Showing results for tags 'power-smooth tool'.
  1. Hi @AndrewShpagin Please check this issue with a perfomance on PowerSmooth Tool Steps - import model, select 2K Texture, paint wtih a big radius. And you will see bad FPS = 1-3, with small radius it 70-100FPS I tested it on 3080 with 16Gb VRam and the latest build - 3DCoat-2022-46 For example in Mudbox 2023 - everything is fast, even with a very big radius... and 4K Texture. If needed - I will record a video example with it perfomance. Video with an issue: power_smooth_tool_issue.mp4 Thank you and have a great day Best regards, Andrew. Plane.fbx
