New Member myara Posted February 26, 2015 New Member Report Share Posted February 26, 2015 I'm new with 3DCoat and I love the way you can send your data back and forward to Photoshop with ctrl + P. Is there any way to do the same with Displacement and Normal Map? Quote Link to comment Share on other sites More sharing options...
Javis Posted February 26, 2015 Report Share Posted February 26, 2015 Hi! That's not possible at the moment, at least in the same way you can color/spec/gloss/etc.. But it is possible to export the map you want (from the menu Texture>Export>Map of your choice), tweak it as you like in PS or elsewhere, and then import (from the menu Texture>Import>Map of your choice again), and continue work in 3DC. It's a little roundabout, but works alright in most cases. Quote Link to comment Share on other sites More sharing options...
