png" Loaded image file "textures\icons64\Recent.png" Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Materials Loaded image file "materials\default\Mattress_prv.tga" Loaded image file "materials\default\Fabric_prv.tga" Loaded image file "materials\default\Paper_prv.tga" Loaded image file "materials\default\Kalshuga_prv.tga" Loaded image file "materials\default\Fabric_2_prv.tga" Loaded image file "materials\default\leather_prv.tga" Loaded image file "materials\default\leopard_prv.tga" Loaded image file "materials\default\Elefant_prv.tga" * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ALL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ENV Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_COLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_COLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_RELIEF Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_SPECULAR Compiling VS... Compiling PS... * Loading shader "Shaders/shadow_sel.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/shadow_tbn.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define SHADOW Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define VERT_NORMAL #define SHADOW Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ALL #define SHADOW Compiling VS... Compiling PS... Loaded image file "textures\chess.dds" Loaded image file "textures\black.dds" Loaded image file "textures\dashes.dds" Loaded image file "textures\dashes2.dds" Loaded image file "textures\snow.dds" Loaded image file "textures\dark\LayersIcons.tga" Loaded image file "textures\dark\stdbutton2.tga" Loaded image file "textures\borders\viewport.tga" * Loading shader "Shaders/hud_smooth.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... Loaded image file "textures\icons\wicons.png" Loaded image file "textures\borders\input_field.tga" Loaded image file "Textures\icons\arrowright.tga" Loaded image file "Textures\icons\arrowdown.tga" Loaded image file "textures\icons\move_area_16.tga" Loaded image file "textures\borders\dock_delimiter.tga" Loaded image file "textures\light\tabbutton_line.tga" Loaded image file "textures\dark\tabbutton.tga" Loaded image file "textures\dark\tabbutton_inactive.tga" Loaded image file "textures\dark\checkers.tga" Loaded image file "textures\BothSideArrows.tga" Loaded image file "textures\vista3.dds" Loaded image file "Textures\dark\DownArrow.tga" Loaded image file "textures\borders\combo_inner_frame.tga" Loaded image file "textures\borders\combo_arrow_frame.tga" Loaded image file "textures\borders\dialog_header.tga" Loaded image file "textures\borders\dialogs.tga" Loaded image file "textures\borders\toolset_internal_buttons.tga" Loaded image file "textures\icons\larrow.tga" Loaded image file "textures\switchcolors.tga" Loaded image file "textures\borders\docked.tga" Can't load image file "textures\stdbutton.tga" Loaded image file "textures\close.tga" Loaded image file "textures\borders\buttons.tga" Interpreting command: recent3b(); Loading file: E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\UV-3.3b 00000000 : RNDR : 8 bytes 00000010 : NSYZ : 0 bytes 00000018 : NBLN : 0 bytes 00000020 : MSSK : 20 bytes 0000003C : PAUV : 16 bytes E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\UV-3.3b: Unknown block found in 3DB file: VUAP! 00000054 : MEAS : 8 bytes 00000064 : CAM1 : 88 bytes 000000C4 : LNRM : 4 bytes 000000D0 : SSPC : 0 bytes 000000D8 : LR01 : 1662 bytes 0000075E : MTLS : 328 bytes 000008AE : MTEX : 129 bytes 00000937 : OBJS : 558 bytes 00000B6D : RNTS : 373 bytes 00000CEA : UVST : 365 bytes 00000E5F : SUBD : 0 bytes 00000E67 : VMAP : 4 bytes 00000E73 : VMTP : 49 bytes 00000EAC : POS0 : 166572 bytes 00029960 : UVS0 : 8 bytes 00029970 : SAR7 : 3140096 bytes Faces: done SetupUVIds: done SetAllDirty: done 00328378 : MAQ2 : 2689652 bytes 005B8DF4 : CMSC : 61 bytes 005B8E39 : STIL : 2237 bytes 005B96FE : RTP1 : 240 bytes 005B97F6 : SYMM : 8 bytes 005B9806 : UVM1 : 1395030 bytes 0070E164 : METU : 16 bytes 0070E17C : VOL3 : 4 bytes 0070E188 : VCSH : 4 bytes 0070E194 : GRIS : 56 bytes 0070E1D4 : MVSV : 4 bytes 0070E1E0 : CVSV : 4 bytes 0070E1EC : OLCO : 4 bytes 0070E1F8 : RFSV : 30 bytes 0070E21E : FITT : 116 bytes 0070E29A : SCPT : 52 bytes 0070E2D6 : SP&J : 1077 bytes 0070E713 : VOSS : 4 bytes 0070E71F : HLSV : 4 bytes 0070E72B : RTGV : 4 bytes 0070E737 : OBJV : 4 bytes 0070E743 : MATV : 4 bytes 0070E74F : BPSS : 358 bytes 0070E8BD : VCUR : 29 bytes 0070E8E2 : SELP : 120 bytes 0070E962 : REND : 1239 bytes 0070EE41 : PTEX : 110136 bytes 00729C81 : URC1 : 20 bytes 00729C9D : APSV : 12 bytes 00729CB1 : SYNP : 403 bytes PutFacesInCells: done * Loading shader "Shaders/rt_copy.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... UpdateDirtyFaces: done Loaded image file "Textures\grey.dds" Loaded image file "Textures\whitet.dds" Loaded image file "Textures\emptygrey.dds" CreateMeshes: done CreatePaddingInfo: done CreatePointsCorrespondence: done CreateTangentSpaceFromBasicNormals: done Loading: done Can't load image file "textures\preview_pen0.tga" Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Materials Deleted: Layers Deleted: Blending Loaded image file "textures\borders\top_menu_highlight.tga" Undocked: Undocked: Undocked: Loaded image file "FillPatterns\leather2.bmp" Loaded image file "textures\icons\texticon.tga" Loaded image file "textures\DownArrow.dds" Loaded image file "textures\borders\tool_select_buttons.tga" * Loading shader "Shaders/uvpreview.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/uv.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... Loaded image file "textures\checker0.tga" Loaded image file "textures\checker1.tga" Loaded image file "textures\checker2.tga" * Loading shader "Shaders/wires.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... Loaded image file "textures\borders\undocked.tga" Loaded image file "textures\borders\hints.tga" Can't load image file "textures\preview_pen0.tga" Options.xml: <AppOptions> <PenInterface::DisplaceObject>false</PenInterface::DisplaceObject> <RtpObj>true</RtpObj> <SoftwarePreset>Unknown</SoftwarePreset> <NormalsCalculationMethod>Maya_normals</NormalsCalculationMethod> <TriangulationMethod>DelaunayTriangulation</TriangulationMethod> <TBNMethod>MikkTSpace</TBNMethod> <NMAP_EXPORT_TYPE>NM_3DMAX</NMAP_EXPORT_TYPE> <FlipPtexQuads>false</FlipPtexQuads> <ShowFocalShift>false</ShowFocalShift> <ShowFalloff>true</ShowFalloff> <StorePenShapeForTools>true</StorePenShapeForTools> <StorePenRadiusForTools>true</StorePenRadiusForTools> <WHEEL_ACTION>WHEEL_CHANGE_RADIUS</WHEEL_ACTION> <CTRL_WHEEL_ACTION>WHEEL_CHANGE_PRESSURE</CTRL_WHEEL_ACTION> <SHIFT_WHEEL_ACTION>WHEEL_CHANGE_SMOOTH</SHIFT_WHEEL_ACTION> <ALT_WHEEL_ACTION>WHEEL_CHANGE_OPACITY</ALT_WHEEL_ACTION> <WheelZoomPerspSpeed>1.000000</WheelZoomPerspSpeed> <WheelZoomOrthoSpeed>1.000000</WheelZoomOrthoSpeed> <WheelZoomUVSpeed>1.000000</WheelZoomUVSpeed> <MainColor>FF40CC40</MainColor> <BackColor>FF000000</BackColor> <EnableChannels[0]>true</EnableChannels[0]> <EnableChannels[1]>true</EnableChannels[1]> <EnableChannels[3]>false</EnableChannels[3]> <NearPlane>1.000000</NearPlane> <PivotType>0</PivotType> <PenInterface::SaveSpecInNM>false</PenInterface::SaveSpecInNM> <PenInterface::SaveDispInNM>false</PenInterface::SaveDispInNM> <PenInterface::DontUseAnphaInNM>false</PenInterface::DontUseAnphaInNM> <PenInterface::DontUseAnphaAtAll>false</PenInterface::DontUseAnphaAtAll> <SymmSnapValue>0.400000</SymmSnapValue> <SnappingMethod2>1</SnappingMethod2> <Global_DontSnapSubdVertices>true</Global_DontSnapSubdVertices> <ProjectionThrough>false</ProjectionThrough> <FreezeViewMode>0</FreezeViewMode> <FreezePScrollSpeed>1.000000</FreezePScrollSpeed> <UsingProcessors>32</UsingProcessors> <UseMultiCore>true</UseMultiCore> <UseMulticoreForSaving>true</UseMulticoreForSaving> <UseMRT>true</UseMRT> <PickFromAllLayers1>true</PickFromAllLayers1> <PickDepthToo>true</PickDepthToo> <PickFromCentralPoint>true</PickFromCentralPoint> <PivotType>0</PivotType> <SwapYZ>false</SwapYZ> <EditorPath>photoshop.exe</EditorPath> <MeshViewQuality>0</MeshViewQuality> <Choose></Choose> <FILL_BORDERS_MODE>FILLB_ASK</FILL_BORDERS_MODE> <BorderEdgesWidth>64</BorderEdgesWidth> <LightDirX>-0.562900</LightDirX> <LightDirY>-0.279500</LightDirY> <LightDirZ>0.279500</LightDirZ> <MillionsOfPolygons>1.000000</MillionsOfPolygons> <TexSizeX>1024</TexSizeX> <TexSizeY>1024</TexSizeY> <LightAmbient>0.000000</LightAmbient> <ShowThumbs>true</ShowThumbs> <ShowIThumbs>true</ShowIThumbs> <ImgPath> <_str>PickData\sky.jpg</_str> </ImgPath> <PickerType>1</PickerType> <PickColorMode>0</PickColorMode> <PenSensivity>1.000000</PenSensivity> <Symmetry_point_opacity>40.000000</Symmetry_point_opacity> <CamZoomSpeed>1.000000</CamZoomSpeed> <CamRotSpeed>1.000000</CamRotSpeed> <SlidersStates> <SliderState> <ID>SMOOTH_STROKE</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_RADIUS</ID> <State>true</State> </SliderState> <SliderState> <ID>FALLOFF</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_DEPTH</ID> <State>true</State> </SliderState> <SliderState> <ID>SMOOTH_DEG</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_MASK</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_SPEC</ID> <State>true</State> </SliderState> <SliderState> <ID>ERASE_DEGREE</ID> <State>true</State> </SliderState> <SliderState> <ID>RetopoExtrusion</ID> <State>true</State> </SliderState> <SliderState> <ID>ViewBias</ID> <State>true</State> </SliderState> <SliderState> <ID>RtpOpacity</ID> <State>true</State> </SliderState> <SliderState> <ID>SymmSnapValue</ID> <State>true</State> </SliderState> <SliderState> <ID>*Basic2</ID> <State>true</State> </SliderState> <SliderState> <ID>*Tweak2</ID> <State>true</State> </SliderState> <SliderState> <ID>*UV2</ID> <State>true</State> </SliderState> <SliderState> <ID>*Commands2</ID> <State>true</State> </SliderState> <SliderState> <ID>*Surface4</ID> <State>true</State> </SliderState> <SliderState> <ID>*LC4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Adjust4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Objects4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Commands4</ID> <State>true</State> </SliderState> <SliderState> <ID>SegmentsNum</ID> <State>true</State> </SliderState> <SliderState> <ID>*Modes3</ID> <State>true</State> </SliderState> <SliderState> <ID>*Commands3</ID> <State>true</State> </SliderState> <SliderState> <ID>*Selected3</ID> <State>true</State> </SliderState> <SliderState> <ID>*Selected2</ID> <State>true</State> </SliderState> <SliderState> <ID>*Sculpt1</ID> <State>true</State> </SliderState> </SlidersStates> <FoldersStates> <FolderState> <ID>OPENOBJ</ID> <Folder>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\</Folder> </FolderState> <FolderState> <ID>ObjLwoStlPlydaewrl</ID> <Folder>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\</Folder> </FolderState> <FolderState> <ID>SAVEMESH</ID> <Folder>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\</Folder> </FolderState> <FolderState> <ID>3b</ID> <Folder>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\</Folder> </FolderState> <FolderState> <ID>3b3b.jpg</ID> <Folder>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\</Folder> </FolderState> </FoldersStates> <AllowRmbProp>true</AllowRmbProp> <PanoRotation>0.000000</PanoRotation> <PanoBlur>0.000000</PanoBlur> <ShadersPreviewSize>1</ShadersPreviewSize> <RareGrid>false</RareGrid> <NormalGrid>true</NormalGrid> <DenseGrid>false</DenseGrid> <CustomGrid>false</CustomGrid> <GridStep3D>1.000000</GridStep3D> <GridSubSections>1</GridSubSections> <GridStepsCount>10</GridStepsCount> <ShowAxisX>true</ShowAxisX> <ShowAxisY>true</ShowAxisY> <ShowAxisZ>true</ShowAxisZ> <MovementSensitivity>1.000000</MovementSensitivity> <ZoomModulator>1.000000</ZoomModulator> <PanUDModulator>1.000000</PanUDModulator> <PanRLModulator>1.000000</PanRLModulator> <RotationSensitivity>1.000000</RotationSensitivity> <SpinModulator>1.000000</SpinModulator> <TiltModulator>1.000000</TiltModulator> <RollModulator>1.000000</RollModulator> <M3D_ActivationKey>Key 1</M3D_ActivationKey> <PenIconSize>1</PenIconSize> <StripIconSize>1</StripIconSize> <MaskIconSize>1</MaskIconSize> <MtlIconSize>1</MtlIconSize> <ModelsIconSize>2</ModelsIconSize> <RotateAroundYAxis>true</RotateAroundYAxis> <DisableRoll>false</DisableRoll> <RealtimeUVPreview>true</RealtimeUVPreview> <ZoomToVaryRadiusSensitivity>1.000000</ZoomToVaryRadiusSensitivity> <UpDonToVaryDepthSensitivity>1.000000</UpDonToVaryDepthSensitivity> <RLToVaryTransparencySensitivity>1.000000</RLToVaryTransparencySensitivity> <SpinToVaryRotationSensitivity>1.000000</SpinToVaryRotationSensitivity> <TiltToVaryFocalShiftSensitivity>1.000000</TiltToVaryFocalShiftSensitivity> <RollToVarySpecularSensitivity>1.000000</RollToVarySpecularSensitivity> <GeneralPen::Color.x>0.250980</GeneralPen::Color.x> <GeneralPen::Color.y>0.800000</GeneralPen::Color.y> <GeneralPen::Color.z>0.250980</GeneralPen::Color.z> <GeneralPen::Color2.x>0.000000</GeneralPen::Color2.x> <GeneralPen::Color2.y>0.000000</GeneralPen::Color2.y> <GeneralPen::Color2.z>0.000000</GeneralPen::Color2.z> <GeneralPen::PenRadius>0.767960</GeneralPen::PenRadius> <GeneralPen::PenRotation>0.000000</GeneralPen::PenRotation> <GeneralPen::DeepDegree>0.414515</GeneralPen::DeepDegree> <GeneralPen::ColorOpacity>1.000000</GeneralPen::ColorOpacity> <GeneralPen::SpecularDegree>1.000000</GeneralPen::SpecularDegree> <GeneralPen::Falloff>0.000000</GeneralPen::Falloff> <GeneralPen::FocalShift>0.000000</GeneralPen::FocalShift> <HidePenConstantlyInCapsMode>false</HidePenConstantlyInCapsMode> <HidePenConstantly>false</HidePenConstantly> <ShowPenShape>true</ShowPenShape> <ShowPenAlpha>true</ShowPenAlpha> <PenCircleColor>FFFFFF00</PenCircleColor> <PenShapeColor>FFFF0000</PenShapeColor> <PenShapeColorWithCTRL>FF0000FF</PenShapeColorWithCTRL> <PenShapeColorWithSHIFT>FF00FF00</PenShapeColorWithSHIFT> <ShowCentralSpotInCapsMode>true</ShowCentralSpotInCapsMode> <MessageAbovePen>0</MessageAbovePen> <MessageBelowPen>0</MessageBelowPen> <MessagesColor>FFFF0000</MessagesColor> <PickVertMode2>1</PickVertMode2> <RecentFiles> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\SimpleChar.fbx</_str> <_str>D:\Libraries\Documents/3D-CoatV4/UserData\autosave.3b</_str> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\SimpleChar.fbx(dp)</_str> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\SimpleChar.ply(dp)</_str> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\Easy.obj(dp)</_str> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\UV.3b</_str> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\UV-2.3b</_str> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\UV-3.3b</_str> </RecentFiles> </AppOptions> Can anyone help ? Please -AgeTDev
  11. Hello! I am currently using the 30 day period to evaluate 3d coat. I want a better way to retopologize than what maya has to offer. After i retopologized my object i attempted to export it as a .FBX, which resulted in a crash. In fact i tried all 4 versions of the program executable and everyone one crashed when attempting to export the retopo mesh as a .fbx. I have submitted the info as prompted but i just wanted to post it here and see if maybe it's something that I'm doing wrong. A good note is that exporting to .OBJ works just fine. Attached is the screen shot and here is the submitted info of the report. http://pastebin.com/WbVuRQEh Thank you! -Jon
  12. MPaquin
    AUTOPO Hardsurface
    3D Coat seems to be crashing while doing Autopo with hard surface models. The mesh is 2 million polys. I also tried a decimated version from ZBrush. It's a pretty complex model so that might be a factor. Autopo works on another model without using the hardsurface setting. It seems to be stalling on CreatingCutGraph. Am I just being impatient or is really crashing?
  13. Whenever I do an action such as opening a file, saving a file, or pressing any buttons on the easy start-up menu apart from to work with voxels, 3D coat crashes. The only exceptions to this would be things like using open recent. I'm completely new to 3D coat, infact, any software of this type, and am unsure if I've stupidly ticked some box that would make the software act like this, however I've found it's gotten to a point that I can't work around the errors and this seriously needs fixed. Whenever it crashes it either tells me it is unstable and needs to shut down so I should save my work, but then shuts down without giving me a chance to after pressing OK, or in most cases opens a window entitled "CRASH!" along with a lot of information. I've entered a bug report but have yet to receive an e-mail back to me, so I decided that perhaps the forums could offer help sooner. It is a very urgent problem, and completely breaks the software so I need a fix rather soon. I've attached an image of the window I am given when the program crashes, I would have attached everything in the bug report but due to it's extensiveness I decided it would be best to only give it on request.
  14. version: 4.0.0.4 (CUDA)(DX64) I have a strange problem where I can load some saves, but not others. I'm not sure where the problem lies, but between these two save files attached, the 4th copy can be loaded just fine, but the 5th and every copy thereafter, gives me a crash. halp?
  15. Hello, I'm using 3Dcoat since few month now (since the steam release). Everything was running fine but now i've some problems who looks to be related to steam. Did'nt find any info about this particular problem on the forum. Every time i'm leaving 3d coat : steam crash and try to update itself when restarting. (every other steam apps do not act like this : only 3d coat). Some 3DCoat mode do not work anymore like : 64 CUDAOGL or 64CUDADIRECTX or 64DIRECTX I can't send any crash error log, when 3d coat crash i've a classic windows error message not a 3d coat or steam one. I did'nt made any major changes on my pc since this problem : no new hardware, no new drivers. i've already follow this steps. Reinstall V3.7 Reinstall steam+v3.7 Reinstall nvidia drivers Use check integrity option in steam app. I think they're nothing related but i've V4 on my computer too using my steam key. The exact same mode are working without problem. It's looks very strange to me. Any idea how to fiw this ? Some extra info : win7 i76600K 8go GTX 570 (v.306.94) Anyway, i'm enjoying a lot my 3D coat license, i've to post some picture in wip gallery soon :-) thanks for you help.
  16. I need urgent help. I have a fairly simple all-quad model I am trying to UV unwrap. If I manually mark the seams and hit Unwrap, 3D Coat crashes and I get forever spinning beachball. I am not using symmetry although the model itself is symmetrical. It is impossible to use 3D coat for unwrapping when this issue exists. I'm under deadline and I would need urgent help for this issue. I'm running 3D-Coat (3.7.08B (GL64) under Snow Leopard. My machine is Quad Core Mac Pro with 8 gigs of ram. Show screenshot of the model I try to unwrap.
